Not resposible for any misshaps or death from this how to: Blah blah blah
This best I can do since I already did this once and I am now going back to write it up. If I left something out or you need more explanation just ask I'll help where I can.
Tools: 8mm socket 1/4 inch drive and rachet
13mm socket 3/8 inch drive or bigger and rachet
extension for the 13mm
Hammer
A friend
And small straight screwdriver
optional: 2 ohm resistor and electrical tape if you don't want to have an airbag light on.
1) Disconnect battery
2) locate and remove the 8mm bolts on the sides of the srt steering wheel.
shown here..
3) the airbag will come right off. Disconnect the horn and the air bag connectors. A small straight screwdriver may help but be careful with the airbag one they can be tricky and you don't want to brake it in case you ever want to go back to stock.
4) Loosen the 13mm there in the center of the wheel. Run it out till theres about 5 or 6 threads left to go. Now you need your friend.
5) Put your legs up under the wheel and grab the wheel on the sides like you were driving. have your friend put the 13mm socket on the bolt and have them hammer on the bolt while you pull as hard as you can with your arms and push up with your legs. This will help jar the wheel off the column.
I guess you could use a steering wheel puller but not many people have one and this way works. Once its loose take the bolt the rest of the way out and its off.
6) Put the viper wheel on. Run the wires for the horn and airbag through the hole in the wheel. Line the wheel up with the splines and push it on, tighten the 13mm bolt, check to make sure your wires don't get pinched and that the wheel goes all the way down on the column.
7) plug the horn up. It works perfect with the connection on the viper airbag.
DO NOT Plug in the srt airbag connector into the viper airbag as I'm not sure what might happen and it could be bad!!!
8) go ahead and install the viper airbag and tighten the 3 8mm bolts on that. you would be done but you would have an airbag light on in the dash.
So if u don't want that..
9) use the 2 ohm resistor. Put one end into one side of the connector of the srt and one end into the other. Then tape it up so it stays put. Then put the wire out of the way so you can finish. install the viper airbag tighten the 3 8mm bolts around the sides and your done.
10) connect the battery and drive on. just be careful you no longer have a driverside airbag.
