Could anyone around Columbia, SC do this for me? I've been thinking about this mod for awhile and thinkin it might be good. Got some questions, though.
1. If I'm planning on gettin the S2 in a little while, will it do anything?
2. If I did the return line/fuel pump, how do I get the ecu to recognize it can run higher fuel pressure?
3. If I can only cut fuel pressure w/ the S-AFC II, how can I raise it? I understand how this can help w/ tuning a fuel system for optimal performance, but there is no need to turn it down until I am capable of running higher pressure than stock.
Praying for HemiDakota, hang in there! MODS:Stage 2 w/ toys, BDJ's 3" side exit exhaust, Maxxfab 3" O2 housing, PTP WGA (19-16 until I get an FMIC), Psi-fi CAI, Mopar sway bars, Psi-fi LCA's, Prothane MM inserts, MPx MM bolts, Mopar BOV, $20 catch can, Mopar STS w/ Boogers, T-Bolts, PTP checkvalve and heatshield Wish List: MSD wires, FMIC, DCR oil mod, larger TB, w/i, fix my boost leaks and lean the car out a bit!
I just figured since there are plenty of Apex~i SAFC owners out there and many are new to it, this thread might be useful for the SAFC Veteran users to help others.
help with:
Install
set up
SAFC to Vehicle connection
Tuning
and everything else having to do with the Apex~i SAFC(II)
please try to keep this thread only "Apex~i SAFC (II)"
I should really put this in the how to section - PAP
Heres how to wire it up:
SAFC
Your going to need a tach driver to get a good rpm signal.
POWER- Redwire (afc)---pin 11 on module C1 (dark blue/red wire)
RPM- Green wire (afc)---tach driver (should be the gray wire)
GROUND- Brown wire & Black wire (afc)---pin 18 on module C1 (black/tan wire) the brown wire should be T'd closer to the PCM.
THROTTLE POSITION SIGNAL- Gray wire (acf)---pin 21 on module C2 (orange/dark blue wire)
MAP SIGNAL- yellow white wire output signal (afc)---pin 23 on module c2 leading to PCM (dark green/red wire)
white wire input signal (afc)---pin 23 on module c2 coming from motor (dark green/red wire)
The C1 module is the bottom connector going to PCM
The C2 module is the middle connector going to PCM
I would also recomend using the MAP signal as a reference in lieu of the throttle position sensor. So, the boost tells the AFC when to go into the high and low setting. Just be sure to refrence the signal before you modify it.
Man, ive been searching for a while for an answer of the SAFC install... but, there a problem that i just recently heard... maybe anyone can help... to my understanding, i was told that i needed to use a wideband O2 for proper usage of the SAFC. also, an A/F guage. are these statements true?
Thnx, Bro
Sgt. Rivera
US ARMY Aviation
your tuning should be done on a dyno to get your Air Fuel Ratio good. or buy a wideband gauge/controller to do your own tuning.
BUT, I DONT KNOW ANY DYNO SHOPS HERE IN GERMANY... 2ND IM NEW AT TUNING CARS, EFI, DYNO USE, ECT.... IM A MECHANIC... GUESS I GOTTA WAIT TILL I HIT DA STATES
thanks for the replys NIVO and Toyoguru!! list of mods:
stage 1
BDJ's 3" CAI
HP T3/T4 turbo kit
HP 3" turbo back exhaust
Greddy profec b spec II
Apex SAFC II
Other mods listed below:
I'm hoping Tiny from Psi fi can sell me his injectors really soon and then all I need is a pump....in wanting to run 20psi+ will I need a map clamp along with the SAFC??
I had been thinking about this question for a while, and maybe it will help others out.
At what point should the SAFCII be used? Should there be a platform of other mods (ie S1 or 2, etc.) first? Or is is pretty much not needed until a larger turbo setup?
I have been considering buying one, but have been holding off on it because I think money could be better spent elsewhere until I go large turbo.
I wouldn't worry about the SAFCII until you go w/a bigger turbo or nitrous....I'd recommend getting S1/2 or even better a greddy profec b EBC as the low boost and high boost settings are invaluable for gaining the much needed traction in 1st and 2nd gears which our cars lack...IMO of course!
can some one please post there settings so i can tune mine a little bit as you can see the mods i have in my sig below .
thanks
04 SRT-4 Flame Red Of Course ! AGP 3" CAI , Kenetic WGA , Motor Mount Inserts , Greddy TT , TWM STS , Blood Red VC , Hand Made oil catch can , Fan swich mod .
settings depend on what mods you have done to your car...our cars run rich till about 18lbs...I've had every mod possible on the stock turbo, w/no fuel management and was at a pretty good A/F mixture of 12.2-12.5:1 on the dyno.
Stock 03 PCM , SG 1 Injector , Dasmopar Map Clamp
Custom Made/Setup Boost Controller System
Custom Made Short Air Intake , MSD 8.5mm Wires
Custom MM Inserts , STS/W Delrin Bushing
Water Injection System ( Dual Nozzle Set Up )
Rims 7.5'' x 17'' / Tires 225/45/17
does anybody know How to tell if the knock sensor is working on the SAFC, I hooked the wire up like its suppose to, or do I need the tach adapter so it would work with the RPM signal???
First E-blue in Fort walton beach, Navarre, Pensacola area!!!!! Stage 1 upgrade. 3inch downpipe with dump cutout, lowered with TEIN suspension, psi-fi new billet bone motormounts upper and lower, AEM intake, AGP wastegate actuator, CCA FMIC, plug mod, 18psi to redline, ED hardpipes cold and hot with Greddy Type S BOV, Walbro 255lph fuel pump, Greddy turbo timer, Greddy Profec B spec2, Apexi SAFCII, flux capacitor, and a pimp driving it!!!!!!
