Old 04-29-2009, 02:44 PM   #1 (permalink)
relenger's Avatar
Member Number: 30003
Default How-To: Wire Up "Trac Off" Light
How To - Wire up the "Trac Off" Light on the dash
Tools for the job
Philips Screw driver
Parts
wire
Clip (not sure what there called, Metal clips that go in the harness at the end of the wire where it connects)
First thing you need to do is remove the screws at the top of the dash pad next to the defrost vent, then remove the screws at both ends of the dash pad
gently pull the dash pad up, its held in by clips.
once you get enough room you should be able to see the two screws at the top of you guage cluster, remove them
Now lower your steering wheel to its lowest point.
the plastic shroud that is at the bottom of the cluster is also held in by clips. gently pull up working from left to right. the are four clips holding it down.
now remove the two screws at the bottom of the cluster. remove them.
Next gently pull your clust out.
Now look at the back of the cluster. it should look like this
The Square around the right set of bulbs is where we wanna focus
You will need a bulb to put here. I used my CEL bulb since i have a AEM EMS and the CEL is on all the time. here is where the bulb goes
You are done with the guage cluster. Now lets get back in the car and take a look at the harness. Should look like this
Now you need to take your wire and put the clip on the end. i have a spare harness with alot of clips. if you need a wire ready to install with a factory clip. just PM me.
plug the clip/wire into this spot. bottom row, 3rd in from the right. located here
You are done. now put everything back together. The light is lite by grounding it. I have a AEM EMS so i hooked it to that and when my traction control is off, the light is on
The Cobalt firmly grabs you and whisks you along your way instantly.
It does so with authority and poise, but while slipping relatively unnoticed through traffic,
never being violent, or dare I say it, frightening. When you ask the SRT-4 to take you somewhere fast,
it punches you in the face, throws you over its shoulder, and runs, screaming,
so quickly that its tires can barely keep up
relenger is offline   Reply With Quote
Old 05-17-2009, 08:46 PM   #2 (permalink)
projectNEON's Avatar
Member Number: 10290
Trader Rating: (35)
I'm lost since when do we have trac control? Must be for standalone guys I assume. Good find though
[IMG][/IMG]
Best 1/8th: 8.205 @ 84.95 Best 1/8th MPH: 86.37 <<< These are so 2005 I need new numbers
projectNEON is offline   Reply With Quote
Old 05-18-2009, 09:36 PM   #3 (permalink)
relenger's Avatar
Yes this is more for the standalone guys. You could use it for other things too.... how about when HOM is off?
Old 06-26-2009, 12:51 AM   #4 (permalink)
Racindesi101's Avatar
Member Number: 61040
Yea this puzzled me too because i noticed the trac off symbol by accident...the sun just happend to hit it at the right angle and im liek wow what!...now I know we dont have trac control so whats the story behind that?
Racindesi101 is offline   Reply With Quote
Old 06-26-2009, 03:08 AM   #5 (permalink)
Xx_R/T_xX's Avatar
Member Number: 18749
the older rt neons used to have them
BIG TURBO!
Old 07-21-2009, 09:22 PM   #6 (permalink)
CantStopSpinin's Avatar
Member Number: 56380
nice
stage 3 FTW!
CantStopSpinin is offline   Reply With Quote
Old 07-21-2009, 09:35 PM   #7 (permalink)
hercfe's Avatar
Member Number: 19255
it would be nice to use this with a wotbox/2step. it wouldn't be hard.
hercfe is offline   Reply With Quote
Old 07-21-2009, 09:42 PM   #8 (permalink)
aww sheet's Avatar
Member Number: 20431
Trader Rating: (31)
i was thinking the same thing
View Modifications
Old 07-21-2009, 09:58 PM   #9 (permalink)
Sota's Avatar
Member Number: 31159
or the boost box.
would give a nice visual indicator when either is "deactivated" for what ever reason.
where's jay and phrozen.
  • N2MB / Jay & Jon
  • S&P Development / Jimmy
  • Maddog Shifters / Chuck
What else needs to be said?
Sota is offline   Reply With Quote
Old 07-22-2009, 09:04 AM   #10 (permalink)
Member Number: 61839
If you put in an R/T cluster with stock PCM you'll have track control as well.....
2001 R/T
stage 3R
snapisone1 is offline   Reply With Quote
Page generated in 0.17480 seconds with 13 queries
