Old 03-21-2006, 10:49 PM   #106 (permalink)
lnxsrt's Avatar
Member Number: 6702
heh, had this mod for a year and a half and never a code. safe to say it works.
11.5mm wires
greddy full auto tt
JMB catch can and breather
mopar bov
front and rear dc sports strut tower bars
mopar sts w/booger
mpx shift knob
agp motor mounts
jlm tranny mount
bdj's no cat 3" side-exit
jmihalchik's 2nd O2 eliminator mod
MaxxFab 3" O2 Housing
agp wga
needswings MBC 17psi down to 15psi
Denso Iridium ITL20
JMB 3" SR Intake
180 tstat
LFS 60MM TB/ADPTR
lnxsrt is offline   Reply With Quote
Old 03-22-2006, 11:29 PM   #107 (permalink)
Kali's Avatar
Member Number: 12322
How far in do you need to drill the non-fouler? just a bit? just to near the end?
[x] Mopar BOV
[x] Race MM Inserts
[] AGP WGA
[] MSD 8.5mm Spark Plug Wires
[x] Needswings 3" DP w/ E-cutout
[x] Goldline Lowering Springs
[] FMIC *Debating*
Kali is offline   Reply With Quote
Old 03-23-2006, 11:07 AM   #108 (permalink)
lnxsrt's Avatar
Member Number: 6702
enough to screw it on the O2 sensor
Old 04-25-2006, 12:14 PM   #109 (permalink)
Member Number: 17538
Im getting code PO420 but my Mopar/Borla Turbo Back, From Maxxfab, has a High Flow Cat. Should i do this Mod or try something else??
honda2dodge is offline   Reply With Quote
Old 04-25-2006, 04:59 PM   #110 (permalink)
vypurr2's Avatar
Member Number: 10185
This will fix it for you if you want to do that. Stage 1 will also fix it.
vypurr2 is offline   Reply With Quote
Old 04-30-2006, 11:00 AM   #111 (permalink)
ZZiK's Avatar
Member Number: 641
engine code came back after 2 days kept trying different ways still have engine light on!!! dmanit!
Very First 03 and 04 SRT's in South FL!! Mods on 04: Mods as off 08-07: BDJ 3' dump with o2 housing, AEM Intake, AGP UHP and Exhaust depot Hotside, HKS SSQV, Greddy TT, NGK AFX Wideband, DCR Top end modifier, New AGP WGA, Dasmopar Map clamp slightly tuned around 12.5/11.5 a/f. AGP BIG FMIC. Stage 1, SD Coil pack, wires, Walbro 255 FP, Stock ported turbo and stock ported TB to 55mm.
ZZiK is offline   Reply With Quote
Old 04-30-2006, 07:53 PM   #112 (permalink)
sqcomp's Avatar
Member Number: 33803
I installed my needswings v5 and used this non-fouler trick. No codes yet after 48 hours...
I also took a roundtrip from Portland to Tacoma and back...no codes.
sqcomp is offline   Reply With Quote
Old 05-06-2006, 01:48 AM   #113 (permalink)
OrangeSurprise's Avatar
Member Number: 37362
Quote: Originally Posted by Bacardi 151
Quote: Originally Posted by raven_328
WHy dont you guys just get o2 sims?
Who sells them and how much? Also, does the sim allow you to remove the 02 sensor from the bung entirely?
anyone??? sims??? if i'm gettin the aem uego do i have to do this mod? am i replacing the a/f sensor with the uego or the o2? and what do i do with the a/f sensor or o2 sensor?
Mopar Stage 1,DTEC FC,Greddy Profec B,Maxxfabb 3" O2 Housing,Kinetic WGA,AEM UEGO Wideband,Perrin 3" TurboBack Exhaust, AGP Dogbone mounts,"modified" AEM SRI, AGP uppipe w/ greddy RS, Megan Racing COs, Hotchkis Rear sway bar
???HP/???TQ
13.6 @ 103mph @ Raceway Park, Englishtown, NJ
street tires suck!
Back in NY baby!!!!
OrangeSurprise is offline   Reply With Quote
Old 05-07-2006, 10:42 AM   #114 (permalink)
okay anyone know where in jersey i can find a non-fouler? went to pep boys yesterday and they didn't have it(AARRRRGH!!)
Old 05-08-2006, 01:33 AM   #115 (permalink)
Member Number: 2096
Did this last Wednesday and so far no problems!
xmdfmk7x is offline   Reply With Quote
Old 05-08-2006, 02:50 PM   #116 (permalink)
vypurr2's Avatar
PM me if you can'y find one. I have a spare sitting around.
Old 05-08-2006, 07:00 PM   #117 (permalink)
TekWarrior's Avatar
Member Number: 29278
3 months and not 1 code
TekWarrior is offline   Reply With Quote
Old 05-14-2006, 04:15 AM   #118 (permalink)
Member Number: 2096
Was working good, but I just threw the upstream O2 sensor code. P0133 if I remember correctly. No P0420 however. Maybe the 180 t-stat has something to do with throwing the P0133 seeing as how the same night I installed the t-stat with my cutout open it threw the code. Simple reset of the ECU got rid of it.
Old 05-18-2006, 10:17 AM   #119 (permalink)
vypurr2's Avatar
Maybe you drilled out too much?
Old 05-20-2006, 08:28 PM   #120 (permalink)
SilentBear's Avatar
Member Number: 34629
Quote: Originally Posted by Beastiek2
Hey guys I also did this mod for the V5 DP and the code same back after about an hour..I reset the ECU again and same thing.
I have an 05 is somthing else required?
DP is my only mod right now.
Thanks for any help
-Brody
Is it the no cat code? Or I found this on the first page.
The check engine light that you are getting is not from the 2nd o2 sensor but from the upstream o2 sensor ( in o2 housing). It is reading no backpressure and sending CEL code p0133 i think that is the right code, its either 0133 or 0833, but either way, if you don't have a cat on your exhaust your gonna get a code no matter what.
SilentBear is offline   Reply With Quote
Page generated in 0.19622 seconds with 13 queries
