So I've tried to read (which is difficult for me as it is) about the different options to piggy back my fuel system for the new turbo going on.
Obviously I need a wideband which I will get as well as I'm going back to my stage 1 turbo and will be upgrading to larger injectors such as 750's or 900's..
Now, the questions I have are..
1) Are there any real advantages in going with a NEO over the older SAFC.
2) Do I need to upgrade the map & tip sensor as in with the stage 2+ kits?
3) At what point do I need a return line?? (I will be upgrading to a walbro 255 pump)
4) How do I control the boost with an external wastegate? I'm assuming I need either a manual or a electronic boost controller? options for this are??
Going with a AGP 50 trim Turbo external wastegated and the following mods are already installed..
B&B Exhaust no cat
AEM intake
Motor Mounts
HKS blow off
MSD Wires
NGK Plugs
Ported & polished intake & throttle body..
Thanks for everyone's input.. can't wait to start playing with the new turbo!
05 Silver - BB 50 Trim, SAFC II, PRoSpeC, B&B Exhaust, QW BFMIC, etc.. etc.. Big stereo.
04 Yellow Mustang GT - Novi 1000, Exhaust, Meth
SAFC NEO only has one tuning map so you can only tune it on either Pump gas or Race Gas. NEO does not have the knock retard reader, which is known not to be the most accurate.
No you dont need Map/Tip sensors if SAFC is hooked up right and vacuum lines.
return line is a great thing to have but is NOT needed with 255 fuel pump will be great but if you want a real good tune return lines are good to run Static or Rising FPR
::Stg 1 PCM::AEM S.R.I::Hallman MBC::Borla Dual Exhaust::NeedsWing v5 3" DP/Cuttout::Turbonetics Cold Side Pipe w/ Greddy Type S.BOV::Mpx Front Mount Intercooler::Tein-S Springs::AEM EUGO,OIL Pressure,Volts::Apexii TT::AGP SCT Tune::Bwoody Motor Mounts::IP2 CF Hood::Carbon By Design Eyelids & Radiator Shroud::AGP Return Line::AGPBB50trim::RC750cc::Walbro255
Obviously I need a wideband which I will get as well as I'm going back to my [b]stage 1 turbo [/B](U mean pcm right?)and will be upgrading to larger injectors such as 750's(Those are plenty good for 500+hp)or 900's..
1)Are there any real advantages in going with a NEO over the older SAFC.
^ It's a toss up pick one Neo has 16 points Rpm Tuning SAFC 2 has 12 Rpm point's But has 2 maps and is lockable. Neo you will have to write your tunes down on paper and swith back to whatever gas you run manually. Both work great.
^No but you will need a Msd tach driver to run the SAFC NEO/Safc2
^No point It's up to you but it makes it easy on the tuner total option.
^Yes
B&B Exhaust no cat
AEM intake
Motor Mounts
HKS blow off
MSD Wires
NGK Plugs
Didn't you make a thread that was almost the same as this one I think I posted in it?
Anyway good luck on your beast just make sure you look in the tuning section read everthing and read about Kr and keep it safe.
Sean
A853 Crew (ONLY UNO)
Starting all over from stock
Mods Now04 Silver Wilwood slotted BBK slotted,slotted Rear,Windage tray+crank scraper,Dcr power shift2 clutch,Bwoody Motor mounts+trany,Stock air box mod+K&N drop in,F&F Ported ex.Manifold,3" o2 housing,My catch can+check valve,Safc Neo,Agp waste gate + ptp spring,Agp uhp,lower
^ Coming Maxed Stocker WORLD RECORD 08
Does anybody by chance have a afc neo tune for just 91 pump gas all i need is one for 16 pounds cause im tryin to keep the stock clutch for as long as possible, thanks
2005 ACR
Mods
-agp solid motor mounts, greddy catch can, 3inch turbo back exhaust, ATP Turbo Uppipe, hks BOV, catless downpipe, ATP Turbo 57 trim v-band turbo, walbro 255 fuel pump, RC 750cc injectors, AFC neo, exhaust depot big front mount
2005 ACR
Mods
I have one tuned for BB50trim 22psi lol on stock clutch
