Old 05-25-2009, 09:25 AM   #1 (permalink)
Pomz23's Avatar
Member Number: 64878
Question Best/unexpensive way to datalog wideband.
I want a wideband gauge, but I want to be able to datalog it, because I plan on getting a DSP. whats a good gauge to do this on. I dont want to bother trying to data log the WB with the dsp, It just seems easier to log a WB by its self. Im looking at getting a AEM WB then getting a cheep data acquisition device and hooking it up to a tach driver and the WB. then loading it into a spreadsheet on graph. Will that work? Because other options ive found seemed to be expensive.
Metal Werkz - For Sale: New Custom Aluminum Door Sills and Radiator Shrouds!!!!!! Click here for my site.
Pomz23 is offline   Reply With Quote
Old 05-25-2009, 12:50 PM   #2 (permalink)
Nick Chestnut's Avatar
Member Number: 16791
I highly suggest the Zeitronix ZT-2. It will log RPM, TPS, MAP, EGT, and an auxiliary input. Logging just the wideband without RPM is rather inefficient.
Note: I am no longer offer tuning services. Please contact another vendor for tuning. I'm no longer going to compete with people who half ass things, make empty promises, and insist on flat out doing things the wrong way. I apologize for any inconvenience this may cause...
* Nick Chestnut *
* 2004 SRT-4, GT3076R @ 498WHP/502 WTQ *
Nick Chestnut is offline   Reply With Quote
Old 05-25-2009, 01:12 PM   #3 (permalink)
jc.turbo's Avatar
Member Number: 41950
Trader Rating: (35)
if you're slightly electronically savy, can try something from WBo2.com WIDEBAND AFR/LAMBDA (Tech Edge)
jc.turbo is offline   Reply With Quote
Old 05-25-2009, 02:11 PM   #4 (permalink)
Wow, cool! Never seen that before! Thanks for the link!
Old 05-25-2009, 02:31 PM   #5 (permalink)
TDSAaron's Avatar
Member Number: 68381
The NGK AFX is an extremely accurate inexpensive wideband controller. It doesn't do internal logging but it does have a 0-5v analog output. It is actually designed by ECM who makes laboratory grade widebands. If you buy an NTK sensor to use with it it's even more durable and accurate. The Bosch sensor works okay with it too. I use an ECM AFM1000 but not everybody is going to spend ~$1700.00 on a wideband controller.
Aaron Lail
Custom EFI Tuning
Diablo Sport CMR Tuner
www.TruDynoSports.com
"Let me tell you how much power your really making"
TDSAaron is offline   Reply With Quote
Old 05-26-2009, 08:28 PM   #6 (permalink)
Member Number: 44368
LM-1 with RPM converter, or just input the LM-1 analog out to the scangauge. With the RPM converter you can log rpm plus four other sensors.
rkinney is offline   Reply With Quote
