Old 03-21-2007, 03:44 PM   #151 (permalink)
vypurr2's Avatar
Member Number: 10185
Correct! Follow the pictures above!
vypurr2 is offline   Reply With Quote
Old 03-25-2007, 10:02 PM   #152 (permalink)
SkittlePower's Avatar
Member Number: 37724
Trader Rating: (50)
i just did this about 2 weeks ago and i accidently drilled all the way through the nonfouler and i still dont have a code. good find
SkittlePower is offline   Reply With Quote
Old 05-04-2007, 10:21 AM   #153 (permalink)
Jmhm17's Avatar
Member Number: 24437
hey for all you people that are still not throwing codes over a few weeks.. when you turn your key to the "on" possition but dont crank the motor. dose your CEL flash 10 times? cause if it dose then this mod dosent fix anything, if it stays on solid then your car has passed its OBDII drive cycle and all tests passed. let me know. and having your car stay in its "test mode" pulls a shit ton of fule/timeing, if you can watch your fule trims and ignition retard and advance when its trying to pass the tests..
i dont need the mod to make the code go away i need it to pass its drive cycle so my other sensors can pass as well.. its totaly fuckin with my tune and driveability. cause like i said if its still flashing (the cel) then its pointless.
i dont want to have to buy stage one.. and i have pulled every cat code out there so hopefully this clears up all of them rather then just 420
* Disclaimer...The above post may or may not have misspelled words ...deal with it...
**Sold**
Best E/T 12.699 @ 108.97
Best MPH 12.856 @ 110.32
09 Legacy 2.5i DBM... I miss boost
Jmhm17 is offline   Reply With Quote
Old 05-04-2007, 03:20 PM   #154 (permalink)
jmihalchik's Avatar
Member Number: 4142
i have had this mod for years my tune was perfect, the 2nd o2 has nothing to do with timin and or a/f u can unhook with no effect on timing, a/f it is strictly an emissions control device that makes u keep ur cat.
12.879@110.21, stage 0, no juice, stock fuel, stock o2 housing, stock bov, stock tb, stock intake mani.
jmihalchik is offline   Reply With Quote
Old 05-04-2007, 03:22 PM   #155 (permalink)
jmihalchik's Avatar
Member Number: 4142
no flashing btw, just tested for ya
Old 05-04-2007, 03:59 PM   #156 (permalink)
Jmhm17's Avatar
awasome thanx for checking.
it dose alot more then just throw a code. i think it states it in the FSM. stage one just passes it regardless and only reads the first one.
Old 05-04-2007, 08:48 PM   #157 (permalink)
vypurr2's Avatar
Just wanted to update...2+ years with this mod and no problems yet!
Old 05-06-2007, 06:32 PM   #158 (permalink)
Jmhm17's Avatar
ya i just did this and no codes yet
Old 05-12-2007, 12:20 PM   #159 (permalink)
l3it3r's Avatar
Member Number: 5077
I have no cat, and have no code... I don't know why, but this mod seems pointless to me since I haven't experienced the need for it.
Canon EOS 30D|Canon EF 28-135mm f/3.5-5.6 IS
Canon 18-55mm (kit lens), Canon 50mm f/1.8 II
SanDisk 8GB ExtremeIII | Canon 580EX Flash
l3it3r is offline   Reply With Quote
Old 05-17-2007, 11:23 PM   #160 (permalink)
mooseman0's Avatar
Member Number: 45861
Trader Rating: (18)
OK i have a HUGH question my car will not drive for very long w/o getting the boost leak code i have fades tip mods and i am 2005 i also get the cat code and once my check engine comes on at all with or w/o the cat code it is always at least the boost leak code but n e ways n e time i get a check engine like the car will not run right at all if i jump on it at all it falls on its face
WIll the prevent that from happening!!!
IF so i will keep my car cause i am tired of it!!!
05 srt4 few bolt ons
mooseman0 is offline   Reply With Quote
Old 05-17-2007, 11:26 PM   #161 (permalink)
mooseman0's Avatar
Trader Rating: (18)
so that main post of this is to move the sensor out of the inside of cat to get that reading??? also i am stage 0 i need to know cause i need to fix my car b4 i get pissed and trade it in
Old 05-18-2007, 09:26 AM   #162 (permalink)
VanillaXtract's Avatar
Member Number: 27205
Trader Rating: (33)
Yea, you move the sensor further away from the pipe so that you are getting less exhaust gas hitting the sensor. That way it is getting a drop in O2 just like if there was a cat there.
ANTI-SWEETS CLUB MEMBER # 6
If life was easy, it'd be called "your mom"
VanillaXtract is offline   Reply With Quote
Old 05-18-2007, 11:35 AM   #163 (permalink)
mooseman0's Avatar
Trader Rating: (18)
awesome man appriciate it a lot
Old 05-18-2007, 12:24 PM   #164 (permalink)
Trader Rating: (33)
Good luck, let us know if it works
Old 05-20-2007, 10:25 PM   #165 (permalink)
mooseman0's Avatar
Trader Rating: (18)
ok i didn't do it yet i think im ganna go to garage and do it tonight i will make sure i let ya know how it goes Man i hope it works
Page generated in 0.20093 seconds with 13 queries
