Old 10-13-2009, 10:31 AM   #1 (permalink)
04boosted's Avatar
Member Number: 61528
Trader Rating: (10)
Default Afr's change 5 months after tune?
I had the car tuned in May of this year, and I had the AFR dialed in at 11.5-11.7 at WOT. I was spiking 20 lbs, not sure what i was holding to redline then. I did a couple pulls recently, and the AFR's are 10.9-11.1 and the boost looks like it is still spiking at 20psi but falling to 15 at redline (stock boost gauge). I have a FM wg, and am on PCM control boost. I did a boost leak check and everything was good. So I'm not sure why things are looking richer, its getting cold out here too, thought that was gonna lean it out a bit.
My mods are: Stage 1 PCM, Hard pipes, HKS BOV, PTP Charge pipe, FM WG, KN CAI, MPX 62mm TB, Agp RL, Mpx 3" TBE, Walboro 255, DTEC FC.
Here is my dyno sheet from last tune:
[/quote]
K&N CAI, MPX BFMIC, AGP hard pipes. HKS SSQV BOV, MSD wires, Stage 1, MPX, 3" turbo back exhaust, Pt performance charge pipe, FM WGA, MPX 62MM TB, AGP RL, Agp Dog bones, AEM Wideband, Dtec FC
304Whp 363LbTQ
04boosted is online now   Reply With Quote
Old 10-13-2009, 08:32 PM   #2 (permalink)
04boosted's Avatar
Trader Rating: (10)
Bump!
Old 10-13-2009, 08:36 PM   #3 (permalink)
COY
COY's Avatar
Member Number: 35663
Trader Rating: (42)
colder air is denser. (is denser a fucking word?) That may explain it. I would reset your ECU and go see checksum if its something that is really bothering you/the car.
Flame= Ignored
PTP = Ignored
Bring back Ekool
COY is offline   Reply With Quote
Old 10-13-2009, 08:38 PM   #4 (permalink)
04boosted's Avatar
Trader Rating: (10)
I understand that, but wouldn't the colder, denser air make the car lean out? I am experiencing a richer wot than before.
Old 10-13-2009, 08:44 PM   #5 (permalink)
CONROY's Avatar
Member Number: 46401
Trader Rating: (124)
colder will make it lean out more.. do a boost leak test?
Pittsburgh Penguins 40-22-4 84 points
CONROY is offline   Reply With Quote
Old 10-13-2009, 08:50 PM   #6 (permalink)
Kason23's Avatar
Member Number: 34502
boost leak... or gauge might be wrong.
Tuned By TDSAaron!!
Now Rocking a Delta 46
Old 10-13-2009, 09:00 PM   #7 (permalink)
04boosted's Avatar
Trader Rating: (10)
Well i did a boost leak test, and nothing. So i guess my next question is: even if the gauge is wrong, wouldn't the AFR's still be roughly the same, regardless of what the gauge was reading? Also my next concern is the DTEC, I am thinking about switching to the DS, because of all the rave about it. I was just wondering if its possible that the DTEC setting could have changed or if the wastegate loosened?
I guess anything is possible, just trying to see if anyone has had the similar problems. Thanks again for the help.
Old 10-13-2009, 09:01 PM   #8 (permalink)
COY
COY's Avatar
Trader Rating: (42)
yeah, I am dumb. Read it fast and then realized I am dumb.
Check the dtec? If boost leak is good try to pull a bit more fuel? Check wastegate. Blown diaphragm?
I would still reset the ecu.
Old 10-13-2009, 09:05 PM   #9 (permalink)
04boosted's Avatar
Trader Rating: (10)
I'm not really sure what to look for on the DTEC if you are talking about the settings, the wiring looks good, I'll reset the PCM, and check out the WG tomorrow.
Thanks again.
Old 10-17-2009, 07:04 PM   #10 (permalink)
Member Number: 64907
i have the same f'in problem to the t and ive checked everything and cant find nething wrong
overboost8 is offline   Reply With Quote
Old 10-17-2009, 07:31 PM   #11 (permalink)
04boosted's Avatar
Trader Rating: (10)
Ive reset the PCM, and nothing changes, if i disconnect the RL I run too lean. like 12.5, so I wonder if the DTEC is not doing its job correctly.
Old 11-14-2009, 11:50 AM   #12 (permalink)
04boosted's Avatar
Trader Rating: (10)
Just an update.. I found my problem, my Fuel pressure regulator was leaking boost at the adjustment screw. So i took apart and fixed that leak. Now everything is running great! I'm stoked that i finally found it! Was driving me crazy.
