Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > Regional Forums 1 > Mountain
Old 03-04-2007, 07:54 PM   #1 (permalink)
SRToc Member
zro26t's Avatar
Member Number: 3959
Default What did I do wrong??
I need some help please! I sold my car and I wanted to return it to stock. I took out the Ice-man air intake, Stage 2 computer, injectors, WGA, and the 2 sensors. I put the factory Intercooler back in. I had to leave in the LFS TB that I put in it though. I also took out the DTEC fuel controller and a catch can. I fired it up and it stummbled some then idled out, then the engine light came on. I took it for a drive and as soon as it gets to 3000 rpm it starts stumbling and you have to back off the throttle. The engine light is still on.
I'm not sure what I could have hooked up wrong. Does anyone have a diagram of where the stock vacume lines go. I'm stummped as to what I did wrong, any help would be greatly appreciated.
Thanks,
Brian
Stage 2 W/O Toys, Mopar BOV, Mopar STS, IceMan CAI, Custom MagnaFlow side exit, Magnecore 8.5 wires, MSD ignition coil, Needswings DP w/e-opener and MBC, JMB catch can, LFS 60mm Throttle Body and Manifold adpater, AIS IC, Turbo XS DTEC-fuel computer.
zro26t is offline   Reply With Quote
Old 03-05-2007, 12:06 AM   #2 (permalink)
Nick Chestnut's Avatar
Member Number: 16791
It sounds to me like the D-TEC uninstallation may be the cause of the problem...
First off, what code(s) are you throwing???
Edit: Have you migrated to the new coSRToc site yet?!? If you haven't, you should. That's where all of us are at now...
- Nick Chestnut
* 2004 Dodge SRT-4, GT3076R, SCT Tune, 408 WHP w/o SCT and waiting on new numbers with SCT!
"Don't argue with an idiot. They bring you down to their level and beat you with experience." - Unknown
Nick Chestnut is offline   Reply With Quote
Old 03-05-2007, 12:07 AM   #3 (permalink)
dommo_g's Avatar
Member Number: 20279
I don't know that it'll help, but here it is.
dommo_g is offline   Reply With Quote
Old 03-05-2007, 08:34 AM   #4 (permalink)
SRToc Member
zro26t's Avatar
Member Number: 3959
Thanks Dommo, I'm cross eyed now lol! I'll have to check that. I'm stummped, it sputters a little but when you get to 3K rpm it's not a happy camper at all.
Old 03-05-2007, 08:46 AM   #5 (permalink)
SRToc Member
zro26t's Avatar
Member Number: 3959
I'm getting P0108 Manifold Absolute Pressure (MAP) Sensor Circuit High Voltage ??? What do I need to do to fix it?
Old 03-05-2007, 08:57 AM   #6 (permalink)
98srt2dr.'s Avatar
Member Number: 36661
Trader Rating: (37)
i had to put a new map sensor in to get rid of that code, its happened twice on my car
98 neon-
11.90@117 on stock turbo, slicks, and spray
12.0@121 on 50 trim, pump gas, and street tires
99 neon- sold
04 srt-4- daily driver, CAI, Solid upper mount
98srt2dr. is offline   Reply With Quote
Old 03-05-2007, 09:00 AM   #7 (permalink)
SRToc Member
zro26t's Avatar
Member Number: 3959
Was it something the dealer had in stock or did you have to order it? How much was it. I'm trying to fix it in a hurry because I traded it in last Friday and the dealer was nice enough to let me keep it and take all my stuff out. But I need to get it them as soon as possible.
Old 03-05-2007, 09:35 AM   #8 (permalink)
98srt2dr.'s Avatar
Trader Rating: (37)
i think they had it in stock, $80ish i think
Old 03-05-2007, 09:41 AM   #9 (permalink)
khock3's Avatar
Member Number: 39741
I agree w/ nick, sounds like something went wrong with the dtec unistallation. I threw the same code when I installed my dtec and I just had two wires mixed up.
khock3 is offline   Reply With Quote
Old 03-05-2007, 09:46 AM   #10 (permalink)
SRToc Member
zro26t's Avatar
Member Number: 3959
How did you uninstall yours? I figured since all the wires were just tapped into the factory harness that all I needed to do was cut them close to the harness and tape the ends up. I didn't do the install so I'm not sure how it's all done but I do know that's how the wires were connected.
Thanks for all the advice everyone. I really do appreciate it. I have like 2 days to get this figured out before the dealership starts screaming for the car.
Old 03-05-2007, 10:21 AM   #11 (permalink)
There's your problem. The MAP wire must be CUT in two when installing a DTEC or SAFC. It controls fuel by modifying this signal.
Make sure to reconnect the MAP signal wire. If this doesn't correct the problem, let me know.
Edit: The MAP signal wire should be the Dark Green/Red wire in the orange connector at the PCM.
Old 03-05-2007, 10:36 AM   #12 (permalink)
SRToc Member
zro26t's Avatar
Member Number: 3959
Your the man, let me try that. God I hope that's it.
Old 03-05-2007, 11:30 AM   #13 (permalink)
SRToc Member
zro26t's Avatar
Member Number: 3959
Well that was it, thanks so much for the help. I am so relieved now. I'm gonna miss the car and the great people on the forum. Everyone stay safe and keep the rubber side down!
Old 03-05-2007, 01:20 PM   #14 (permalink)
No one said you have to leave the forums... You know you're always welcome here!
Old 03-05-2007, 03:53 PM   #15 (permalink)
SRToc Member
zro26t's Avatar
Member Number: 3959
Oh I won't be leaving the boards, lol! I'll still be on here seeing what's up.
Page generated in 0.30367 seconds with 11 queries
