Old 05-25-2004, 05:40 PM   #16 (permalink)
Member Number: 6185
The SAFC will work..I installed and tuned the one in Nsanesrts car....the only thing you will need to buy is a tach adaptor..we used an MSD unit. Have fun finding a way to run the wiring in the car without drilling holes....I ended up extending the wiring harness a few feet so that it could be placed exactly where we wanted it..and still allow enough wire to hold and tune in the pass seat. Also...Im hoping you are wanting to use the SAFC to take fuel out..because attempting to add fuel will cause the ecu to throw codes and make life really hard on you..
For the car to hold boost up top, you are going to have to adjust the wga...hook the rage up with no boost controller...then adjust it to hold the boost level you wish to run up top [say 17psi or so]..then use the boost controller to allow more boost/faster spool off the line [can we say no traction]...
I just tuned the wga in for 17psi up top...it will gradually build to 19psi and slowly go down to 17psi near the shift point...[once the new agp wga gets here..get to tune it again].
If you dont know what you are doing...Keep the car stock
11.478@120.58mph on the stock turbo, intercooler, head, cams, intake manifold, intake, throttlebody, exhaust manifold, etc and making 391hp 482lb/ft torque... :
"Vtec- All the lag, none of the turbo, like waiting for bad sex"
Religion is a bandage created by man to help heal a soul wounded by circumstance.
toyoguru is offline   Reply With Quote
Old 05-26-2004, 03:33 PM   #17 (permalink)
wild04SRT's Avatar
Member Number: 4825
Default APEXI S-AFC help
i need someone to help me with options on the AFC this thing is confusing the hell out of me
boost and lots of juice
wild04SRT is offline   Reply With Quote
Old 05-26-2004, 03:56 PM   #18 (permalink)
Member Number: 6185
what exactly are you having problems with?
Old 05-26-2004, 08:26 PM   #19 (permalink)
wild04SRT's Avatar
Member Number: 4825
does anyone have this in there car can you pm me so i can ask details
Old 05-26-2004, 08:27 PM   #20 (permalink)
Member Number: 6185
I installed it..I tuned it..What do you want to know...
AIM flxdacat22
YIM felix225
Old 05-28-2004, 07:38 AM   #21 (permalink)
SRTforums Nazi Admin
NIVO88T's Avatar
Member Number: 1109
cleaned up this thread, renamed it and made it a sticky. this should clean this forum of the multiple SAFC threads.
Own a Rear Wheel Drive Nissan/Datsun or Infiniti?
www.RWDNissan.com
SRTGURL's SRT-4 SIte:
www.srtgurl.com
Old 05-30-2004, 07:30 PM   #22 (permalink)
Member Number: 9054
wondering if anyone can post their safc map, high low throttle positions and ne points.... maybe with the stage 1?
-shahul
ShahulX is offline   Reply With Quote
Old 05-30-2004, 11:08 PM   #23 (permalink)
Member Number: 6185
Ill take a note of where I have the NE points on nsanesrts car next time I get a chance...However, I hope that noone posts thier actual tune...and if anyone does..I hope noone else uses it...as EVERY car will be different..including two stock cars. This isnt something you just guess and play with. Improperly tuned, and you WILL screw something up. Basics such as Hi and lo throttle points and NE points are fine..as they will help you get a baseline for being able to do fine adjustments later on. Tuning should be accomplished with nothing less than a Wideband...You MIGHT be able to do SMALL adjustment utilizing the factory o2 sensor readings, however, I would highly advise against it.
Old 05-31-2004, 11:51 AM   #24 (permalink)
RoostBoost's Avatar
Member Number: 7368
Trader Rating: (72)
why would the SAFC cause the ecu to throw codes when trying to add fuel??....When I try to boost over 17lbs in 3rd,4th,or 5th gear my car will hit a fuel cut, jerk forward, throw a check engine light and prevent me from boosting w/out some serious jerking and studder. Once I disconnect the neg. battery terminal the light goes away and I can boost again, but only to 14psi or less....
RoostBoost is offline   Reply With Quote
Old 05-31-2004, 05:46 PM   #25 (permalink)
NIVO88T's Avatar
Member Number: 1109
do you have a return line?
the AFC will work best on the car if you have one so you can run higher fuel pressure while on boost and then trim the fuel out with the SAFC (this lowers the voltage the pcm sees and thus keeps you from hitting fuel cut) it does get complicated to explain but if you write down on a post your list of mods we can help.
Nice car BTW!
Old 05-31-2004, 06:43 PM   #26 (permalink)
Member Number: 6185
Like NIVO said..the SAFC is better for pulling fuel.. If you attempt to add fuel, the afc is raising the voltage that the computer sees from the MAP [IE..higher boost]...So what happens is when you get higher in the boost the computer will throw the 0108 code [map voltage high output]..and the car will feel like it hit a brick wall....This is the major downfall of the afc...you cant effeciently add fuel..only take it away. So to solve this, you either need to go with a returnline kit, or bigger injectors. Then you use the AFC to pull fuel out and at the same time..this will make the computer see less boost so there is no need for a FCD anymore..
Old 05-31-2004, 11:42 PM   #27 (permalink)
Member Number: 9054
are you all gaining power leaning the fuel out or adding fuel?
-shahul
Old 06-01-2004, 10:59 AM   #28 (permalink)
Member Number: 6185
Power is gained by stabilizing the a/f ratio....depending on what boost you run and what other modifications are done..depends on the target a/f ratio at a given rpm level...For the srt, a nice safe a/f is 11.5:1 or so...When using the safc to tune....usually you have to go a little overkill on the fuel system [bigger injectors, return line kit etc..] and pull out fuel to achieve your goal..Widebands and egt gauges are really nice tuning tools...and I wouldnt attempt to tune without a wideband myself..
Old 06-01-2004, 06:45 PM   #29 (permalink)
Member Number: 9054
aem uego? what are you all using for a wideband? dyno-tune?
-shahul
Old 06-01-2004, 08:14 PM   #30 (permalink)
Member Number: 6185
I use a generic wideband..cost around $315 or so...digital readout..with datalogger outputs..Using this while doing 3rd [for tuning] and 4th gear pulls [to ensure streetability] from 2500 rpm...Ive gotten nsanesrt's car pretty close to dialed in where we want it.
Page generated in 0.22446 seconds with 12 queries
