i need to know what i need for my t3t4... all i have is the turbo itself...
i need to know what kind of oil lines i need/ length too... it has a 5 bolt flange pattern for the turbine housing.. where can i get an o2 housing for this setup?
and what is the best manifold for it? thanks in advance!
have a moderator move this thread to the performance section or what they feel is a better section.
but go to agpturbo .com
for oil feed lines and or return.
atpturbo .com is another good site
and summittracing .com
you need a 3/8 npt plug
3/8 to -4 fitting
28" of -4 oil feed line
-10 or 5/8" oil return line
oil drain flange
-4 to 1/8" fitting for the turbo inlet
agp log mani, kinetic, or another t3 mani
different blow off valve with hard piping
agp or another manufacture 5 bolt O2 housing
38mm external wastegate
all necessary gaskets
wastegate dump tube or recirc.
new intake, and some other misc. items
if you have anymore questions do a search before you post
Only atp makes a 5 bolt adapter otherwise you will also need a 4 bolt exhaust housing with the turbo. At this point you may be better off selling your turbo and buying a complete package from agp. Unless you plan on buying everything used you will pay more in the long run.
