How-To: Roll Fenders for $15 - Dodge SRT Forum
post #1 of 34 (permalink) Old 10-21-2007, 01:21 PM Thread Starter
BTR
BTR's Avatar
Quoted: 0 Post(s)
Is your car slammed?
Do your tires rub against your fender?
Are you horny as shit right now?
Is your tire being shredded by your fender because you are just too damn low?
Does your fender look like this?
then you probably need your fenders rolled
http://www.rollyourfender.com/instruction.html
thats how you roll your fenders....
assuming you coughed up the 250-300$ purchasing a fender rolling tool or the 100$ to rent it.
I saw one of the tools the other day and thought to myself why the hell cant I make something to roll my fenders to make my wide (wider than stock) rims fit without f**king shit up!
well I went to HDR (home depot racing) and bought some 2 inch pvc piping along with 2 pipe connector clamps (ran me a total of about 15$)
here's what I got
and you'll need something to heat the fender with, preferably a HEAT GUN, you can use a hair dryer on high of you want but the heat gun will make it less likely for cracks in the paint.
BTR is offline
post #2 of 34 (permalink) Old 10-21-2007, 01:24 PM Thread Starter
BTR
BTR's Avatar
Quoted: 0 Post(s)
take the rubber piece inside the clamps out.
turn them inside out then cut the extra plastic on the inside so i can fit around the pvc piping.
like so.
BTR is offline
post #3 of 34 (permalink) Old 10-21-2007, 01:27 PM Thread Starter
BTR
BTR's Avatar
Quoted: 0 Post(s)
get some KY jelly and put those plastic pieces on the pvc piping...
BTR is offline
post #4 of 34 (permalink) Old 10-21-2007, 01:29 PM
rlundi86's Avatar
Quoted: 0 Post(s)
rlundi86 is offline
post #5 of 34 (permalink) Old 10-21-2007, 01:31 PM Thread Starter
BTR
BTR's Avatar
Quoted: 0 Post(s)
I found this online (awesome instructions) just ignore the fender liner bolt portion.
here is an image.
the rubber pieces i put on the pvc make it easier on the fender
BTR is offline
post #6 of 34 (permalink) Old 10-21-2007, 01:33 PM Thread Starter
BTR
BTR's Avatar
Quoted: 0 Post(s)
remember when following these instructions, you dont need to raise the wheel of the ground, just jack the car up so the fender is higher, remember to keep applying heat as you roll the fender.
BTR is offline
post #7 of 34 (permalink) Old 10-21-2007, 01:34 PM Thread Starter
BTR
BTR's Avatar
Quoted: 0 Post(s)
BTR is offline
post #8 of 34 (permalink) Old 10-21-2007, 01:37 PM Thread Starter
BTR
BTR's Avatar
Quoted: 0 Post(s)
before....
after....
perfect!!!! remember guys, use HEAT! and the paint wont crack.
BTR is offline
post #9 of 34 (permalink) Old 10-21-2007, 01:41 PM Thread Starter
BTR
BTR's Avatar
Quoted: 0 Post(s)
couldnt do the rear b/c the pvc piping was too thick. The ass end of my car is so slammed that even when the rear is jacked up, there is still not enough clearance between the fender and the wheel.
car is jacked up.
this pic was taken with the wheel off the ground... still no clearance.
failure....
just go out to HDR and get some 1.5inch pvc piping...
good luck guys!
BTR is offline
post #10 of 34 (permalink) Old 10-21-2007, 05:11 PM
endlessheart666's Avatar
Quoted: 0 Post(s)
what did you use for heat?
97 Miata Turbo
endlessheart666 is offline
post #11 of 34 (permalink) Old 10-21-2007, 05:22 PM
Quoted: 0 Post(s)
great how to but i heard a baseball bat works great to. just an idea
AGP wga, 3" tbe no cat, atp upp, hks ssqv, agp returnline, k&n intake, agp dog bone mm, short shifter, greddy tt, safc2, AIS intercooler, 255 fuel pump, b/s chain removed, aem wideband, MSD tach driver, fuel pump rewire.
279 hp
317 tq
fastloudfzr is offline
post #12 of 34 (permalink) Old 10-22-2007, 03:28 PM
msrt4's Avatar
Quoted: 0 Post(s)
the way i did it is just get a grinder with a grinding wheel and and remove all that metal off then with a 120 grit sanding disk smooth it out came out perfect. another thing that has to be done is remove the mudflap and grind that piece of metal from the fender to the car up to the spot welds or remove it completely and then get it welded this would prevent the car from riding the wheel in hard dips
msrt4 is offline
post #13 of 34 (permalink) Old 11-01-2007, 04:20 AM
doc's_srt4's Avatar
Quoted: 0 Post(s)
doc's_srt4 is offline
post #14 of 34 (permalink) Old 11-01-2007, 05:01 AM
you are now legal to enter this establishment
jrmrbcax's Avatar
Quoted: 25 Post(s)
failure....
LMFAO!
jrmrbcax is offline
post #15 of 34 (permalink) Old 11-06-2007, 10:03 AM Thread Starter
BTR
BTR's Avatar
Quoted: 0 Post(s)
Originally Posted by jrmrbcax
failure....
LMFAO!
yah I know... I suck.
I'll leave them like that till I get the new wheels on it.
BTR is offline
User Tag List
Linear Mode Linear Mode
