First E-blue in Fort walton beach, Navarre, Pensacola area!!!!! Stage 1 upgrade. 3inch downpipe with dump cutout, lowered with TEIN suspension, psi-fi new billet bone motormounts upper and lower, AEM intake, AGP wastegate actuator, CCA FMIC, plug mod, 18psi to redline, ED hardpipes cold and hot with Greddy Type S BOV, Walbro 255lph fuel pump, Greddy turbo timer, Greddy Profec B spec2, Apexi SAFCII, flux capacitor, and a pimp driving it!!!!!!
you need a tach driver to get a good rpm signal...then you do the knock sensor test with the low rpm and higher rpm...set it and then check to see if the x goes away when you access the knock sensor screen. I did it a couple of times and haven't seen the x at all, but it seems to be working...
i just called moder performance to order the 8913 tach adapter so i could hook up my safc and they said msd discontinued that part and they dont carry them anymore. he also said that the tach adapter shouldnt be needed to hookup the sacf. what am i suppose to do?
I stole the line but its how I do Things. "If it aint broke, fix it till it is."
My SAFC is on the way from Ebay as we speak and for a great price of 265 BTW. Gotta get a Tach Adapter next. I've read over the install and it sounds fairly straight forward. And I'm sure it comes with instructions (hopefurry in ingrish) for set up but I was hoping for a general rundown of initial operation and collection of the data and adjustments from that data. How does the SAFC collect/report 02 voltage data or some other means of AFR info? My idle is crappy with the STG 2 injectors and thats my first goal is to even that out. Also how does everyone like the knock feature and at what AFR,02 voltage, or temp does the SAFC indicate knock. I'm really anxious as to the limit of the W/I and making more safe(?) power
Thanks,
Powered by Mopar Stage 1/3 Hybrid.
Cincinnati's next SRT's in the 11's
when installing this.
should i splice in to the wires or cut then add??also my fing tack driver is water loged and fried, so i have to wait 2 weeks for a new one, so, can i use the exsiting tach wire?? apexi sai i could, but i dont know the wire....
I'm pretty sure that the SAFC II reads teh map signal/voltage and adjusts fuel based on teh signals it gets from teh map sensor and alters it before it gets to the ecu...you must set the SAFC II to read PRESSURE in the settings menu...
