Old 05-10-2007, 09:35 AM   #61 (permalink)
UsmcSrt4's Avatar
Member Number: 39607
Mods
Screamin Demon Coil,MSD 8.5mm Wires,NGK Plugs,Tein S-Techs,ACT 6 Puck,Boomba Fuel Rail,750cc Injectors,Turbo XS Type RFL BOV,AGP FMIC,AGP Polished Catchcan, 3" Turbo Back Exhaust,ATP UHP,Aeromotive Fuel Return w/ FPR,160 degree thermostat,AFC Neo,Polished AGP GT3076R Kit - Best run 12.9 (untuned and bad night) Tein S-Techs http://www.cardomain.com/ride/2578807
UsmcSrt4 is offline   Reply With Quote
Old 05-10-2007, 09:46 AM   #62 (permalink)
UsmcSrt4's Avatar
sits perfectly, just lift up the dash a tad bit, wedge it in there and let the dash hold it in place, mine hasnt budged at all. hope this helps
Old 05-10-2007, 04:16 PM   #63 (permalink)
Member Number: 31907
Quote: Originally Posted by UsmcSrt4
nice is it a just snug fir or a real tight push on it i am scared to hurt my neo lol
and i see the buttons are oin the left is there a feature to flip the display so yo can mount in any positoin or somerthing?
*2005 SRT-4
MODS:
Mopar 3 inch cold air intake
Fade's '05 TIP Mod
apexi neo fuel controller(tuned by topspeed of atlanta thanks)
msd 8.5 plug wires
slow boy racing wga (16 psi)
Greddy catch can
Greddy turbo timer
Custom 3' side exit exhuast
Prosport boost gauge
8000k quick whips hid kit
numbers as of 5/16/07
265hp and 273trq
SRT4Badboi is offline   Reply With Quote
Old 05-10-2007, 05:37 PM   #64 (permalink)
Member Number: 30237
my numbers on the sensor check are much different than on the one that was posted earlier. Car seems to be running ok but not sure what that means.
-06 300C SRT8
-05 SRT-4 - Hahn 20G, AFC Neo, 750cc, CTI FMIC, 3'' CTI TBE, Maddog STS, ATP UPP, HKS SSQ BOV, Stage 1 - sold
-03 Supercharged S2000 - 310rwhp - sold
sirrach is offline   Reply With Quote
Old 05-11-2007, 09:23 AM   #65 (permalink)
UsmcSrt4's Avatar
its not tight, its nice n snug, i can manipulate the neo easy as shyt. if i need to take it out, just grab and pull, it wont hurt the neo. like i said just lift up your dash just to the right of the boost gauge, slide the neo in and lay the dash down. looks good and people can see it from the back
and you can switch the buttons. forget what exactly you go into though cuz i havent messed with it in a bit, but you can have the buttons on the right or the left.
Old 05-11-2007, 09:42 AM   #66 (permalink)
manny z's Avatar
Member Number: 759
Trader Rating: (18)
Default problem
Quote: Originally Posted by KBizzle
are you pulling any fuel yet? or is correction off? what are your hi/lo throttle pts set at? just quickies, lemme think a lil more for a solution.
EDIT: also, did you seperate the WHITE wire and GRAY wire when you wired into the MAP wire? you should have at least an inch between em.
No, I am not pulling fuel I am still at no correction. Lo is 10%, High is 40% the gray wire is about an inch from the white. I can move it down some more, have people had a problem from them being to close?
ok, I moved it and it still has the same problem, I am getting worried now
Go back to your menu, and make sure your sensor setting is on PRESSURE!! I accidently move mine once, and it took me hours to figure out why it was running like shit.
manny z is offline   Reply With Quote
Old 05-11-2007, 06:28 PM   #67 (permalink)
and also did you extend the wires with soem more wire so you can put it there or no and where did you route it again? pics??? sorry for all the weird ?'s
Old 05-12-2007, 07:53 AM   #68 (permalink)
UsmcSrt4's Avatar
no i did not extend the wires at all. its routed through the fireall like any other thing needing to go to the cabin.
Old 05-12-2007, 07:59 AM   #69 (permalink)
UsmcSrt4's Avatar
just another one i had.
Old 05-12-2007, 06:06 PM   #70 (permalink)
cause i am looking at the harness and it dont seem like it would go al the way where you need some of the wires to go lol
Old 05-13-2007, 02:07 PM   #71 (permalink)
UsmcSrt4's Avatar
it did, promise ya
Old 05-13-2007, 11:08 PM   #72 (permalink)
how do yo put it on pressure go to the place where it is at and click next then next again or is there certian settings
oh yeah i put mine on pressure and it runs like crap
Old 05-15-2007, 05:44 PM   #73 (permalink)
UsmcSrt4's Avatar
if anyone can, and im SORRY about this, but i left my manual in Florida and i wont be back there for a bit, can enyone explain the percentage i see when set on pressure in the monitor mode? sorry about the no0b question lol
Old 06-06-2007, 05:44 PM   #74 (permalink)
SRT4R's Avatar
Member Number: 35481
Thumbs up
Wow... This NEO look HOT! Easy to use... It's a must to have!
Thanks for the awesome pic's...
SRT4R is offline   Reply With Quote
Old 06-11-2007, 09:13 PM   #75 (permalink)
newhaircut's Avatar
Member Number: 28722
Here is my Neo install location. I like it because it's not in public view. So if some one is looking into your car (to steal crap) they can't see it.
Up Close:
Dash:
More Dash:
SALVATION HAS A HIGH PRICE:
HOWEVER, for YOU, It's FREE!
Isaiah 53:6
Mods: PTP SST V2 Turbo, PnP Exhaust Manifold, Stage 2 w/o, AGP Race FMIC, S-AFC Neo, Cooling Mist W/I, Walbro 255, PTP FPR, Maxx Fab 3" O2, PTP 55mm TB, AGP WGA, Mopar Exhaust, Needswings V6 DP w/McCord, AEM UEGO, Aeroforce Interceptor Pro, ATP UPP, Greddy RS BOV, 80% STS w/Bushing, MBC.
newhaircut is offline   Reply With Quote
