Old 10-18-2008, 02:22 PM   #1 (permalink)
SugerBear's Avatar
Member Number: 58262
Default Need to replace water pump
I need to replace the water pump in my Srt-4, but I can't find any threads that tell how to do it. Any help would be great.
SugerBear is offline   Reply With Quote
Old 10-19-2008, 09:33 PM   #2 (permalink)
Member Number: 58225
Surely some one can help you on here.
Da-kkon is offline   Reply With Quote
Old 10-19-2008, 09:43 PM   #3 (permalink)
turbojack's Avatar
Member Number: 11814
Trader Rating: (122)
Look at thread dealing with timing belt R&R and download the service manual. Service manual is a sticky in the How To section
turbojack is online now   Reply With Quote
Old 11-04-2008, 02:11 AM   #4 (permalink)
SoCalHybrid's Avatar
Member Number: 52814
My guess you found your answer, but basically you remove the timing belt, then do the following:
1. Hold the intake cam sprocket completely still, and remove the bolt holding it onto the cam.
2. Now do the exhaust. (Yes, you can swap #1 and #2 if you want)
3. unbolt the timing tensioner and idler pulley
4. unbolt all of the bolts holding the inside cover on
5. If you haven't already drained the coolant for the timing belt, now's your time.
6. Unbolt the 5 or 6 bolts holding the water pump on.
7. Clean the mounting surface
8. (Per FSM) apply dielectric grease (Vasoline would probably work) in the groove on the new water pump.
9. Insert the o-ring into the greased groove.
10. Put more grease on top of the o-ring
11. bolt it up, using the torque from the FSM
12. do everything in reverse to build it up.
Note that some water pump warranties require that you do a complete cooling system flush. Use DCX HOAT coolant, or Xerex G05 coolants only. Everything else (Regardless of what the bottle says) does not meet the requirements set by the mfr. Prestone and Peak are boat OAT formulations, not HOAT.
RUgoinUp 2 Heaven? Ever lie, steal, dishonor your parents, commit adultery, use God's name in vain? Those are only 5 of the 10 Commandments. Breaking 1 condemns you to Hell. Claiming to be a good person won't work in a court of law, nor will it when you stand before God. If you want Heaven, admit you're guilty and ask God to forgive you solely on Jesus' death on a cross. Then love God with all your heart, and love people too.
SoCalHybrid is offline   Reply With Quote
Old 11-04-2008, 02:55 AM   #5 (permalink)
VanillaXtract's Avatar
Member Number: 27205
Trader Rating: (33)
What is a good aftermarket water pump?
ANTI-SWEETS CLUB MEMBER # 6
If life was easy, it'd be called "your mom"
VanillaXtract is offline   Reply With Quote
Old 11-04-2008, 04:06 AM   #6 (permalink)
I used a cardone, it had an aluminum impeller instead of the factory plastic one.
That being said, think the factory is better as you can get thinner walls which means you move more water per rotation. Be very careful though - most places are happy to sell you the stratus 2.4L with the stamped piece of junk impeller. Yes it will bolt up, but you will probably overheat. Sport compact car did a story on the srt-4 engine when it came out, and they specifically mention how DCX upgraded the cooling with the better impeller which flows something like 40% more fluid.
At risk of being burned at the stake The factory piece is already "hot-rodded"
Old 11-04-2008, 05:23 AM   #7 (permalink)
Trader Rating: (33)
Thanks for the info.
Old 01-02-2009, 05:49 PM   #8 (permalink)
Roach's Avatar
Member Number: 697
Trader Rating: (27)
what are tq specs for the water pump bolts?
2.0L SOHC - 400whp 11/11/04 - still shooting for 450whp+
Check out my mods and pics here
Roach is offline   Reply With Quote
Old 01-02-2009, 05:55 PM   #9 (permalink)
turbojack's Avatar
Get the factory service manual in PDF format from the sticky part of the How Too section. Once downloaded open it up and then using the search feature built into the PDF reader find the torque specs. Most likely it will be within the section describing the water pump install Or it will be in the first part of the engine section where there's a torque specs chart.
Page generated in 0.15653 seconds with 13 queries
