» Tire Upgrade Garage
Old 12-31-2004, 05:00 PM   #1 (permalink)
SRToc Member
metfan2000_99's Avatar
Member Number: 2980
Default Big turbo Vacuum line setup question?
Hey guys I just want to know How you guys have the vaccum lines set up for the Big turbo! I have a line going from the turbo into the TURBO XS HPBC and than from there to the bottom nipple of the WGA....Is this right. I've seen some MBC set on the top and bottom ports of the WGA...Just woundering...
List of mods:
AGP T3/t04 50 trim
AGP FMIC
AGP CAI
AGP Fuel kit (SAFC-2)
AGP Hard Pipe
Return Fuel Line
HKS SSQ BOV
Motor Mounts
metfan2000_99 is offline   Reply With Quote
Old 12-31-2004, 05:16 PM   #2 (permalink)
Member Number: 13362
Trader Rating: (109)
This might help you , I got it from another member on here , & it works for me .
2.4TURBOMAN is offline   Reply With Quote
Old 12-31-2004, 05:20 PM   #3 (permalink)
SRToc Member
Member Number: 2980
I dont have the Emanage though, I am running the SAFC....Will that still work?
Old 12-31-2004, 05:28 PM   #4 (permalink)
dognutz's Avatar
Member Number: 14819
Trader Rating: (15)
you have it the right way now stop worrying use bottom nipple sir..
HOME OF THE MOST HP SRT4 ON NO SPRAY!! WITH 31psi BOOST
FOR ALL YOUR NEEDS RAGE-TEK IS THE ANSWER
Shop (954) 978-0978
Cell (954) 274-4175
http://mike-castaldo.tripod.com/
also check herehttp://home.comcast.net/~extreme1neo...ome.html-.html
dognutz is offline   Reply With Quote
Old 12-31-2004, 05:32 PM   #5 (permalink)
SRToc Member
Member Number: 2980
lol ok
Old 01-03-2005, 05:56 AM   #6 (permalink)
nastyblacksrt's Avatar
Member Number: 2683
does it really matter? can either the bottom or top nipple be used?
nastyblacksrt is offline   Reply With Quote
Old 01-03-2005, 07:00 AM   #7 (permalink)
Steven Burgess's Avatar
Member Number: 1515
I use both nipples on the wategate. My boost source has a T in it and one side goes to my mbc and then to one nipple on the wastegate. The other side of the T goes directly to the wastegate.
Steve B.
Custom 60-1 turbo
434hp 419torque @ 25psi
7.7@95mph
Stock turbo, 295whp @ 21psi 7.9@88.8mph
Local Sponsor: www.4totalperformance.com
Steven Burgess is offline   Reply With Quote
Page generated in 0.14924 seconds with 11 queries
