I was looking around and haven't seen one yet, so I figured I'd post pics of how I did mine.
First off, parts needed:
*extra gauge pod
*2 screws
*Drill or dremel
*Marker or Sharpie (to mark where your holes need to be drilled)
*Razor blade
*Screwdriver
1. Take the four (4) screws out of the top of the dash. 2 (two) on the sides of the dash and 2 (two) on the top near the defroster vent.
2. Take out your A-Pillars, but be careful not to break the clips they're very fragile!
3. After you have the A-pillars out, pull out the top of the dash.
4. You're gonna have to modify your extra pod to sit flush against the dash pad, so with a razor blade or dremel(which I used) you'll have to cut off the little plastic "finger" that's on top of the gauge pod.
before: after:
5. After you do that, line up your gauge pod where you want it to sit on the dash and mark it either with a marker or u can do it the way I did, with a screwdriver.
6. Next, take out your drill or dremel and drill a hole(s) where u marked the dash. Keep pushing (lightly) until the drill bit goes all the way through. After you make your hole, I would suggest taking the razor blade and cutting away the excess plastic you will probably have around the hole(s) u just made.
*I suggest drilling one hole at a time, that way you can line up the gauge pod the way you want to so you can read the gauge clearly*
7. After you do that, I would go ahead and mount the gauge you're using into the gauge pod and mount the pod onto your dash pad.
My name's Jason.....and I drive a neon 13.3 @ 105 1/4 time myspace fs:4-lug 16's
so using this technique, you didn't have to cut part of the dash right? all you had to do is drill a whole? the other how to's show to cut off some of the dash so the gauge pod will fit.and i didnt want to cut it. but this seems different. let me know. btw, good job
You don't have to cut the dash for this one but you are drilling a hole in it anyway so really not saving the dash anyway. The gauge pod also looks like it will be at a different angle than the stock pod. I guess this would be a little bit quicker than the pdf one that has been used before. You have any pictures of the pod with a gauge installed? Here is the link to the other one also courtesy of Speed and Power Development extra gauge pod
It does sit at a different angle, but imo it seems to be a little easier to see w/o the steering wheel getting in the way. I think I accidentally erased the picture I had posted where I took a pic from the driver's seat. When I find it, I'll rehost it
RUgoinUp 2 Heaven? Ever lie, steal (big or small), commit adultery (in deed or thought), use God's name in vain? Those are just 4 of the 10 Commandments, breaking just 1 condemns you to Hell. Claiming to be a "good person" won't work in a court of law, nor will it when you stand before God. If you want Heaven, admit your guilt, and ask God to forgive you solely on Jesus' death on a cross. Then love God with all your heart, and love people too.
