Ok, so I noticed a lot of people were having trouble with these things, so here is some help....
1.
The wiring is exactly the same as the SAFC II
2. You will have lots of extra wires left over, its for vtec control, you do not need them so tie them off
3. Follow the pictures below to help setup the workings of the unit
4.
If you are S0, most throw a P1187 CEL I am still searching for a fix....
5. If you need help, pm me....
Ok first things first.... this should be self explanitory.... VTEC should stay where it belongs.... on Hondas, so this setting is supposed to be OFF
This is Easy/Pro mode choice.... Pro mode gives your more points to map your A/F, so go with that.... unless you like having the fewer points
Cylinders = 4 and Throttle setting pointing Northeast
Sensor select should be on Pressure
Your analog readings max... you can choose the numbers, this works best for me RPM at 8000 because the next lowest is at 6000.... Correction at +/- 15% and pressure at 200
This is where you can customize the colors, brightness, angle, and if you want a screen saver or not....
my buttons are on the left so my screen is set for left... if your buttons are on the right, it should be set to right
Here is where you choose your throttle Volts.... car must be running to set this.... first you would let the car idle and hit ok where this screen is.... when it says throttle full OPEN you rev the car to full throttle (probably best on a dyno, sitting in your driveway is going to scare your neighbors) you dont have to do this for the car to run fine.... but if you do, it will let you set a throttle warning... and maybe other stuff (I am too scared to do it in my driveway)
Here is where you change your A/F map... hit the ok button to go between the RPM, High, and Low settings.... you have to be sitting on at least the first Ne point to switch between the three... hit the up or down button to change the numbers
Here is when you press the down button before being on the first Ne point, you can turn correction off, in case you dont have it tuned yet, or if the weather changes dramatically and you want to drive it home without it pulling fuel
This is an example of a fuel map graph... it shows how your fuel is set to be pulled on the car
Here is where you set the % throttle for the settings to kick in... anything between high and low will be rounded out between the two maps
Here is where you can check to make sure its hooked up right, if all the sensors are reading, its ok
This is the version number and stuff
This screen is bad, don't initialize unless you screwed up and need to reset the AFC Neo....
