Old 01-28-2009, 04:44 PM   #1 (permalink)
04SRTFOUR's Avatar
Member Number: 58292
Default AEM wideband
just got my aem wideband in the mail yesterday and put it on at work everything went smooth. start it up and its a 14.8 which is a good idle but when i end of driving it, it just stays at 14.8 the whole time. today when i started my car it went from 14.8 to 15.0 and basically stayed around there at idle. and when i drove it went back and forth from 14.7 to 8 so its not like its stuck at 14.8 but it wont go any lower then that even if i go WOT. but everything is brand new so i dont see why it wouldnt work. let me kno wat u think thanks.
04 Black'd Out SRT
Mopar CAI/Mopar Stage 2/FB Ported Turbo and Mani/AGP WGA 19 psi/Eibach Springs/3' exhaust to 2.5mopar tips/MM inserts/Turbo XS RFL BOV/Dtec Fuel Controller/AEM Wideband/DC sports strut bar/MSD coil pack & wires/Weapon R catch can/CF Hood/Godspeed BFMIC
04SRTFOUR is offline   Reply With Quote
Old 01-28-2009, 04:48 PM   #2 (permalink)
cbosch's Avatar
Member Number: 57373
Check the connections at the back of the gauge sometimes they come loose, also check all connections down to the sensor. Obviously you are getting power to it so it has nothing to do with that connection. Hope that helps.
Intercooler, HID headlights, Hahn 20g w/Tial 38mm External Gate, aem wideband, afc neo, agp motor mounts, RC 750cc injectors, AEM 3inch intake, hot and cold side hard pipes w/ tial bov, Tein type S springs, Side Exit exhasut
KWB POWERED-CMB DRIVEN
cbosch is offline   Reply With Quote
Old 01-28-2009, 09:34 PM   #3 (permalink)
04SRTFOUR's Avatar
anyone else have any other input?
Old 01-30-2009, 01:59 PM   #4 (permalink)
Member Number: 35913
Trader Rating: (15)
Default mine works fine
1 - where's the o2 sensor placed?
2 - I think there is a dial at the back that could be set to 0-1 volts, which may correspond to your readings - did you get it used?
3 - did you get the full wideband kit? what's the kit #?
4 - did you use a wideband o2 sensor?
TomC3 is offline   Reply With Quote
Old 02-03-2009, 06:20 PM   #5 (permalink)
FallenAngelHIM's Avatar
Member Number: 65943
Glad this thread came up. I'm having the same problem.
I took it to a dyno and their A/F readings of my car changed while the AEM Wideband stayed at 14.8 the whole time even on WOT.
The shop told me I need the gauge calibrated, how does that work?
What is causing the A/F wideband to stay locked in 14.8 the whole time?
"loyalty first, all the bullsh--- second." -Obie Trice
"DON'T STREET RACE. There's nothing to be gained except carnage." -Russ Oasis
Quote: Originally Posted by Wongfu View Post
Well the only thing that failed is you bi or whatever orientation is. Did I ask hey all you gender confused people please come fill my thread with crap?...with that being said go piss off and hump some other dudes leg
Visit my Examiner page for automotive articles.
FallenAngelHIM is offline   Reply With Quote
Old 02-03-2009, 06:27 PM   #6 (permalink)
Silver SRT4's Avatar
Member Number: 17735
Bad sensor possibly, but again I dont own this wideband so we should see if more people can chime in.
SRTs are better than everything ever. period. Car, plane, rocketship, anything. There has never been anything in existance as fast as an SRT-4. Scientists have been considering changing lightspeed to SRT-4 speed, but havent been able to because light cant keep up.
Silver SRT4 is offline   Reply With Quote
Old 02-04-2009, 06:06 PM   #7 (permalink)
lopez's Avatar
Member Number: 21617
Check this out.
http://www.aempower.com/images/produ...%2030-4100.pdf
lopez is offline   Reply With Quote
