Old 01-24-2005, 07:20 AM   #151 (permalink)
SRToc Member
hemidakota's Avatar
Member Number: 272
Trader Rating: (15)
PT# 5029302AG - List $229.00 - MPSC $150.70.
Talk to Ted from Mopar Supercenter.
hemidakota is offline   Reply With Quote
Old 01-24-2005, 09:07 AM   #152 (permalink)
SRT4STEVE's Avatar
Member Number: 6032
i changed the plug and the wire already. Still p0304
CAR FOR SALE Black 2004 10k Miles $16.000
SRT4STEVE is offline   Reply With Quote
Old 01-24-2005, 02:03 PM   #153 (permalink)
SRToc Member
hemidakota's Avatar
Member Number: 272
Trader Rating: (15)
Did you remove the intake manifold in the past?
Ok! Try this out.
1. Distilled water in a regular spray bottle.
2. Start engine
3. Spray distilled water between the top edge of the intake manifold and heads. You are looking for any suction sounds.
4. Spray distilled water around both edges (left side and right side) for the same sunction sounds
If you have any sunction sound (sounds like a a quick high whistle tone) then you have a leak. Most likely check around the cylinder #4.
Old 01-24-2005, 02:14 PM   #154 (permalink)
skipdogg's Avatar
Member Number: 18045
Swap the # 1 and # 4 injectors around. See if you pull a P0301.
If you do, its a bad injector. One of mine went bad, and thats the code I pulled.
skipdogg is offline   Reply With Quote
Old 01-24-2005, 03:43 PM   #155 (permalink)
SRT4STEVE's Avatar
Member Number: 6032
very interesting ill have the dealer do that. Car runs fine for the most part seems like the light just stays on.
Old 01-31-2005, 02:12 PM   #156 (permalink)
Member Number: 9728
Saturday- my car started surging randomly, right up to 3k. Thanks to these forums instantly knew what it was. My suspicions were confirmed not 1 hr later when she threw the p0123 code.
Sunday- i pop out my Iceman CAI and return her to stock for the trip to the dealer monday morning.
Monday- Take it into the dealer and tell the service guy that she threw p0123 and its probably a tps sensor or wiring problem. Still no word from the service dept so much for the 15 mintue fix. HEH.
EBlue 04 w/sunroof as of 5/19/04
IcoolerthnU is offline   Reply With Quote
Old 01-31-2005, 02:49 PM   #157 (permalink)
SRT4STEVE's Avatar
Member Number: 6032
i take my car in tommorow for the second time for misfire in number 4.
Old 01-31-2005, 03:12 PM   #158 (permalink)
Member Number: 9728
well the service manager called me. He thinks they should be able to have a new wiring harness tommorrow. Hes go it in stock at another dealer. Hopefully they replace the harness and all goes well tommorrow. *fingers crossed*
Old 02-01-2005, 02:03 AM   #159 (permalink)
StRicTly4boosting's Avatar
Member Number: 17164
Trader Rating: (15)
Have you reseted the computer by disconnecting the negative on the battery.
Mopar Stage 3 w\Toys , Mopar Short Throw Shifter, Agp S3 Wastegate, Agp MotorMounts, Agp Return Fuel line w\ Aeromotive Gauge , Needswings 3inch Downpipe delete cat w\CutOut , Dc-Sports CatBack Exhaust , Mpix Fmic , Jmb Pressure Pipes with Hks SSQ Bov , Walbro 255lmph Fuel Pump , $20Catch Can, , Autometer 30\30 BoostGauge , Mopar Stage 3 Coilovers , Dc-Sports Front Strut Bar , Prothane Bushings on Control Arms
StRicTly4boosting is offline   Reply With Quote
Old 02-01-2005, 02:06 PM   #160 (permalink)
Member Number: 9728
called from the dealership again. The harness he had was of the wrong revision (i half expected that). Hes overnighting the correct one, and he says i'll have the car tommorrow. Here comes day 3... grrrrrr.
Old 02-01-2005, 02:10 PM   #161 (permalink)
SRToc Member
hemidakota's Avatar
Member Number: 272
Trader Rating: (15)
Hmm....the latest revison is 'AF' according to Ted (Mopar Supercenter).
Old 02-01-2005, 02:14 PM   #162 (permalink)
WhiteRob1984's Avatar
Member Number: 12625
Trader Rating: (38)
Sup ya'll. Well since I threw my P0123 code and getting it back from the dealer, all is well. However, now when under heavy boost at low RPM (WOT) the car boggs/hesitates. It's fine around 5 PSI, it's more around 10 PSI. After doing some research on the boards, people have these problems when their plugs or wires go bad. Does this sound right, or do you think it has something to do with what the dealer did when they fixed my TPS problem. You can check a few posts back, I actually typed the paper I got back from the dealership stating what they did when they fixed it...
BTW, I went ahead and ordered some 8.5mm Magnecor wires w/NGK (1 step colder) plugs to hopefully fix the problem. If anyone knows why my car is doing this, please post. Thanks!
Here's what they did verbatim off the paper I got back after they fixed my TPS problem (instead of going back pages, I just quoted it here):
Quote: Originally Posted by WhiteRob1984
Well I got my car back and everything is fine now. Normal boost and no more code or check engine light. Before I took it in, it threw a P0123 code, but check out what the paper said they did when I got it back...
Customer states engine revving by itself. Check engine light is on. Scan code P0121. TPS High Voltage. Determined cause to be open TPS. Replaced Throttle Position Sensor.
Parts......Qty........FP-Number........Description
Job #1....1...........4606196............Sensor TH 8037155
So what does this mean? Why did they get P0121 and I got a P0123? And from what I'm reading, they replaced the sensor only and not the harness, or did they? Replacing the sensor only is not the fix, right? Replacing the harness is... I thought?
Get back. Thanks!
- Florida SRToc (FLSRToc) President
- SRTforums.com, #1 SRT site on the net!
- Local St. Pete/Tampa SRT-4 owners, need help installing a part? PM me!
WhiteRob1984 is offline   Reply With Quote
Old 02-01-2005, 02:24 PM   #163 (permalink)
SRToc Member
hemidakota's Avatar
Member Number: 272
Trader Rating: (15)
Are you at home right now?
Old 02-01-2005, 02:34 PM   #164 (permalink)
Trader Rating: (38)
Me? If so, yes!
Old 02-01-2005, 02:39 PM   #165 (permalink)
SRToc Member
hemidakota's Avatar
Member Number: 272
Trader Rating: (15)
What are your mods?
Did you check for any CELS on the dashboard?
