Old 08-02-2009, 06:25 PM   #1 (permalink)
Member Number: 74306
INFO: Links to General Automotive Repairs/Maintenance
How's it going guys. Here are some completed DIYs that you guys might find helpful. The repair info isn't model specific but does give you a general idea of how certain parts work. Let me know if you guys see any errors.
- Anti Lock Brake Safety Information (ABS)
- Air Conditioning Troubleshooting - No cool air, noisy AC, etc
- Ball join check
- Brake System Troubleshoot - screeching noise, dragging brakes, etc
- Break-in procedure for new engines
- Camshafts - removal, cleaning, inspection and installation
- Charging System - No start, Noisy alternator, fuses burn out quickly, battery not charged
- Clutch Troubleshoot - chattering, rattling, slipping, stiff pedal, and more
- Cooling System - overheating, low coolant, refilling, flushing, and more
- Crankshaft and Main Bearings - removal, cleaning and inspection, installation and more
- Cylinder Head Overhaul - removal, cleaning, inspection and installation
- Drive Axle - Clunk Noises, Gear noises, vibration, and more
- FF Axle Shafts and CV Joint Troubleshooting
- RWD Drive Axle Troubleshoot - clunking noises, vibration and more
- Troubleshoot hard starting, rough idle, slow acceleration, Misfire, poor gas mileage, etc.
- Electrostatic Discharge (ESD)
- Emissions Inspection - PCV, TAC, Evap, Catalytic Converter, EGR and more
- Engine Services - bead blasting, cold tank, steam cleaning,
- Engine Damage Inspection - Magnaflux, Zyglo, Dye Check, Ultrasonic, X-ray
- Engine Overhaul - cleaning, cylinder head, pistons, rods, crankshaft and more
- Engine Troubleshoot - rough idle, hesitation, backfire, detonation, low oil pressure and more
- Fuel System Troubleshooting - Hard starting or no-start, ping on acceleration and more
- Heater System Troubleshoot - Low or no heat, blower not working and more
- Troubleshoot ignition system, no-start, engine runs rough, etc.
- Proper vehicle jacking and wheel removal procedures
- Manual Transmission Repair - Troubleshooting noisy gears, gears clashing, hard shifting, etc
- OIL PUMP - Rotor and Gear type
- Parasitic Load Explanation and Test Procedures
- Pistons, Connecting Rods and Bearings - removal, cleaning, inspection
- Power Steering Troubleshooting
- Safety in the Garage
- Spark Plugs - troubleshooting, carbon deposits, electrodes, etc.
- Starter Troubleshooting - no start, no clicks from solenoid, etc.
- MANUAL STEERING GEAR TROUBLESHOOTING
- Suspension alignment troubleshoot - tire wear, odd suspension noises, etc.
- Tie rod test
- Timing Chain and Belts - tension adjustment, gear backlash, runout, etc.
- Undercarriage Quick test - this finds loose suspension parts that need replacement.
- Warped Rotors - this test helps determine if your rotors are warped.
- Wheel Alignment Operations - camber, caster, toe, steering axes and more
- Wheel Bearing Quick Test
nitroholickid is offline   Reply With Quote
Old 08-02-2009, 06:26 PM   #2 (permalink)
conroy9940's Avatar
Member Number: 46401
Trader Rating: (114)
Moderator edited.
Pittsburgh Penguins 15-8-0 28 points
Old 08-02-2009, 06:50 PM   #3 (permalink)
RUgoinUp's Avatar
Member Number: 181
Trader Rating: (33)
Welcome to our site.
RUgoinUp 2 Heaven? Ever lie, steal, dishonor your parents, commit adultery, use God's name in vain? Those are only 5 of the 10 Commandments. Breaking one condemns you to Hell. Claiming to be a good person won't work in a court of law, nor will it when you stand before God. If you want Heaven, admit you're guilty and ask God to forgive you solely on Jesus' death on a cross. Then love God with all your heart, and love people too.
RUgoinUp is offline   Reply With Quote
Old 08-02-2009, 06:52 PM   #4 (permalink)
Member Number: 30696
Moderator edited.
amdguy is offline   Reply With Quote
Old 08-02-2009, 11:13 PM   #5 (permalink)
Moderator edited.
Old 08-06-2009, 08:43 PM   #6 (permalink)
hey guys.. the links are now working.. thanks..
Page generated in 0.20355 seconds with 13 queries
