Old 11-18-2008, 10:35 PM   #1 (permalink)
rwcjon's Avatar
Member Number: 65689
Question Valve cover gasket replacement
When i took my car to the dodge dealer they said that my valve cover gaket was leaking, and they wanted a crazy amount of money to fix it. Well i didnt find a How to thread on how to replace this but im wondering if it is the same one as this one i found on Neon Canada site.
Replacing Valve Cover Gaskget DOHC - Home
If anyone can help, thanks in advance.
Stage 0
MSD Coil Pack
MSD 8.5 wires
Apexi TT
Injen Short Ram CAI
rwcjon is offline   Reply With Quote
Old 11-18-2008, 10:50 PM   #2 (permalink)
quicky4JR.'s Avatar
Member Number: 43042
Trader Rating: (55)
1. Pull plug wires off the plugs
2. Loosen and take off the 4 10mm bolts holding the coil back on the valve cover
3. Disconnect the hose running to the pcv valve
3. Use a 8mm deep socket and take off the 9 valve cover bolts
4. Life the valve cover off
5. Take off the valve cover seal
6. Replace with the new one. Be sure not to stretch it!
7. Place orange silicon at proper points. Dont know where? use the old gasket for reference as there should be rimnance of silicone left on it.
8. Follow steps in reverse. tighten/torque valve cover bolts to.....
a) Tighten all bolts to 4.5 N·m (40 in. lbs.).
(b) Tighten all bolts to 9.0 N·m (80 in. lbs.).
(c) Tighten all bolts to 12 N·m (105 in. lbs.).
$17.00 for a valve cover gastest and a 5min job.
Quote: Originally Posted by darrell cox View Post
Far better than stock but not as good as Nemos!
Leaders not followers! Paving the way and making it easy for everyone else!
(954)-915-0016
Davie,FL
Dyno tuning, installs, and custom builds
quicky4JR. is offline   Reply With Quote
Old 11-19-2008, 04:21 PM   #3 (permalink)
rwcjon's Avatar
ok i will try it on my day off thanks again for the intructions
Old 11-20-2008, 08:44 AM   #4 (permalink)
quicky4JR.'s Avatar
Trader Rating: (55)
You got it. Anytime
Old 11-20-2008, 10:53 AM   #5 (permalink)
StageSRT4's Avatar
Member Number: 46216
Trader Rating: (102)
there is also 4 round gaskets that go around the spark plug area, but thats usually where they spring a leak.
there is a pattern on how to tighten down. Ill see if my comp will let me upload pic for ya.
246hp 13.2xx@115mph
www.chicagolandsrtclub.com
member #88
StageSRT4 is offline   Reply With Quote
Old 11-20-2008, 10:56 AM   #6 (permalink)
StageSRT4's Avatar
Page generated in 0.14020 seconds with 13 queries
