Old 07-05-2009, 05:05 AM   #1 (permalink)
GreaseMonkey69's Avatar
Member Number: 43017
Trader Rating: (23)
INFO: List of Tools/Materials/Part #'s for Some How-To Projects
I get alot of questions on the How To: thread on tools and equipment.This thread will be the tools,part numbers,prices and where to find the tools or required sealant/hardware for projects involving removing installing a head/timing belt oil pump ect. Now i will provide other part#'s and prices for all peoples budget,but please don't try to skimp out "making do with what you got" or trying tools that are not made for the job. Tools are built for these purposes and will make the job easier.
These tools are found on this website SPX Miller Special Tools | Main
Now here are some of the tools to work on the head.
3 Jaw Puller to remove the harmonic ballancer. 143.15$
SPX Miller Special Tools Search Results for 8454
Camshaft Sprocket holder. 77.37$
SPX Miller Special Tools Search Results for 6847
Valve Spring Compressor. for doing projects with "the head on" the car 95.00$
SPX Miller Special Tools Search Results for 8215A
Valve spring compressor. use with "head off" 266.60$
SPX Miller Special Tools Search Results for 998772A
know it say's for 3.3 and 3.8L the screws at the end are the same thread and pitch for our valve cover bolts. all you do is tighten them down. turn the handle and slowly compress the springs until you can remove the keepers. then uncompress the spring! use the adapter below!
adapter for the valve spring compressor for use for 2.4 L 51.28$
SPX Miller Special Tools Search Results for 6779
[Tools for installing/removing oil pump assy
Crank Sprocket Remover. (oil pump gear remover) 35.49$
SPX Miller Special Tools Search Results for 6793
Crank Sprocket Installer 37.47$
SPX Miller Special Tools Search Results for 6792
Crank Seal Installer 72.53$
SPX Miller Special Tools Search Results for 6780
B]Now if you don't have the Extra cash for some of these products here are some products from Welcome to Lisle Corporation i have these tools and they do just as good as the miller tools.[
Harmonic damper pulley puller. part# 49500. 78.95$
Detail Page for 49500 Harmonic Damper Pulley Puller - Lisle Corporation
universal cam adjuster. part# 38220. 37.95$
Detail Page for 38220 Universal Cam Adjuster - Lisle Corporation
GreaseMonkey69 is offline   Reply With Quote
Old 07-05-2009, 05:07 AM   #2 (permalink)
Trader Rating: (23)
Here are some of the sealants and other items we use on the car.
Here is the website for most of the sealants.
Discounted OEM Mopar Parts For Your Chrysler Dodge Or Jeep
Cam cap - Oil Pump - red anaerobic sealer
4318083 $15.00 list $10.08 net
Mopar Gasket Maker
(Loctite 518 or Permatex 51813 is the same)
Dabs for valve cover corners - water pump seal - oil pans - black RTV silicone
4318025 $5.20 list $3.47 net
Mopar Black RTV Silicone
(Permatex UltraBlack is a good substitute.)
Mopar MLS head gasket - brown gasket sealant
4318035 $11.62 list $7.81 net
Mopar Gasket Sealant
Now to seal the head gaskets i would reccomend using these products found at a AutoZone,but im sure most auto parts stores carry these items.
AutoZone.com | Get In The Zone!
Permatex / 9 oz. Aerosol Can Copper Spray-A-Gasket Hi-Temp Adhesive Sealant
Part# 80697 6.99$ a can
Duplicolor Engine Enamel (aluminum color) used for head gasket if no spray-a- gasket is available.
DE 1615 Aluminum 5.99$ a can
Now here are different part#s for assembly lube for the cam shafts for initial start up. this is found at AutoZone.com | Get In The Zone!
COMP Cams / 4 oz. (113.398 g.) Engine Assembly Lube Jar 11.99$
This lube is found at O'Reilly Auto Parts - Home
LUNATI PERF.ENGINE PARTS - CAM LUBE (CAMSHAFT LUBE) 6.99$
Old 07-05-2009, 05:25 AM   #3 (permalink)
Trader Rating: (23)
using this post for space and more additions!
Old 07-05-2009, 08:26 AM   #4 (permalink)
RUgoinUp's Avatar
Member Number: 181
Trader Rating: (33)
ATTENTION MEMBERS::
PLEASE DO NOT POST IN THIS THREAD UNTIL THE AUTHOR HAS COMPLETED IT.
GREASE, PLEASE LET US KNOW WHEN YOU ARE FINISHED. i WILL DELETE THIS POST WHEN YOU ARE FINISHED.
RUgoinUp 2 Heaven? Ever lie, steal, dishonor your parents, commit adultery, use God's name in vain? Those are only 5 of the 10 Commandments. Breaking one condemns you to Hell. Claiming to be a good person won't work in a court of law, nor will it when you stand before God. If you want Heaven, admit you're guilty and ask God to forgive you solely on Jesus' death on a cross. Then love God with all your heart, and love people too.
RUgoinUp is offline   Reply With Quote
Old 07-05-2009, 08:29 AM   #5 (permalink)
Trader Rating: (23)
no problem i worked on it last night. there are a few more things to post up and i should be finished. thanks!
Page generated in 0.20111 seconds with 13 queries
