Old 10-22-2005, 12:54 PM   #1 (permalink)
flaguy's Avatar
Member Number: 18836
Trader Rating: (24)
HOW-TO: Test for Boost Leaks
MODERATOR EDIT: Info on how to test for boost leaks is a few posts down. Link to thread on how to make boost leak tester is: GLHS's second gen Boost leak tester how-to / parts list
I need to know how to test for boost leaks, I mean the actual procedure on how to do it. I have the Mach V Motorsports leak tester with adapter hose so I can use a bike pump. My pump has a PSI gauge on it and I'm Stage2 so I'll probably pump it up to 20Psi. Any tips, do's or don'ts. Car on or off? Hook me up. Thanks.
flaguy is offline   Reply With Quote
Old 10-22-2005, 06:09 PM   #2 (permalink)
silentwig's Avatar
Member Number: 30755
Trader Rating: (43)
Here is what a boost leak tester can look like. (Mach V Motorsports leak tester)
Steps.
1. Remove the air inlet hose off the turbo inlet (there's a clamp holding on the inlet hose; remove that)
2. Attach your leak tester to the air inlet
3. Pressurize the system
4. Once you hit 20-22 psi ( which is a good number under your circumstances btw) If you don't hear any leaking air, you prob ok, but if you want to be 100% certain, take some soap water and spray it on the "hot spots" ie. the turbo outlet, cold side pipe, etc. I'm sure you know the rest.
5. Tighten clamps where leaks exist.
6. Re attach the air inlet hose
7. Your done.....easy as cake
-silentwig-
I got a catch can ya d bags
silentwig is offline   Reply With Quote
Old 10-22-2005, 07:05 PM   #3 (permalink)
Hi N Mity's Avatar
Member Number: 33036
Trader Rating: (40)
shove a 3/8 socket extension inside the tube that goes to the airbox and the tube that goes into the intake. I think it says 3/8 on the elbow. also, there is a sticky at the top of the srt dealer/service problems area.
Old 01-03-2006, 12:58 AM   #4 (permalink)
silentwig's Avatar
Trader Rating: (43)
Dont forget to cap off the black hose which connects to your air intake since that will leak air fast without if being capped
Old 01-03-2006, 01:04 AM   #5 (permalink)
Member Number: 11681
Trader Rating: (96)
its way easier with a air compresser
2nd Fastest stock turbo no n2o in the country.
Best 60 1.662
Best 1/8 7.55/93
Best 1/4 11.865/116
Best MPG 28.1 city/33 highway
3147 7.49/102 11.51/124 so far 28psi
3147 7.26/100 22psi pump full int
Old 01-03-2006, 04:40 AM   #6 (permalink)
glhs837's Avatar
Member Number: 215
I'm not sure how its possible without one. No matter whos tester you use, your going to leak past the throttle plate.
Old 01-03-2006, 03:06 PM   #7 (permalink)
silentwig's Avatar
Trader Rating: (43)
Yeah, i dont undersand why people claim to use a bike pump and that it works well...I always thought that was a load of crap.
Old 04-16-2006, 10:38 PM   #8 (permalink)
moltenice's Avatar
Member Number: 6528
Trader Rating: (24)
I tried to test my car and a friends car.. it wouldnt go above 7psi on both cars........
When I began to test the car, I noticed the WGA arm moving out as it built pressure.
But anyways, yeah both cars wouldnt go past 7psi....... kind of weird, and ideas?
moltenice is offline   Reply With Quote
Old 04-17-2006, 06:20 AM   #9 (permalink)
tinytunes's Avatar
Member Number: 12416
Well when i do it i push the gas tothe floor is that a bad thing? Figuring in thta you need to open the throttle plate, i am s3 i can only get it up to 14 lbs and wont build an higher pressure, so should i test with my foot of the pedal? I know i have a leak i am only spiking 19 and holding like 17. Any ideas.
tinytunes is offline   Reply With Quote
Old 04-17-2006, 05:21 PM   #10 (permalink)
moltenice's Avatar
Member Number: 6528
Trader Rating: (24)
I wouldnt open the throttle
Old 05-19-2006, 06:26 AM   #11 (permalink)
Ghowie's Avatar
Member Number: 33090
Trader Rating: (55)
It leaks past the tb anyways it's not a total seal there.
Ghowie is offline   Reply With Quote
Old 10-20-2006, 02:33 PM   #12 (permalink)
akmrue's Avatar
Member Number: 46876
Trader Rating: (13)
could someone give me a parts list of the boost testers above? btw i have a compressor... so the nipple would be the same right?
SRT IS SOLD
PERFORMANCE
AEM SRI/MSD 8.5mm Wires/3'' Needswings DP/MPx 3'' o2/Maddog STS/180 T-Stat/MPx FMIC/PTP WGA 17/15/PTP Check Valve/Street MM Inserts/Greddy Type-S/NGK 4306's .35 Gap/AEM WB/Map Clamp
ALL PARTS ARE FOR SALE!!!!
DYNO 9/1/07:
248whp & 289wtq (15psi) MUSTANG DYNO
akmrue is offline   Reply With Quote
Old 10-21-2006, 10:51 AM   #13 (permalink)
akmrue's Avatar
Trader Rating: (13)
so do you turn the key to the on position or no?
Old 10-27-2006, 11:06 PM   #14 (permalink)
silentwig's Avatar
Trader Rating: (43)
no.
i made a tester a long time ago. ill get some pics up of it soon.
Old 02-15-2007, 07:59 PM   #15 (permalink)
jyndrus90's Avatar
Member Number: 22464
wait so u dont put the key into the on position? I always thought it was to be in the on position is it ever supposed to b in the on position while doing a boost leak test?
GT3076r at 18/22psi varying Stage 2 SCT RC650cc
Walboro 255 3" dump NDE TCS AGP Returnline TurboXS MBC AGP Hardpipe w/ HKS Maddog STS Tein SS AGP MM's Aeroforce Tech Gauge AEM Wideband SB STG 3 clutch
jyndrus90 is offline   Reply With Quote
Page generated in 1.07211 seconds with 13 queries
