Old 08-07-2007, 10:26 PM   #1 (permalink)
Member Number: 52280
HOW-TO: Replace Stock Boost Gauge w/ Aftermarket Gauge (VEI)
I adapted and simplified this from this writeup on VEI Systems' website.
Here's the procedure...
The stock boost gauge is on the right side of the steering wheel in this photo...
Remove the A-pillar covers...
Remove the screws on both sides of the dash cover...
Then remove the 2 screws in the dash pad where the center defrost vent is.
Lift carefully, disconnect any wiring connectors and the boost hose, then pull forward... simple!
Thru the windshield, you can see the stock vacuum hose...
With the dash cover upside down, remove the 2 phillips-head screws that secure the pod to the dash cover. Access is easy by just moving the vacuum/boost hose to the side...
The stock gauge can be separated from the pod by removing the two lock nuts...
Remove the vacuum/boost hose from the barbed connector on the stock gauge. Rather than just pulling hard on it, carefully pry/push it off with a small screwdriver or similar...
The VEI gauge is not a perfect fit only because the gauge is not as deep as the stock gauge, and the studs are a little further inboard than the stock gauge...
This somewhat-cutaway drawing better explains the differences between the stock gauge and the VEI gauge. The flat section on the pod with the holes for the stock studs will be called a "mid-plate" for this installation article...
Another drawing explaining the differences. The gauge does not sit all the way on the pod (small gap at "B"), because the stud just barely hit the mid plate at "A". This area will need to be drilled open for the studs to clear...
Here you can see the holes have been slotted open towards the inside, to clear the studs on the VEI gauge...
Trial fitting the VEI gauge to ensure adequate clearance now...
Continued below...
vgauges is online now   Reply With Quote
Old 08-07-2007, 10:28 PM   #2 (permalink)
...continued from above
Wiring: There are only 3 wires to install, and no photos, but it's very simple. Connect a red wire from a proper switched +12V source, which is easiest obtained from behind the fuse panel, or from the front of the fuse panel using an Add-A-Circuit. (The fuse panel is on the driver's side of the dashboard, and accessible when the driver's door is open). Connect a black wire to a proper ground source, such as the bolt just behind the fuse panel. Finally connect a green wire to a headlight wire, either directly at the headlight wiring, or from the headlight switch. The green wire is optional, but if unused, it's better to connect it to ground, such as the case on the gauge. On this car, the removeable dash panel makes for very easy routing from the gauge to the fuse panel.
Vacuum hose: If your car is making over about 25psi, it's recommended you replace the stock vacuum hose with a rigid hose.
This is how the gauge will be secured to the pod... use a pair of 6-32 barrel nuts to secure the gauge. This drawing also shows some washers in place, and don't worry about the gap from the slotted holes, since it's really only on one side of the washer -- it just looks larger here. Instead of the barrel nuts, you can use regular 6-32 tee-nuts which are available for $0.99 per pack of 4 pcs from Home Depot. Any regular hardware store should have these...
In the front left of this photo is the tee nut with the prongs as you would purchase it. On the front right is the tee nut with the prongs removed (just bend them the other way with pliers and they'll break off). BTW, the other nuts in the background are a hex standoff and how it was modified to be a home-made barrel nut.
The upper nut in this photo shows the tee-nut. The lower is the home-made barrel nut.
Mount the gauge and pod back into the dash cover...
Connect the wires to the gauge. Using all 3 of your hands really makes this easy. Then position the dash cover back in place...
All done!!!
Old 08-08-2007, 09:54 AM   #3 (permalink)
cl14715's Avatar
Member Number: 50232
lol damn that car looks familiar
'04 e-blue srt-4
:|| MODS ||: -Drop-In filter :: 10$ catch can
cl14715 is offline   Reply With Quote
Old 08-16-2007, 09:13 AM   #4 (permalink)
You the guy with the 3 hands, right?
Old 08-16-2007, 10:20 PM   #5 (permalink)
cl14715's Avatar
damnit you caught me
Old 01-17-2008, 07:53 AM   #6 (permalink)
Bump for the GB guys who are looking for this.
Old 01-17-2008, 10:31 AM   #7 (permalink)
R/Tony's Avatar
Member Number: 22637
actually he got 4 hands because the other one is holding the camera
Everytime Im tunning a honda I got this error code: P0404: No Torque found !
R/Tony is offline   Reply With Quote
Old 01-18-2008, 06:06 PM   #8 (permalink)
mEasy27's Avatar
Member Number: 25883
Trader Rating: (28)
2004 Flame Red SRT-4
Garret 50 Trim Soon
mEasy27 is offline   Reply With Quote
Old 02-20-2008, 10:37 PM   #9 (permalink)
04SilverFlash's Avatar
Member Number: 53633
Trader Rating: (18)
subscribed
2004 SRT-4 SOLD
2001 T/A WS6
Parts for sale: http://www.srtforums.com/forums/f27/...irrors-437782/
04SilverFlash is offline   Reply With Quote
Old 03-01-2008, 10:48 AM   #10 (permalink)
fredmfk's Avatar
Member Number: 28706
lmao
fredmfk is offline   Reply With Quote
Old 03-08-2008, 08:11 PM   #11 (permalink)
Member Number: 58212
VERY good writeup with nice pics, but you forgot about the 2 Phillips-head screws on top of the dash in the center vent.
Also, if you don't have the means to secure the gauge with bolts due to any number of reasons you can use electrical tape around the outside housing, just behind the bezel, to take up the gap in between the gauge and the housing. Make sure you use enough, but not too much, to be able to press-fit the gauge into the housing.
Nick S is offline   Reply With Quote
Old 03-12-2008, 05:36 PM   #12 (permalink)
Gramaloke's Avatar
Member Number: 810
you say connect the wires... but to what? I see a black and a white on the stock gauge and RED, GREEN, BLACK on the aftermarket. What's the deal-yo?
Gramaloke is offline   Reply With Quote
Old 03-13-2008, 12:28 AM   #13 (permalink)
The writeup was done to assist and supplement the instructions, which are all here... VEI Systems -- Intelligent Vehicle Instrumentation -- Technical Info
Nick S, I didn't do this install (it was someone at VEI) so I am not sure of those screws, but anyone reading this and doing it should figure it out. Thanks. I personally have never been a fan of wrapping with tape, but if it works then cool.
Old 03-29-2008, 01:41 PM   #14 (permalink)
Member Number: 52407
If anyone broke an A pillar clip I've got some
7055 is offline   Reply With Quote
Old 04-09-2008, 09:40 AM   #15 (permalink)
wiggyx's Avatar
Member Number: 58107
Trader Rating: (23)
You forgot to mention the two screws in the dash pad where the windshield defrost vents are. You'll never get the pad off without removing those two screws as well.
edit: Oops, I see someone already mentioned this. Nevermind...
» Search Used Cars
