Old 12-10-2008, 02:52 PM   #1 (permalink)
bene's Avatar
Member Number: 53801
Trader Rating: (40)
*INFO*: Sunroof Stuck Open Fix
ok heres what i did.
turn the car on accessory and put the sunroof up.
there are 3 screws on each side that hold the glass onto the assembly. remove the 3 screws from each side and then lift the glass off of the assembly from the top.
I found it easiest to remove the 2 back screws with it tilted up and then slide the sunroof halfway back to allow easy access to the front ones.
Find the 2 sliding arms, one on each side, that push the sunroof up and pull it down.
beside the arms you will see a black circle that slides freely across the track. The arm and this circle are suppose to have a small metal pin holding them together.
If the arm is not attached to the circle securely by the metal pin then the arm will not push up and pull down tight on the sunroof properly causing leaks.
Make sure the metal pin is in securely and that it will not slide out. You may use something to help give it a bit of stick.
Then put the sunroof in the closed position without the glass on it. Tilt it up, and then run it back and make sure the arms are moving properly with the circle and fold up and down.
If it is working properly reinstall the glass with the sunroof in the tilted up position making sure you slide the arms in the groove on the glass properly.
Reinstall the 6 screws and test it out. It should close firmly with the rear of the glass being lower than the roof of your car.
And thats it! you have successfully fixed your sunroof from leaking!
for more information there is a TSB in post #2!
bene is online now   Reply With Quote
Old 12-17-2008, 07:13 PM   #2 (permalink)
Dimarini's Avatar
Member Number: 26399
Dodge sells a slide kit for our sunroofs. I got mine from a local dealer for around 25 bucks. The part number is 05174865AA. There is also a TSB for this. See the attachment:
2005 Dodge SRT-4 ACR
Mopar Stage 1 / Mopar BOV/AGP WGA/Turbonetics MBC
MaxxFab 3" O2 Housing/Perrin TBE/Split Second Map Clamp
Granetelli Motorsports Plug Wires/BWoody Check Valve
AGP Oil Separator & Breather/AEM Boost Gauge/AEM UEGO
Mopar SRT Gauges/Aeroforce Interceptor Pro
Mopar Short Throw Shifter
Dimarini is offline   Reply With Quote
Old 12-18-2008, 08:10 AM   #3 (permalink)
racerx20's Avatar
Member Number: 63873
Trader Rating: (10)
Thanks for the info!
04 SRT-4 Electric Blue....Stage 2 no toys, FM WGA, fuel pump rewire, ED FMIC, Ported TB, AEM SR, Full 3" exhaust, Bwoody H-brace, MP Shifter, MP Stg 1 Springs, a few cosmetics
69 Dart Swinger 340
racerx20 is offline   Reply With Quote
Old 12-18-2008, 01:01 PM   #4 (permalink)
Dimarini's Avatar
When I first went to the dealer I asked about getting replacement parts for the sunroof, and they tried to sell me the sunroof for about 800 bucks. So I had to search around a little bit. Jimmy at S & P hooked me up with the TSB.
I thought I would share it to help some guys out.
Old 12-18-2008, 05:53 PM   #5 (permalink)
racerx20's Avatar
Trader Rating: (10)
It definitely helped called and ordered the part today only cost my $15, thanks again!
Old 12-18-2008, 06:09 PM   #6 (permalink)
cleveage's Avatar
Member Number: 37866
Trader Rating: (18)
This is some of the best info I have seen on the sunroof period, this should be a sticky,
cleveage is online now   Reply With Quote
Old 12-18-2008, 09:02 PM   #7 (permalink)
goats srt's Avatar
Member Number: 47689
troof
look in my for sale thread
selling good stuff check it out
Old 12-18-2008, 09:16 PM   #8 (permalink)
cleveage's Avatar
Trader Rating: (18)
I started a thread with a link to this thread asking for it to be stickied and so far I got one response telling me it would need to be in the how-to section, and one smart-ass telling me I misspelled my screenname wrong.
Old 12-19-2008, 07:47 AM   #9 (permalink)
SRTforums Junior Admin
Pete's Avatar
Member Number: 43767
Trader Rating: (89)
added to approved list.
ran a 12.11 at 111 on the stock ported turbo 1.68 60ft
NEW SECTION ****SRT OF THE MONTH CLICK ME*****
DRIVE A NISSAN SENTRA NOW SRT IS GONE
Quote: Originally Posted by peteswife View Post
Yes, because Peter takes the interwebs job oh so seriously... oh wait, a job that he doesn't even get paid for!!!
Pete is offline   Reply With Quote
Old 12-19-2008, 11:55 AM   #10 (permalink)
G-rex's Avatar
Member Number: 64620
good write up ive been havin the same problem
G-rex is offline   Reply With Quote
Old 03-30-2009, 01:20 PM   #11 (permalink)
Member Number: 50639
anyone know what to do for a leaking sunroof?
vinnie22 is offline   Reply With Quote
Old 03-30-2009, 01:45 PM   #12 (permalink)
bene's Avatar
Trader Rating: (40)
thanks for the the sticky pete!
Old 03-31-2009, 01:40 AM   #13 (permalink)
cleveage's Avatar
Trader Rating: (18)
No thank you for starting the thread and Dimarini for supplying the part# and info.
Old 03-31-2009, 09:48 AM   #14 (permalink)
Pete's Avatar
Trader Rating: (89)
deleted a few posts to make it easier to read.
Old 04-07-2009, 03:15 PM   #15 (permalink)
srt41981's Avatar
Member Number: 71640
Question
So the rear part of sunroof is supposed to be lower than the roof line? Because that's how mine is and everyone tells me something is not seated right. All other SRT-4's I have seen the sunroof sits flush on front and rear.
srt41981 is online now   Reply With Quote
Page generated in 0.20477 seconds with 14 queries
