Old 07-25-2007, 06:18 PM   #1 (permalink)
Member Number: 46631
Default 6250 rev cut off + no CEL = Stage 1??
Bought my car used. It has all the 3 bar sensors and Stage 2 injectors (checked the part numbers on the injectors). However, there is no "readable" labels on the ECM. What Stage ECM do I have? As the heading says, I get no CEL's and revs cut out at 6250rpm. I always assumed that it was a Stage 2, but now I'm guessing its a Stage 1. The car has a 50 trim set-up with a 3" TBE and I have been boosting up to 20 psi on occasion. Am I correct?
Thanks all -
agp03 is offline   Reply With Quote
Old 07-25-2007, 06:20 PM   #2 (permalink)
Monster's Avatar
Member Number: 48761
Trader Rating: (74)
sounds better than stage 2 to me
DSP + FPGreen 47lb S3 =
www.pt-performance.com
FS:Strapped Block,evo turbo and more..
FS:Axle,Viperseat and more!
Old 07-25-2007, 06:24 PM   #3 (permalink)
Hey ML, what do you mean - Stage 3? I mentioned the 20 psi just to show that it doesn't throw an overboost code. Right now its set at about 13 psi.
Old 07-25-2007, 06:28 PM   #4 (permalink)
goats srt's Avatar
Member Number: 47689
Trader Rating: (23)
is say it is stock due to the fact that a staged pcm revs to 6500 rpm
look in my for sale thread
click here
myfloridasrt
goats srt is online now   Reply With Quote
Old 07-25-2007, 06:32 PM   #5 (permalink)
Member Number: 11681
Trader Rating: (96)
s0---6250
s1---6250
s2---6500
s3---6500
Everybody else is doing it....vote for me http://www.srtforums.com/forums/f389...ml#post8289538
2nd Fastest stock turbo no n2o in the country.
Best 60 1.662
Best 1/8 7.55/93
Best 1/4 11.865/116
Best MPG 28.1 city/33 highway
3147 10.93@128.58 25psi 7.099/103.54
3147 7.26/100 22psi pump full int
Old 07-25-2007, 06:32 PM   #6 (permalink)
Thanks, goats srt, but I believe that only Stage 2 & 3 up the rev cut-off to 6500. That was the first thing that started me thinking - mine didn't do that. Oops, dansrt4 beat me to it! So, Stage 1, then? Stage 0 should throw codes with my set up, I think.
Old 07-25-2007, 06:35 PM   #7 (permalink)
Trader Rating: (96)
depemds on the vac set up if it woudl throw a code on 20psi
Old 07-25-2007, 07:22 PM   #8 (permalink)
What type of vacuum set-up? I never get CEL codes even with TBE.
Old 07-25-2007, 08:08 PM   #9 (permalink)
Trader Rating: (96)
its prolly s1
Old 07-25-2007, 10:49 PM   #10 (permalink)
That's what I am thinking. I forgot to state that there is a "sticker" on it with a hand printed number that matches my vin. So, it probably is a "staged" computer and sounds like Stage 1.
Now, I have another question which I will post separately. Thanks.
Old 07-26-2007, 02:58 PM   #11 (permalink)
Member Number: 40301
It's guaranteed you've got S1 with that sticker you describe and your 6250 rev limit. That sticker will say what stage it is, but that part is usually hidden under the black mounting bracket. You also definately have stock MAP/TIP sensors. If you're running S2 injectors, I'd bet your car is running really rich most of the time, unless you've got a fuel controller you don't have listed.
Chris
Twidget is offline   Reply With Quote
Old 07-26-2007, 03:57 PM   #12 (permalink)
Thanks Chris!
I believe that the 3 bar sensors are for Stage 2 and 3 only.
The WB shows stoich at idle/cruise, and my AFR's are in the tens (just like Mopar intended, apparently) and I get great gas mileage, so??? The car is still a bit of a mystery to me....
I have an SAFC2 but it is zeroed out right now, but that's a story for another thread. Right now, it runs great on the set up that I have - as far as I can tell, but I am not the brightest star in the sky if you know what I mean...
