Old 01-25-2005, 10:29 PM   #1 (permalink)
Member Number: 13265
Default AFR help
I just wondered if my air/fuel is ok at WOT, it goes from about 11.3-11.5 then near redline it jumps up to 12.1:1, would that be alright, Im running the AGP 50 trim, with walbro 255lph pump at about 14psi on stage 1 injectors.
BrettsSRT4 is offline   Reply With Quote
Old 01-25-2005, 11:15 PM   #2 (permalink)
Member Number: 12302
The numbers are safe numbers. From what i hear, its not safe to be running anything over 12psi, but the 255 seems to be helping with some extra fuel. Just keep your eye on the A/F. Just make sure you really dont see anything higher than 12.5:1 or your gonna run into problems.
SpecJ is offline   Reply With Quote
Old 01-26-2005, 08:39 AM   #3 (permalink)
SRTforums Nazi Admin
NIVO88T's Avatar
Member Number: 1109
12:1 is right where you want it if you are running 93 octane. that's fine.
Old 01-26-2005, 09:49 AM   #4 (permalink)
hydrohopper's Avatar
Member Number: 11900
Trader Rating: (37)
Nivo can you give a quick lesson on how to read A/F readings? Example: What the numbers actually mean, where is the "perfect" AFR that you want to be at, where your danger points are, etc. Thanks.
Mopar Stage 3R with Toys
2004 Flame Red SRT-4
Turbocharged 2.4L DOHC I4 HO
hydrohopper is offline   Reply With Quote
Old 01-26-2005, 02:10 PM   #5 (permalink)
yeah, Im running 94 octane, so I should be alright
Old 01-26-2005, 11:50 PM   #6 (permalink)
Member Number: 5634
Is the perfect A/F ratio the same for all of are cars, or does it change with your modifications?
Stock Turbo vs. Big Turbo have the same sweet spot?
mohillmopar is offline   Reply With Quote
Old 01-27-2005, 01:33 AM   #7 (permalink)
the perfect A/F ratio is different for all cars. Turbo cars, more alike, have a perfect A/F around 12:1 - 12.5:1 where as naturally aspirated cars tend to run much leaner towards stoich in the high 13's even 14's. It really can depend on your setup and what your motor is made out of. A built block would be able to run leaner than a stock block before melting a piston.
Old 01-27-2005, 11:28 AM   #8 (permalink)
Member Number: 5634
12:1 - 12.5:1 is near perfect for any srt-4 right.....Thats what ill shoot for then
P.S. ALWAYS on 91 oct.
I bought it because it's american made
Old 01-27-2005, 12:10 PM   #9 (permalink)
Turbolag87's Avatar
Member Number: 6491
those AFR are not safe for 91, i can see timing/knock being pulled for sure.
F&F Stage III 47lb turbo
Returnline
AGP WGA,
11.40@125mph 26psi and no boost leak
371whp @22 psi pump gas ( With a big ass boost leak)
Turbolag87 is online now   Reply With Quote
Old 01-27-2005, 02:17 PM   #10 (permalink)
Member Number: 5634
How about 11:1 on 91oct?
Old 01-27-2005, 10:11 PM   #11 (permalink)
11.5:1 should be ok on 91. I would invest in water injection kit if you are running 91 octane. This way you can run more boost safer and keep your knock under controll under higher A/F
Page generated in 0.19197 seconds with 13 queries
