INFO: Greddy Profec B-Spec II Wiring Diagram - Dodge SRT Forum
post #1 of 11 (permalink) Old 11-06-2005, 03:29 PM Thread Starter
Blue Acuma's Avatar
Quoted: 0 Post(s)
To everyone looking for a diagram enjoy.
Click image for larger version
Blue Acuma is offline
post #2 of 11 (permalink) Old 01-02-2006, 12:39 AM
str5010's Avatar
Quoted: 0 Post(s)
vaccum line question
on the provided three way fitting, that incluedes the blue line as a boost source, the 4mm line with the filter, where does the third line go?
str5010 is offline
post #3 of 11 (permalink) Old 01-25-2006, 12:52 AM Thread Starter
Blue Acuma's Avatar
Quoted: 0 Post(s)
The 3rd goes to where the blue line was hooked up.
-Pop your hood look for the 3 sensors labled 1, 2, and 3.
-The blue line goes into 3.
-Disconnect the blue line from the sensor.
-Cut a piece of 4mm hose about 1"-2".
-Hook the 1"-2" of 4mm hose to the end of the blue line you disconnected and to one of the 3 way fitting ends and zip tie both sides.
-Hook 1 of the 3 way fitting ends to the 4mm line that goes to the filter/ Boost Controller and zip tie again.
-You should now have 1 end left on the 3 way fitting, connect that end to where you pulled the blue line from on sensor 3 and you are done.
post #4 of 11 (permalink) Old 01-26-2006, 06:30 PM
New Member
Snake Champion, Chopper Challenge Champion, Curveball Champion, Yetisports Ylmypics Champion
vschaos's Avatar
Quoted: 0 Post(s)
I am trying to figure out my setup for this with big turbo. I have had the kit on since like december, but just got new clutch broken in. Anyway when the boost controller is off the car hits the 15-15.3 psi range. When I turn on the boost controller and have everything zeroed out it will hit up around the 19 psi range for some reason. So something is hooked up weird...it was working fine when I had it setup on stage 2 with stock turbo. I must just have something backwards, but was wondering if anyone knew about the big turbo setups how to wire it. I am not sure how mine is currently setup....I now only drive it on the weekends....drive the metro during the week
vschaos is offline
post #5 of 11 (permalink) Old 06-06-2007, 07:31 AM
scrivenerc's Avatar
Quoted: 0 Post(s)
Can some one help me, Im trying to take my ebc out. What lines go where once I remove that three connector? Im lost. I understand everything else expect for the line off the TB.
scrivenerc is offline
post #6 of 11 (permalink) Old 06-01-2008, 06:22 PM
Quoted: 0 Post(s)
Actually I'm installing the Boost controller right now and I just took the black hose from the acuator and hooked it to the Com side on the soleniod and the one from my CAI to the NO side on the soleniod with the NC still plugged and I'm trying to find a gromet that I can run the wires from the soleniod to the controller. But I find that the extra T-pipe needed...isn't needed. but I'll comment if it is...wish me luck!!
WinnipegSRT is offline
post #7 of 11 (permalink) Old 06-02-2008, 07:56 PM
Quoted: 0 Post(s)
Okay, so the controller is installed and that 2nd T-pipe isn't needed. and I found a gromet and just ran the up through the steering coloum. and mounted it on the steering wheel shroud. Took me about 3 hours 2 do (trying to run the wires different ways) but it was pretty easy to install. If you guys want I can take pics and show how it was done?
post #8 of 11 (permalink) Old 06-24-2008, 11:27 PM
SRTSLOW4ME's Avatar
Quoted: 0 Post(s)
ok.. i just installed my profec.. i just dont understand.. what do you do with the original line that comes off the stock wastegate(agp is there now)???
SRTSLOW4ME is offline
post #9 of 11 (permalink) Old 06-25-2008, 11:04 PM
Quoted: 0 Post(s)
You connect the supplied hose to the hose knuckle and connect it to the COM side on the Solenoid.
post #10 of 11 (permalink) Old 09-30-2009, 11:19 PM
standupguy33's Avatar
Quoted: 0 Post(s)
i just installed the profec b 2nite and it seems to be working pretty good. im still trying 2 get the bugs worked out and get it set 2 how i want it but i notice rite now the boost isnt real consistant. i still got some messing 2 do with it 2marro but it seems like its hiting where i set it then kinda jumping around a pound or 2. i hooked it up exactly 2 the diagram thats on here. ne pointers from ne1 about doing a little fine tuning?
2004 GUARDS RED SRT BB 50 TRIM TUNED BY TURBO666
standupguy33 is offline
post #11 of 11 (permalink) Old 04-06-2011, 02:03 AM
Autobots's Avatar
Quoted: 0 Post(s)
Link at the top does not work.
Autobots is offline
User Tag List
Linear Mode Linear Mode
