HOW-TO: Remove Balance Shaft Chain - Page 3 - SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum
Old 04-10-2005, 02:33 PM   #31 (permalink)
Member Number: 7088
yes its an extra chain they put in for NO REASON to waste MONEY
adrenalineaiax is offline   Reply With Quote
Old 05-04-2005, 05:40 PM   #32 (permalink)
l3it3r's Avatar
Member Number: 5077
any reason to KEEP it other than noise/vibrations?
Canon EOS 30D|Canon EF 28-135mm f/3.5-5.6 IS
Canon 18-55mm (kit lens), Canon 50mm f/1.8 II
SanDisk 8GB ExtremeIII | Canon 580EX Flash
l3it3r is offline   Reply With Quote
Old 05-04-2005, 05:50 PM   #33 (permalink)
Registered User
Exhaust Depot's Avatar
Member Number: 143
Reason for taking out the assembly is that you have alot less weight in the engine. Its about a good 15-20lbs for the assembly. If you remove the whole assy, i recommend a windage tray, that way you dont have to add 7qts of oil etc to make up for the void. I have some windage trays in stock, aobut 5 units.
On the 2.6L engine i had on my conquest, we ust to pull them out too. Those engiens where pretty big 4 bangers and i did not have much issues with them pulled out.
Exhaust Depot is offline   Reply With Quote
Old 05-04-2005, 06:08 PM   #34 (permalink)
reddy's Avatar
Member Number: 9502
one of the discussions........ Another balance shaft q...please read
still want to know about vibration........ and is this hard to reverse if you decide you don't like it?
thanks for the how to!!
Stock 04' as far as u know!
reddy is offline   Reply With Quote
Old 05-12-2005, 01:51 PM   #35 (permalink)
omniphil's Avatar
Member Number: 538
Ok, I just did this mod, Question for those that have done it...
I removed the lower sprocket that the chain goes around and the bolt that goes thru it to hold the sprocket onto the balance shaft, I removed the chain, I also left of the sprocket and holding bolt, Will that give any issues with oil pressure? I'm assuming the inside of the shaft isnt presurized...
Also i left of the cover plate and bolts, thats probably ok too I think
---This is my kung fu, and it is strong---
---The surgeon general never said anything about smoking the competition---
01' Neon ACR - Turbo (2650lbs - 242whp/226tq) R.I.P. -->http://home.comcast.net/~omniphil/acr/<--
04' SRT-4 Lightweight (2680lbs - 291whp/338tq) -->http://home.comcast.net/~omniphil/acr4/<--
08' Yamaha R1
omniphil is offline   Reply With Quote
Old 05-15-2005, 10:43 AM   #36 (permalink)
l3it3r's Avatar
Member Number: 5077
how involved is this process? meaning, about how long would it take an *average* person to do it?
Old 05-16-2005, 06:18 AM   #37 (permalink)
omniphil's Avatar
Member Number: 538
This was my first time doing it, It took me about 4 hours as I was taking my time. If I had to do it again, probably about 3 hours. Its a very messy job as well.
The power is pretty noticable above 4000 rpms, but the vibration is pretty noticable too, I get vibration in the steering wheel at any rpm, the cars plastic vibrates at times, same with stuff in the glove box. So just a warning for those that think the vibration is not noticable, it definately is.. I even removed my motor mount inserts and that helped a little. The vibration isnt huge, just a minor annoyance...
If I knew how much it would have vibrated before hand I wouldn't have even bother to do it. Just my 2 cents...
08' Yamaha R1
Old 05-19-2005, 11:36 AM   #38 (permalink)
srt4inliny's Avatar
Member Number: 5834
Thanks for letting us know this. I am sorry to make you sound like my guinea pig, but I like to have a smooth running car. I am pretty sure there are other ways to get 10 horses more out of the car.
srt4inliny is offline   Reply With Quote
Old 05-19-2005, 11:53 AM   #39 (permalink)
04bluesmithjuice's Avatar
Member Number: 10189
Your right, there are other ways to get 10 horespower, but the problem you are going to run into, especially if you go big turbo, is the assembly will break under 400+ hp applications. If it breaks, it could do more damage than actually removing it at this point. Plus 10 horsepower is 10 horsepower. Chris Barnett just did it and saved about 16 lbs and also shaved off about .2 of his et, and he is running stock srt4 motor in his 1st gen, stock turbo and stock ecu.
Brian
04 E-Blue SRT-4
Ask yourself one question:
"When you turn your car on, does it return the favor?"
04bluesmithjuice is offline   Reply With Quote
Old 05-19-2005, 11:22 PM   #40 (permalink)
Member Number: 4264
Balance shaft removal results
I posted my results on a different forum.
Basically picked up over 2 tenths in a car that was already running 12.80's.
Chris Barnett is offline   Reply With Quote
Old 05-20-2005, 08:49 PM   #41 (permalink)
Member Number: 7534
These threads are starting to confuse me. When removing just the chain SOME say you must plug the hole and SOME say you dont even need to bother???
I need to do this mod(just chain) and I gotta get this clear in my head??
tksrt4 is offline   Reply With Quote
Old 05-20-2005, 09:04 PM   #42 (permalink)
Registered User
Member Number: 14521
My $.02:
Unless you are on a serious weight reduction crusade, the removal of the balance shaft assembly may not be worth it. We always removed them from the 2.4 engines we drag raced in our old low-9 second Neon, but they are staying in my '04 SRT, which I prize for its overall smoothness.
A subtle fact many overlook about removing the shafts is that it also reduces 'flywheel effect' by reducing the overall inertial requirement involved in accelerating the engine to higher RPM. You see, the emphasis in analyzing effects of a mod tends to always be on HP numbers. Yet, reducing flywheel effect on a traction-limited FWD car can also worsen transient wheelspin issues. Letting the engine rev quicker is not always advantageous when you can barely hook the car to the ground as it is!
With all due respect to Chris' car and the results he observed, with an automatic trans, it is really an Apple, and the SRT-4 is an Orange.
Bill Hahn Jr. is offline   Reply With Quote
Old 05-20-2005, 10:43 PM   #43 (permalink)
Member Number: 4264
Which is why I posted my results and impressions in a totally different thread, and I made sure to clarify my setup differences.
And to tksrt4, if you remove the chain you MUST plug the hole. It doesn't matter whether or not you remove the shafts. You may not have problems at first, but you will eventually if you don't.
Old 05-21-2005, 11:03 AM   #44 (permalink)
Member Number: 873
ok do you need to removed the assembly to plug the hole?? if so id just remove the whole assembly anywayz....what do you plug the hole with??
2005 A4 GTO....intake, headers, exhaust, vtach and nawwwz..
2003 srt-4 SOLD..
blacksrt4u is offline   Reply With Quote
Old 05-21-2005, 11:34 AM   #45 (permalink)
srt4police's Avatar
Member Number: 6575
Hey Guys, that was going to be my next question.
I have the skittle all apart right now. I want to leave the assembly in. I have already removed the chain and the plastic guides.
Heres my question:
WHAT HOLE DO I NEED TO PLUG????
srt4police is offline   Reply With Quote
