Old 12-07-2007, 10:51 AM   #1 (permalink)
Overboosted's Avatar
Member Number: 46759
Default How-To: Tighten E-Brake
I have replaced my pads on the rear of the car, but my E-Brake does nothing and i mean nothing for me on a hill, i have to leave car in gear, if someone could tell me how to tighten the E-brake that would be swell. Thanks
Overboosted is offline   Reply With Quote
Old 12-07-2007, 10:58 AM   #2 (permalink)
Member Number: 50848
I just did it on my first gen neon, and the mechanics shouldn't be any different. Where the e-brake cables go into the rear brake housing there is a small rubber grommet. With the rear of the car on jack stands it's much easier to get to, and if it's lowered damn near impossible. Take the grommet off and you will see a small gear that can spin up and down. Forget about the "special tool" the FSM mentions and grab a small screw driver orequivalent shaped tool. spin the tire with one hand start adjusting the gear in one direction until the tire grabs, now back off the gear until right after it lets go. Do the same for the other side and your good...
$0.02...
Steve
2005 Black Dodge Neon SXT MTX - Poly Bushings, Progress Rear/SRT Front Sways, Mopar Rear Tension Struts/Lip Kit, SRT Radio Bezel/Guage Cluster, Booger Bushings, Billet Shifter Mounts, SRT STS
1995 Canadian Sport Coupe (Dark Green) Under Construction - Poly Bushings, Eibach Sways, Filled Mounts, Vitor Bobble, No Carpet/Rear Seat/Sound Deadening (not including Firewall), 3.0 Intake/K&N Filter, '95 Hot Cam, Mopar Performance PCM, 55mm bored TB
SRTMiniMe is offline   Reply With Quote
Old 12-07-2007, 11:00 AM   #3 (permalink)
1LAPSRT's Avatar
Member Number: 38267
Trader Rating: (19)
You will most likely need to adjust the brake SHOES inside your rear rotors.
Take off the rear rotor so you can see and get a better understanding of how it works. There will be a "starwheel" in the middle above the spindle. Turn the starwheel so that the shoes are being pushed away from each other and try to refit your rotor. When you have to wiggle it (the rotor) to get it over the shoes, then you are pretty close.
Further adjustment can be done through a hole in the backing plate for the brake "drum". You should be able to spin your tire by hand (w/ medium force) and get two revolutions out of it.
Let us know how it goes!
Heading for a new track? Just want to improve your times at a track you already run?
Old 12-07-2007, 11:23 AM   #4 (permalink)
thanks guys both a great help to a novice dealing with cars, know how to do some small stuff but dont like to take chances on my baby ...
Old 12-07-2007, 11:34 AM   #5 (permalink)
MonsterLemon's Avatar
Member Number: 48761
Trader Rating: (40)
Mine is the same way it doesnt work so I bought some shoes awhile back. When I took everything apart to swap the rotors my shoes were brand new still. So I definitely need to adjust mine maybe when the rain clears up.
MonsterLemon is offline   Reply With Quote
Old 12-07-2007, 12:03 PM   #6 (permalink)
1LAPSRT's Avatar
Trader Rating: (19)
In theory the parking brake shoes should last FOREVER! They are "thoeretically" only used to hold your car stationary and therefore should not have any wear factors applied to them.
Old 12-07-2007, 01:39 PM   #7 (permalink)
SRToc Member
stunuts04's Avatar
Member Number: 20511
all in theory....
SRTOC #740 2007 One Lap Media Noob
stunuts04 is offline   Reply With Quote
Old 12-17-2007, 07:49 PM   #8 (permalink)
projectNEON's Avatar
Member Number: 10290
Trader Rating: (33)
Unless you are drifting with your car haha
Best 1/8th: 8.205 @ 84.95 Best 1/8th MPH: 86.37
projectNEON is offline   Reply With Quote
Page generated in 0.21229 seconds with 11 queries
