Depo, a OEM light manufacturer, and the WORLDS largest aftermarket light producer, has designed a new set of headlights for the 03-05 Dodge Neon and 03-05 Dodge SRT4.
This is great news, because we have had great success with this brand, and the quality of lights they produce is very good!
These headlights are a complete replacement for the factory lights, and come preinstalled with new headlight gasket surrounds. These are a direct replacement, and require no cutting, no modification to your car to install.
The low beam is a projector light, that produces a razor sharp light output. The high beam uses a standard reflector. Both low beam and high beam have bulbs preinstalled. You simply connect your factory headlight wiring to these and they will begin working immediately.
Both low beam and high beam use a H7 55 watt bulb.
