Old 01-18-2005, 09:05 PM   #1 (permalink)
Speedooooo's Avatar
Member Number: 2759
Trader Rating: (25)
INFO: Removing Outside B Pillars
I've head it's pretty hard to do. I want to take them off and paint them. I don't want to keep having to clean them, and them getting oily and dirty in 2 days. Thanks for the help.
Speedooooo is offline   Reply With Quote
Old 01-18-2005, 10:38 PM   #2 (permalink)
cocoadog's Avatar
Member Number: 9184
Give this a try.
04 Flame Red w/Predator 93 stock tune, Stock turbo & wastgate, Mopar Catback, K&N CAI, Forge BOV, JMB Hard Pipes, Hotchkis sways, Urethane bushings,
Stage 3 coilovers and some other odds and ends
cocoadog is offline   Reply With Quote
Old 05-20-2005, 03:48 PM   #3 (permalink)
Bacardi 151's Avatar
Member Number: 14061
Trader Rating: (34)
I want to add to this...
The fronts are REALLY easy...
1. Lower window
2. Pull away the rubber on the vertical part of the door
3. Unscrew the three torx bolts holding the pillars on...
The rears on the otherhand...
1. Lower the window...
3. Remove two screws on door panel and window roller handle
4. Pull to remove door panel
5. Unclip the door lock and door handle rods from the door panel
6. Pull off half the clear plastic
7. Remove the two screw holding the window in place (there's only two screws)
8. Gently push the window down (goes down another 4")
9. Tilt window so the rear bumper side of the window goes down a little, and the front bumper side of the window goes up...
10. Push the glass towards the inside of the door to gain access to lowest torx bolt
11. Remove the middle and upper torx bolts...
When you reinstall the pillars, I suggest you do not install the lowest torx bolts...If you want to ever remove the pillars again for repainting or whatever, you can remove the rear pillars by only pulling away the rubber...You won't have to worry about the glass or door panel...
Former 295hp/344tq owner
Bacardi 151 is offline   Reply With Quote
Old 05-20-2005, 06:24 PM   #4 (permalink)
Speedooooo's Avatar
Member Number: 2759
Trader Rating: (25)
Thanks for the great how to. I think I'm going to stick to taking off only the fronts.
Old 05-21-2005, 08:36 AM   #5 (permalink)
Trader Rating: (34)
You could also put black vinyl on it without removing the pillar...Go to a sign place and get some black scrapes...There's also something called vinyl striping tape (like a 3" wide pinstripe) which is sold on ebay for about $10 shipped and probably at auto part stores as well...
Old 06-06-2005, 05:57 PM   #6 (permalink)
Trader Rating: (34)
Default Pics added
Here's all you do to remove the rubber...Pull the rubber at the top down, then you can easily pull the rubber away from the side...
Here's the finished product...
Old 06-06-2005, 06:01 PM   #7 (permalink)
mysrt4ownsyou's Avatar
Member Number: 947
Trader Rating: (51)
question! when you remove all 4 of these b-pillars...is the underneath thats still on the car painted the same color as the car is painted itself? such as, if u take them off a black srt4, will the underside still on the car be black? as on a yellow car would the underside still left on the car after the bpillars are taken off be yellow? let me know! thanks!
mysrt4ownsyou is offline   Reply With Quote
Old 06-06-2005, 06:59 PM   #8 (permalink)
TheBeak's Avatar
Member Number: 8513
that looks really nice, thanks for the ideas and the how to...
'Tilll next time,
Rich
3/11/05 Stone White ACR on order!.................................................. ..........................
5/10/05 Stone White ACR in the garage !!
TheBeak is offline   Reply With Quote
Old 06-07-2005, 07:10 AM   #9 (permalink)
Trader Rating: (34)
Yes, it's body color and clearcoated underneath...But it won't look good with the pillars removed, IMO...Towards the top there's there's an indent, almost looks like there's a dent...
Old 06-07-2005, 11:22 PM   #10 (permalink)
Speedooooo's Avatar
Member Number: 2759
Trader Rating: (25)
Hey Boost N Juice that looks really good. I was going to paint mine but seeing as how complicated it is to take off the rear ones, I'm going to get some vinyl I think. Thanks for the write-up.
Old 06-08-2005, 04:32 PM   #11 (permalink)
Member Number: 947
Trader Rating: (51)
thanks for the info...do u think itd even look bad being that my car is black if i removed them? or is the paint scuffed underneath?
Old 06-09-2005, 02:25 PM   #12 (permalink)
Member Number: 8918
i was wondering about same color paint..if i take them off..to i have to get them painted RIGHT AWAY and put back on..or will it be ok if they are off for a day or two ??
nikon d40 ,, Nikon 18-55mm f/3.5 - 5.6G
Nikon AF-S DX Zoom-Nikkor 55-200mm f/4-5.6G ED
Nikon 50mm 1.8, quart. 70-300mm, nikon 18-135 f/3.5-5.6G IF-ED Nikon SB-400
2003silverneonsxt is offline   Reply With Quote
Old 06-09-2005, 02:28 PM   #13 (permalink)
Trader Rating: (34)
They're just trim pieces...Your car won't let water in when it rains if the pillars are off...
Old 11-08-2005, 11:09 PM   #14 (permalink)
FranknBeans's Avatar
Member Number: 9927
Anyone think about painting them while they are still on the car....?
2003 Silver Dodge Srt-4 - sold
2007 Silver Dodge Nitro
2010 2SS Camaro
FranknBeans is offline   Reply With Quote
Old 11-09-2005, 05:35 AM   #15 (permalink)
Trader Rating: (34)
Take around them very good...
