Old 07-12-2008, 05:38 PM   #1 (permalink)
Member Number: 54038
Default How-To: Sea Foam Motor Treatment
MODERATOR EDIT:
Quote: Originally Posted by evo77 View Post
Good info below found on another forum...
Sea Foam used (as directed) in crankcase oil dries moisture and re-liquefies old oil residue. Sea Foam can be used as a pre service cleaner and as an after service additive with no affect on plastics, composites, aluminum, steel, gaskets, seals, or any other manufacturer supplied component.
See the attachment to this e-mail
You can NOT run any engine crankcase on pure Sea Foam, even though Sea Foam is 100% petroleum blended oil. A premium QUALITY oil, Sea Foam was not engineered to supply the film strength of a (made for) crankcase-use oil, like Mobil 1 synthetic or your basic Valvoline, Havoline or Pennzoil does.
When Sea Foam is applied to crankcase oil at 1 1/2 ounces Sea Foam per quart of crankcase oil (see product container), Sea Foam DOES NOT affect the viscosity or lubricating properties of that crankcase oil to which it is applied, including synthetics and blends.
Please see the attached reference sheet on using Sea Foam in Oil.
Thank You
dink Davis
Technical Services Manager
Sea Foam Sales Company
Minneapolis, Minnesota
They also attached the following info as a Word Document to the email:
Sea Foam Motor Treatment used in Crankcase oil
All Gasoline and Diesel, Rotary style engines
Sea Foam may be used in an oil crankcase 2 separate ways, depending on your needs and expectations.
Sea Foam is most commonly used as a pre service old oil residue cleaner and moisture drier, and is also used as an after service additive.
1. As a pre service cleaner for residue, sticky rings or valve train noise, put 1 ½ ounces of Sea Foam Motor Treatment into the engine oil crankcase for EACH quart of oil capacity including filter. Drive a MINIMUM of 30 minutes/miles, MAXIMUM 100 miles, then do your oil change service (LOF). This begins the process of safely/slowly re liquefying the old oil residue so contaminants may flow and be filtered. This also makes your old oil dirtier, quickly, so a LOF service is necessary when the oil gets dirty.
2. As an after service additive into fresh oil, nearly fresh oil, or oil (used condition) that is NOT ready to be changed (by mileage), put the same amount as above, then SELF SET a program to MONITOR your oil for color and clarity on a mileage, timed, or event basis (like every time you add fuel, etc.) to determine when an oil service is necessary.
Sea Foam will safely and slowly re liquefy old oil residue, so it will probably make your oil need changing BEFORE your normal scheduled LOF service. Only your monitoring of the oil for color and clarity can tell when it is time to do oil service, or 3,000 miles, whichever comes first.
Check your oil level and monitor the color for needed service!
Change your oil when it gets dirty!
Joshlax27 is offline   Reply With Quote
Old 07-12-2008, 06:12 PM   #2 (permalink)
Ragin_SRT's Avatar
Member Number: 42510
Trader Rating: (42)
unplug the hose coming from the pvc into the intake mani & pour in 1/4th of the seafoam bottle then let it sit for a min or so, then plug the hose back in and start the car,let it burn until you don't see any white smoke and that's it........as far as the rest of the bottle you can pour into the gas tank........hope it helps you out
Crane 14's
Ragin_SRT is online now   Reply With Quote
Old 07-12-2008, 06:27 PM   #3 (permalink)
evo77's Avatar
Member Number: 1346
Yeah what he said but here is a more thorough step by step for those of you out there that are challenged...
1. start car
2. remove rubber PCV hose from hard line (opposite end of PCV valve)
3. use a styrofoam cup and pour 5.3 oz of Seafoam into the cup
4. you can either dip the PCV hose into the cup so that it sucks the liquid up a little bit at a time or pour it slowly into the hose (make sure to keep the car from stalling)
5. shut off car
6. wait 5 minutes
7. re-install PCV hose
8. turn car back on
9. watch white smoke pour from exhaust
10. take car for a spirited drive with a few WOT pulls
11. done
S2 no toys, Mopar bov, AGP bfmic, 3" turboback
Old 07-12-2008, 09:27 PM   #4 (permalink)
Ragin_SRT's Avatar
Trader Rating: (42)
1. start car
5. shut off car
6. wait 5 minutes
7. re-install the hose
8. turn car back on
11. done
forgot one step (re-installing the hose).......I fixed it for you
Old 07-12-2008, 09:30 PM   #5 (permalink)
bpsrt4's Avatar
Member Number: 40796
Trader Rating: (29)
Do it to an older car w/ a ton of miles on it...it smokes even more
I only got one big puff of smoke and that was it on my srt
bpsrt4 is offline   Reply With Quote
Old 07-12-2008, 09:36 PM   #6 (permalink)
Ragin_SRT's Avatar
Trader Rating: (42)
I barely had any in mines but on my wife's car.....well it looked like the car was a heavy smoker
Old 07-12-2008, 10:05 PM   #7 (permalink)
evo77's Avatar
Member Number: 1346
Old 07-13-2008, 12:45 AM   #8 (permalink)
Plan on doing this tommorow, thanks guys. I wanna put some in my gas tank. Can I do it at the same time that I do the intake manifold? Or do I have to pour it in, wait, run it, drive it, THEN repeat with gas tank?
Old 07-13-2008, 01:13 AM   #9 (permalink)
COY
COY's Avatar
Member Number: 35663
Trader Rating: (41)
I thought you put it in your oil and your fuel tank as well.
Quote: Originally Posted by Flame View Post
Coy is and always will be at least 99% better then me on my best day
PTP = ignored
COY is offline   Reply With Quote
Old 07-13-2008, 01:25 AM   #10 (permalink)
fr33fir3's Avatar
Member Number: 54378
I think you add it to your oil like an hour before you change it drive around with it in there and it breaks down the deposits and sludge.
fr33fir3 is offline   Reply With Quote
Old 07-13-2008, 05:56 PM   #11 (permalink)
Ragin_SRT's Avatar
Trader Rating: (42)
the whole bottle in the oil or you can do half on the oil & half on the tank (depends on you)......as far as the pcv method.......just follow the instruction either on the label or the on here
after you shut the car down & reconnect the pcv hose you can pour the rest in the tank
Old 07-13-2008, 08:48 PM   #12 (permalink)
VanillaXtract's Avatar
Member Number: 27205
Trader Rating: (33)
Correct way to use Seafoam?
I followed the How-to on the LS1 website. There is a pic of the smoke trail I left in the above thread.
ANTI-SWEETS CLUB MEMBER # 6
If life was easy, it'd be called "your mom"
VanillaXtract is offline   Reply With Quote
Old 07-13-2008, 09:27 PM   #13 (permalink)
bpsrt4's Avatar
Trader Rating: (29)
Seafoamed my Escort today...holy shit that was a lotta smoke. Seems to run a bit better now too
Old 07-13-2008, 10:02 PM   #14 (permalink)
evo77's Avatar
Member Number: 1346
Thank You
dink Davis
Old 07-14-2008, 05:36 AM   #15 (permalink)
Trader Rating: (33)
awesome info!
Page generated in 0.21966 seconds with 13 queries
