Old 04-10-2007, 02:23 PM   #31 (permalink)
srtkidd's Avatar
Member Number: 37352
I see so I can pick up one at a walmart how much ones at walmart or target runfor??? thanks for the help toO!
yEs that was mE pasSing you..and nO i do not havE the abiLity to slow down timE..im juSt that boOstn!!!
srtkidd is offline   Reply With Quote
Old 04-10-2007, 03:08 PM   #32 (permalink)
SRTforums Junior Admin
stowaway's Avatar
Member Number: 3286
anything under $150 is going to be pretty crappy. won't last long, won't flow enough cfm. you can find decent deals though. Just keep in mind the specs for the tool you plan on using.
Old 04-10-2007, 03:33 PM   #33 (permalink)
Member Number: 32177
Trader Rating: (12)
can someone pm me on how to build a tester?? PLEASE thanks, or direct me to a link that there is one to build..PM me please thanks
Stock and 4 SALE!
blknite22 is offline   Reply With Quote
Old 04-10-2007, 03:43 PM   #34 (permalink)
stowaway's Avatar
Member Number: 3286
GLHS's second gen Boost leak tester how-to / parts list
Old 07-12-2007, 12:51 AM   #35 (permalink)
conroy9940's Avatar
Member Number: 46401
Trader Rating: (114)
having a problem.. i got a DAS leak tester.. and it reads 0 and wont go up as im doing the test.. my BOP is leaking because its warped and i got a new one in the mail.. i need some help!
Pittsburgh Penguins 16-8-0 32 points
Old 08-15-2007, 05:28 PM   #36 (permalink)
silvrsrt's Avatar
Member Number: 50533
has anyone had a boost leak in one of their fuel injectors? i pressurize the system to 20-25 like stated and the only place i got air coming out is the far right injector. i know it is that cause if you wiggle it you can hear the hiss change. im thinking it's a bad o ring on the injector but im not sure. any suggestions?
silvrsrt is offline   Reply With Quote
Old 08-16-2007, 11:21 AM   #37 (permalink)
conroy9940's Avatar
get a new o-ring for the injector and you'll be good togo
Old 09-05-2007, 10:51 PM   #38 (permalink)
Member Number: 31038
Trader Rating: (50)
Quote: Originally Posted by jaymzx
I've heard that you need the key turned with the Mopar BOV plate to enable the solenoid that equalizes the pressure on both sides of the diaphragm in order to keep it from 'blowing off'.
Fact?
So since I have the AGP bov plate I need to turn it, to the On position? But then I will get the overboost code? Just reset the computer afterwards right?
raul-01 is offline   Reply With Quote
Old 09-20-2007, 10:16 PM   #39 (permalink)
indian srt-4's Avatar
Member Number: 40634
Fact?
i have the mopar BOV plate and i turned it to the on position and i did not get a over boost code. all of the air came out of my mopar BOV in less than 2 sec tho
Mods:Goldline//Maddog//Pwerks//Forward Motion//Diablo//Mopar//Needswings//VVME\\
indian srt-4 is offline   Reply With Quote
Old 09-21-2007, 06:35 PM   #40 (permalink)
jaymzx's Avatar
Member Number: 278
Trader Rating: (12)
I had to key-cycle my car a few times to get my Mopar BOV to seal completely. I no longer have a Mopar BOV installed. Not because it leaked but because it was annoying after 70,000mi.
James NWSRT-4
READ AND LEARN:
Old 05-06-2008, 08:12 PM   #41 (permalink)
datadave49's Avatar
Member Number: 39365
Hey Hey
Help we got leaks at the intercooler but we can't get it to stop the tigher we get the clamp the more it leaks what am I doing wrong
Dave
Have Fun
2000 neon with a 05 SRT drive train with a S1 Pcm More to come
http://www.cardomain.com/ride/2351649
http://datadave49.tripod.com/datadavenewtoy
datadave49 is offline   Reply With Quote
Old 05-08-2008, 07:42 AM   #42 (permalink)
RUgoinUp's Avatar
Member Number: 181
Trader Rating: (33)
It could be that the hose isn't sitting flush. Or if the hose has a leak, replace it with a new hose, and replace the worm clamp with a T-Clamp as well.
RUgoinUp 2 Heaven? Ever lie, steal, dishonor your parents, commit adultery, use God's name in vain? Those are only 5 of the 10 Commandments. Breaking one condemns you to Hell. Claiming to be a good person won't work in a court of law, nor will it when you stand before God. If you want Heaven, admit you're guilty and ask God to forgive you solely on Jesus' death on a cross. Then love God with all your heart, and love people too.
RUgoinUp is offline   Reply With Quote
Old 05-08-2008, 07:03 PM   #43 (permalink)
crazyrob4's Avatar
Member Number: 63252
hey thanks bro this helps alot i hope im not leaking
crazyrob4 is offline   Reply With Quote
Old 06-29-2008, 02:15 AM   #44 (permalink)
TheOne&Only's Avatar
Member Number: 58780
hey just wanted to make sure when u test the boost you use the in car boost guage to see what pressure is in the system right?
s1, kinetic wga, AEM EBC, MPx FMIC, K&N CAI, 180 T-stat, Rims & tires 225/45/18, DCsports catback(with resonator removed), mopar BOV, STS, $20 catch can, Eibach Pro-Street-S Coil-Overs, CBD Viper hood.
http://www.youtube.com/watch?v=TUhHSem5-3I
Next up AGP Stage 4
The best modification you can ever make to a car is a better driver
TheOne&Only is offline   Reply With Quote
Old 06-29-2008, 11:19 AM   #45 (permalink)
jaymzx's Avatar
Member Number: 278
Trader Rating: (12)
Yea it's easier to have two people do it. Someone in the car to read out the boost level and the other to run the leak tester. Alternately, you can have a pressure gauge on your air line while pressurizing.
Page generated in 0.17451 seconds with 13 queries
