Old 06-28-2008, 12:52 PM   #1 (permalink)
srtkid-85's Avatar
Member Number: 56617
Default aem uego hook up!!
ok, i heard that since i have stage 1 and a 3" catless DP i can use the downstream 02 bung for my wideband ,true or false? and if true, is there any down falls from it?having the stock 02 senser just hangin around? or should i spend the 40 bucks to get a 3rd bung welded on? i mean cuz i love takin the easy way out but whats better for my car? thanks u guys, let me know!
srtkid-85 is online now   Reply With Quote
Old 07-01-2008, 11:26 AM   #2 (permalink)
Member Number: 56991
As far as my knowledge goes once you go stage 1+ that it doesn't read your downstream thast why when you go catless on stock stage0 you get check engine. I would say that one is up to you lol. I got all three of mine in there but that because needswings is the bed DP EVER>
::Stg 1 PCM::AEM S.R.I::Hallman MBC::Borla Dual Exhaust::NeedsWing v5 3" DP/Cuttout::Turbonetics Cold Side Pipe w/ Greddy Type S.BOV::Mpx Front Mount Intercooler::Tein-S Springs::AEM EUGO,OIL Pressure,Volts::Apexii TT::AGP SCT Tune::Bwoody Motor Mounts::IP2 CF Hood::Carbon By Design Eyelids & Radiator Shroud::AGP Return Line::AGPBB50trim::RC750cc::Walbro255
RaiedZ is offline   Reply With Quote
Old 07-03-2008, 12:56 PM   #3 (permalink)
srtkid-85's Avatar
still lookin for awnsers? any one know?
Old 07-03-2008, 01:05 PM   #4 (permalink)
rrmike1's Avatar
Member Number: 55729
I zip tied my downstream O2 to the crossmember and used the lower bung for the uego. It's perfectly fine and there are no adverse effects on the car. The sensor may go bad being exposed to the elements, but do you think you'll ever need to replace it??
Stage 2 w/o toys, FBM pnp'd turbo/mani., Rage 55mm T/B, AGP WGA, AGP CAI, MPx 3" O2, Maxxfab 3" DP no-cat, Mopar Exhaust, AEM UEGO, SprayItRacing BOV, Crane 8.5mm wires, Champion RE10pmc5's, 180 thermo, RFR check valve, Prothane race MM inserts, Autometer 30/30, SCT Tuner, Tein H-techs, Proparts dual-gauge pillar, Fuel pump re-wire.
rrmike1 is offline   Reply With Quote
Page generated in 0.13359 seconds with 11 queries
