Old 03-18-2007, 11:57 PM   #766 (permalink)
Member Number: 52249
Alright! I'll go through it again in the morning and hopefully get this little issue settled so i can atleast drive the car and break this turbo in and get to some tuning! THANX 4 da help man! i appreciate it!
RPMSRT4 is offline   Reply With Quote
Old 03-19-2007, 05:18 PM   #767 (permalink)
ALRIGHT! I need some major help here! I re-wired the SAFC-2 and soldered it and everything and checked all connections inside the car and all is good. The darn thing still reads 84%-90% before and during idle! All other systems like rpm throttle and everything right on the money except that! What else could it possibly be?
Old 03-19-2007, 09:27 PM   #768 (permalink)
beyondspexj's Avatar
Member Number: 30264
Trader Rating: (30)
what are your settings??
Old 03-21-2007, 02:38 PM   #769 (permalink)
i'm 10in/10out! low throttle 49% and high 50% which was set on stock turbo set up and haven't touched it. in lo i'm minus 45% across the board and air fuel ratios are fine when driving. also found out my map sensor took a dump. i unplugged it and the car started to run just fine! haven't try to tune on boost till i get this situtated!
Old 03-21-2007, 03:03 PM   #770 (permalink)
Trader Rating: (30)
Haha good job finding it. You should be able to find one from someone who got a stage 2 or 3 upgrade
Old 03-22-2007, 06:00 PM   #771 (permalink)
Sportingsrt4s's Avatar
Member Number: 52114
ne one with this installd ( that installed and tuned themselves or atleast installed and has it working correctly ) in the nebraska area? columbus, nebraska is where im at and would like to have some one experienced with this unit help me with my install... not new to cars just like to have some one experienced help me since this is a important device and i dont want it or the car to go boom! :P
Sportingsrt4s is offline   Reply With Quote
Old 03-22-2007, 08:37 PM   #772 (permalink)
just in luck! found a map sensor at the junk yard and everything is peachy now! thanx 4 da help though!
Old 03-29-2007, 10:12 PM   #773 (permalink)
Member Number: 52598
dose the regular neopn use the same map sensor
Craz1000 is offline   Reply With Quote
Old 03-30-2007, 01:06 AM   #774 (permalink)
Trader Rating: (30)
selling mine if anyone is interested.
Old 03-31-2007, 10:37 AM   #775 (permalink)
do u have a tach adapter? if so id be interested in buying that from u. pm if u'll sell it seperatly
04 srt4~mopar sts~mopar stage 2 w/o toys~mopar bov plate~cca bfmic~BC coilover struts~agp hardpipes + tbolt clamps + blitz bov(upp and bov in box still)~Greddy turbo timer~K&n typhoon cai~Agp dog bones~clear corners~Fan switch mod~$20 catch can~3" downpipe~3" MPx o2 housing~Bwoody hbrace and traction bars~
Old 03-31-2007, 11:17 AM   #776 (permalink)
Trader Rating: (30)
no i dont have one. sorry.
Old 04-10-2007, 06:21 PM   #777 (permalink)
Member Number: 37321
i have a question for u guys. do any of u guys have a large throttle body and a safc and are having problems under certain loads with stage 2 computer?
stinky2004 is offline   Reply With Quote
Old 04-12-2007, 08:32 PM   #778 (permalink)
goats srt's Avatar
Member Number: 47689
nice write up
Old 04-16-2007, 01:24 AM   #779 (permalink)
SRTainly's Avatar
Member Number: 36792
Trader Rating: (15)
I am seeing people who are at -33 to -39 fuel on the top end.....isn't that advancing the timing WAY past acceptable limits? Pull fuel=advance timing=bad news. Shouldn't you try to adjust fuel with the return line and fpr to the point that you pull as little fuel as possible? Ideal would be able to adjust fuel with the fpr and return line and never even need a fuel controller.....but since you will be too rich at lower rpms you need it to pull fuel then. I currently am boosting 20psi on a Garrett .50 trim setup with return line, adjustable fpr, and 650cc's...I have to pull 0 at top end, only between about 3500 and 5000 rpm's. If this sounds wrong please let me know, but we had one of our guys blow his engine at -20 because the advanced timing caused detonation and broke one of the ring lands!
I think it's stock.......
SRTainly is offline   Reply With Quote
Old 04-17-2007, 11:58 AM   #780 (permalink)
tinctorus's Avatar
Member Number: 30504
Trader Rating: (42)
can any one help me out i just installed this and i dont want it to pull any fuel at the moment i just want my car to run like it did before i put this in until i can get to a dyno im not understanding any of the settings
Quote: Originally Posted by Tex
india not arab. think himiny-bimminy not alalalalalalala
tinctorus is online now   Reply With Quote
» Search Used Cars
