need help with fan switch mod plz read??
ok well i have tried both ways to do the fan switch mod with the relay and the way to connect it to the blue/pink wire in the ecu harness and what happens is when i hook the ground and then hook the other wire to the relay or blue/pink which ever i do and i turn the switch on i can hear the relay making a ticking noise and thats it what could be wrong.help plz
50trim..,AEM intake,hks bov,
mpx 62mm TB-agp shift selector
balance shaftchain removed-charge pipe mode
act 6-puck clutch w/prolite weight flywheel
quickwhips IC-hondata heatshield/gasket
bwoody h-brace,traction bars
3''TBE,wot box/2-step,180 stat,fan switch mod
hurst sts/booger bushing/msd coil/wires-safc neo,walbro 255lph,fuel pump rewire
s2 injectors, returnline,boomba fuel rail.dcr oil modifier,agp solid mm and trany mount.
