Old 09-09-2008, 10:09 PM   #61 (permalink)
TheOne&Only's Avatar
Member Number: 58780
ok well i final got up the courage to take of my bop and i found that there was not gasket on it so i made one and put it back on (I now know the nightmare of the 3rd bolt) and it dosnt seem to be leaking whe im driving but when i try the tester large amouts of air still pour out of it. how do i keep the bop closed to test it i tried key cycling.
s1, kinetic wga, AEM EBC, MPx FMIC, K&N CAI, 180 T-stat, Rims & tires 225/45/18, DCsports catback(with resonator removed), mopar BOV, STS, $20 catch can, Eibach Pro-Street-S Coil-Overs, CBD Viper hood.
http://www.youtube.com/watch?v=TUhHSem5-3I
Next up AGP Stage 4
The best modification you can ever make to a car is a better driver
TheOne&Only is offline   Reply With Quote
Old 11-10-2008, 08:11 PM   #62 (permalink)
Pomz23's Avatar
Member Number: 64878
Trader Rating: (19)
something is not right, i tryied this and it was leaking out of the vents of all the solinoids. are my solinoids bad?
Metal Werkz - For Sale: New Custom Aluminum Door Sills and Radiator Shrouds!!!!!! Click here for my site.
Pomz23 is offline   Reply With Quote
Old 06-20-2009, 09:45 PM   #63 (permalink)
orator3's Avatar
Member Number: 71108
subscribed for some good info.
IT MIGHT BLOW UP BUT IT WONT GO POP...
orator3 is offline   Reply With Quote
Old 07-25-2009, 09:38 PM   #64 (permalink)
Member Number: 31038
Trader Rating: (50)
Take off oil cap during boost leak test to relieve crank case pressure and not blow crank/cam seals?
raul-01 is offline   Reply With Quote
Old 08-13-2009, 02:09 PM   #65 (permalink)
Flaco3o5's Avatar
Member Number: 70186
i boost leak tested my car and capped off the driver side valve cover that connects 2 the intake and i can hear and see little bubbles coming out of my oil cap and it leaks a little bit of oil is that always the case of boost leak testing srt-4s?
Flaco3o5 is offline   Reply With Quote
Old 10-19-2009, 03:59 PM   #66 (permalink)
JoMain's Avatar
Member Number: 73476
Default blue plate
i replaced my gasket on the blue plate and i am still getting air pouring out of the holes on the plate, key cycling to no effect, do i need to run the car around a little bit first?
MSD Coil, MM Inserts, Billettech CC, Kinetic WGA, NGK's, Water Leak Mod, Rice Plate
JoMain is offline   Reply With Quote
Old 10-19-2009, 04:58 PM   #67 (permalink)
JoMain's Avatar
My surge valve is leaking hardcore... any sellers of this item?
Thanks!
Old 10-20-2009, 05:57 PM   #68 (permalink)
datadave49's Avatar
Member Number: 39365
Hey Hey
Guys you should only have no more then 20 psi going in to the test.When I made my pvc tester we bang it on the shop floor and then tried to take it apart and could so we put it on add the air wow did we have leaks as I found and fix them the sound started to stop then bang apart it came LOL.Well we ran to home depot for pvc glue put it back together and found the rest of the leaks.we just install a larger intercooler and it time to check to see if we have any leaks
Dave
Have Fun
2000 neon with a 05 SRT drive train with a S1 Pcm More to come
http://www.cardomain.com/ride/2351649
http://datadave49.tripod.com/datadavenewtoy
datadave49 is offline   Reply With Quote
Old 10-20-2009, 06:02 PM   #69 (permalink)
SRTforums Junior Admin
stowaway's Avatar
Member Number: 3286
you didn't use glue in the first place? wow.
Old 10-20-2009, 08:41 PM   #70 (permalink)
JoMain's Avatar
dont forget the primer!
Old 11-03-2009, 04:15 PM   #71 (permalink)
Member Number: 64577
Any answer to this question?
STILL GH3Tt0 is offline   Reply With Quote
Old 11-03-2009, 11:59 PM   #72 (permalink)
Member Number: 74486
i read this all so far so if done right should it hold the pressure or does it still leak from some were?sorry im new to this stuff lol.
crackerzach is offline   Reply With Quote
Old 11-04-2009, 06:15 PM   #73 (permalink)
datadave49's Avatar
Hey Hey
If you get it right you will find all your leaks.When we made our tester we could not find my PVC glue so we just use a hammer and a block of wood to put it together and started to find my leaks at 20 lbs after we fix about 4 leaks pow and the tester blow apart so we went to home depot for more glue and put it back together and found a few more leaks so go slow and you an get it to work but use glue and not a hammer LOL
Dave
Old 11-04-2009, 06:50 PM   #74 (permalink)
OCTANESRT420's Avatar
Member Number: 50299
sounds like you guys need a new oil cap..
OCTANESRT420 is offline   Reply With Quote
Old 11-05-2009, 10:56 PM   #75 (permalink)
Flaco3o5's Avatar
are u able 2 find out while performing a boost leak test if the PCV valve leaks?
Page generated in 0.20338 seconds with 13 queries
