Old 04-17-2007, 08:13 PM   #781 (permalink)
tinctorus's Avatar
Member Number: 30504
Trader Rating: (42)
ok so i jsut initialized it and it seems to be running ok but my in out points are at 1 which is where it goes to after you do that
However when i tried to put them to 10 in 10 out the car just bogs down and shuts off then i throw p0108 and p2074 so i guess i have to just leave it at what it is after initialization because like that the car seems to run ok
Quote: Originally Posted by Tex
india not arab. think himiny-bimminy not alalalalalalala
tinctorus is offline   Reply With Quote
Old 04-17-2007, 08:18 PM   #782 (permalink)
goats srt's Avatar
Member Number: 47689
hurry up and figured it out so u can help me when i get one
Old 04-17-2007, 08:59 PM   #783 (permalink)
Network13's Avatar
Member Number: 36188
Trader Rating: (42)
I got P2074 long b4 I installed the SAFC. I started getting it when I installed my 60mm TB.
Guess again my foreign friend,
American Muscle will DO You IN!
South Florida SRT Owners Club
http://www.floridasrtoc.com/
Network13 is offline   Reply With Quote
Old 04-18-2007, 08:33 AM   #784 (permalink)
KBizzle's Avatar
Member Number: 30144
are you changing those points with the car running? if you are that would explain it, change them with the car not running....
KBizzle is offline   Reply With Quote
Old 04-18-2007, 08:38 AM   #785 (permalink)
KBizzle's Avatar
Old 04-18-2007, 02:38 PM   #786 (permalink)
tinctorus's Avatar
Trader Rating: (42)
actually yes i was trying to change them with the car running i didnt know it made a difference i figured you could change anything on the fly but i guess not
i have a buddy thats familiar with it coming over tonight to help me look at it and go over everything with me so hopefully i will get everything squared away
Old 04-18-2007, 02:39 PM   #787 (permalink)
tinctorus's Avatar
Trader Rating: (42)
Lol i can do the wiring for it thats no problem at all but your on your own as far as using and tuning it goes man
Old 04-18-2007, 07:24 PM   #788 (permalink)
ToMuchBoost's Avatar
Member Number: 35620
Trader Rating: (69)
Anyone know how to set the SFAC up for HI and LO boost setting, but so you don't have to switch file maps?
I thought I'd be able to use the TH-Point because its ref to boost (map)... Set it for say 79% LO (thought it was anything below this would be lo fuel map), and 80% HI fuel map. But it always seems to use the HI map.
Figured 79% should = about 17psi on a 2 bar map
My low boost is 15psi
My HI boost is 23psi
Stage 2 car
FYC Racing
Build Thread Here
ToMuchBoost is offline   Reply With Quote
Old 04-18-2007, 11:36 PM   #789 (permalink)
Turbocruiser13's Avatar
Member Number: 42620
Trader Rating: (21)
Not sure exactly how to answer your direct question, but I do know that if your hi boost is 23 you can see 17 or even more with much less than 79% throttle so that may be why it's kicking it off like that. I wouldn't know why it would use the hi settings with anything less though. You may want to have a buddy ride shotgun and watch the boost to find out exactly when you're going into hi mode and see if it matches up with your boost.
Edit: After rereading your post it seems like some people were having issues with their hi and low points being so close. Try putting your low down to say 55% and keep your high at 80% and see if that helps then anything in the middle and the controller will compensate for it by mixing your hi and low points together
O4 PT Cruiser non GT
Stock b****es, come get me
SoCal's fastest PT Cruiser
Turbocruiser13 is offline   Reply With Quote
Old 04-18-2007, 11:43 PM   #790 (permalink)
Trader Rating: (69)
I'll try that, LO has to be at least 73% (that = 16psi on the 3bar map) I'll turn the HI up to 90%.
I know for sure what my boost is for both lo and hi settings on the boost controler (have aeroforce and a elec boost gauge).
Thanks,
Old 04-19-2007, 04:45 PM   #791 (permalink)
tinctorus's Avatar
Trader Rating: (42)
does anyone know if you can change it from reading the pressure as hg and instead make it read psi??? or did the little china men leave it like that to make us feel dumb
Old 04-20-2007, 10:45 PM   #792 (permalink)
tinctorus's Avatar
Trader Rating: (42)
for an answer to a simple question
Old 04-21-2007, 12:23 AM   #793 (permalink)
beyondspexj's Avatar
Member Number: 30264
Trader Rating: (30)
think the china man wants you to feel dumb
Old 04-21-2007, 01:12 PM   #794 (permalink)
Network13's Avatar
Trader Rating: (42)
I just went through the instructions and it does not say anything about being able to display psi.
Old 04-22-2007, 11:12 AM   #795 (permalink)
Eagle-TSI's Avatar
Member Number: 31753
Default Mistake
I don't know if this has been note before but :
GROUND -
Brown wire & Black wire (afc)--- pin 18 on module C1 (black/white wire) the brown wire should be T'd closer to the PCM.
Point is that PIN 18 isn't "black/White" wire, but "Black/Tan". On the other hand, there IS a "black/White" wire on PIN 9.
BTW if anyone can help I'm still have BIG TIME troubles with my installation :
http://www.srtforums.com/forums/show...46#post4704746
Thanks
Eagle-TSI is offline   Reply With Quote
