Old 07-13-2008, 11:37 AM   #1 (permalink)
Member Number: 61750
Default 9.6 AR at WOT Help Please
Just got done with my turbo install GT3076 with return line kit arronneon rc750's 255 pump safc II and I can't seem to get the AR at wot higher than 9.6 my fuel pressure is set at static 40PSI and im pulling 8% in the low and 20% in the high across the board.It will idle at 14.7 all day. Also im at 20PSI. Any Ideas? Thanks
taylor757 is offline   Reply With Quote
Old 07-15-2008, 05:58 AM   #2 (permalink)
SpeedEuphoria's Avatar
Member Number: 30870
Just to clarify, static meaning no vac line on the regulator?
Try going lower on the FP slightly
Project log pics
Old 07-16-2008, 07:20 AM   #3 (permalink)
Yes im running the regulator without the vac line because i was told at 20PSI its not enough power. Also I tired to lower the fuel pressure to 38 and still didnt make a difference. And at idle i even changed the fuel pressure to 25 and my AFR where still 14.7 at idle? Does that mean my regulator is bad.
Old 07-16-2008, 07:22 AM   #4 (permalink)
HCCAFan's Avatar
Member Number: 35768
Trader Rating: (18)
Cat enrichment maybe?
HCCAFan is offline   Reply With Quote
Old 07-16-2008, 07:42 AM   #5 (permalink)
Whats that? Sorry Im still new at this. I dont have a cat and also i have the fouler mod
Old 07-16-2008, 11:10 AM   #6 (permalink)
in closed loop the car will compensate and still go to 14.7, at WOT it will change
Old 07-16-2008, 11:13 AM   #7 (permalink)
NoisufnoC's Avatar
Member Number: 136
same kind of thing happened to me. i couldn't pull enough fuel on the DTEC to get my AFRs in an acceptable range without knocking on pump. I went to SCT flash to fix the problem. You could get smaller injectors
omgz!! i haz mods!!
Old 07-16-2008, 02:56 PM   #8 (permalink)
Thats strange I have a few friends around the area running the same set-up just higher boost and 1:1 with boost source and pulling about 5% to 8%. Is there a way to test the aftermarket fuel pressure regulator or the safc. It seems to be whatever I do its still 9.6 AFR WOT. Also im throwing a P0172 code System Too Rich (Bank 1)
Old 07-18-2008, 08:58 AM   #9 (permalink)
HCCAFan's Avatar
Trader Rating: (18)
If the car thinks the cat is too hot it will dump ass loads of fuel. Has been a motherfucker on my car with stock turbo with a map clamp and now with a 50 trim and SCT tuning. A lot of the SCT guys are talking about having the same problem and turning off the stuff that calculates cat temperature.
Old 07-18-2008, 10:19 AM   #10 (permalink)
rasp's Avatar
Member Number: 56076
I had to pull quite a bit up top running 43psi of static pressure on my RC750s to keep myself in an acceptable A/F ratio at the top of 4th gear. These cars seem to like to dump fuel in that gear up top.
Old 07-18-2008, 10:22 AM   #11 (permalink)
never2muchboost's Avatar
Member Number: 20976
Trader Rating: (47)
are you sure tha afc settings are correct? you should have sensor type set to pressure 10 in 10 out and make sure it is set to 4cyl with the arrow pointing northeast
Email: Jay@N2MB.com
take a moment today to reflect on what happened on 11 september 2001...
Old 07-18-2008, 10:24 AM   #12 (permalink)
Trader Rating: (47)
if the afc was doing it job and removing 20% and you are not running a rising rate on the fpr you should be going dead lean.the pcm will compensate up to 30% in closed loop which is why you are running stoich at idle.
Old 07-18-2008, 10:26 AM   #13 (permalink)
aaronneon@RealTune's Avatar
Member Number: 623
Trader Rating: (398)
Looks like he is bringing the car up to us.
Ill get it sorted out for him.
10.62@133.8 '05 SRT-4 Neon
11.74@120 '08 SRT-4 Caliber
Worlds Quickest/Fastest CSRT-4
Old 07-18-2008, 10:29 AM   #14 (permalink)
$PK$'s Avatar
Member Number: 47676
Sooo, your car is running really rich. Either lower your FP or get smaller injectors. Or raise the boost.
401whp 419wtq on pump gas tuned by Jannetty Racing Enterprise
$PK$ is offline   Reply With Quote
Old 07-18-2008, 11:41 AM   #15 (permalink)
Trader Rating: (47)
well there ya have it.....its as good as fixed now
