Old 04-18-2005, 06:24 AM   #1 (permalink)
Masssilversrt4's Avatar
Member Number: 3905
Default HOW-TO Rear Tension Strut Kit Install
Rear Tension Strut Kit Mopar Part # P4510826
Stock VS/new
What do they do??
Higher durometer bushings virtually eliminates wheel hop under braking for improved suspension control.
Rating 1 -10 For Difficulty
2-3
Tools needed
Jack
1/2" Wratchet
Sockets
21mm Deep
19mm Deep
18mm Deep
15mm
14mm box end wrench
First Jack up rear end of car
Next Remove the Wheel using a 19mm Socket
Next remove the rear 21mm nut from the Tension Strut
I used a impact gun and didn't need to hold the Tension Strut. If you need to hold the Tension Strut you would use a 14mm Open ended wrench.
Once that nut is off take of the washer and bushing.
Next at the other end of the Tension Strut is the bracket for the E-Brake cable
Take the two nuts off 15mm
Once that is off take off the E-Brack bracket and move aside
Next Take off the two studs that hold the Tension Strut to the Chasis.
They are 18mm and you will need a deep socket.
Once that is done you can remove the stock Tension Strut. Repeat the proccess for the new Tension Strut. Torque the chasis studs to 70ft/lbs the 15mm brake line bracket to 250 in/lbs and the rear 21MM Nut to 70 ft/lbs.
Put the wheel back on and torque the Lugs to 95-100 ft/lbs.
Repeat for the other side.
Have fun.
Hell bent on building fast cars!!!
Masssilversrt4 is offline   Reply With Quote
Old 04-25-2005, 06:15 PM   #2 (permalink)
thunder6g's Avatar
Member Number: 12672
Trader Rating: (60)
so these reaplace the stock ones? I assume they make a big diff on auto X but not so much on drag and daily driving?
thunder6g is offline   Reply With Quote
Old 04-25-2005, 07:30 PM   #3 (permalink)
Member Number: 3905
Replaces the stock ones.. helps for braking. Eliminates rear wheel hop on hard braking.
Old 05-17-2005, 02:55 AM   #4 (permalink)
Member Number: 12903
isn't it the same thing as replacing the stock bushings with urethane ones?
red2k2rt is offline   Reply With Quote
Old 10-16-2005, 12:58 PM   #5 (permalink)
Wheat_Burner's Avatar
Member Number: 12004
Trader Rating: (115)
Thanks for the great how-to, Masssilversrt4. People like me that usually fix one thing and break another appreciate the pictures.
Quote: Originally Posted by red_power
dale, for someone who sucks at driving like you you sure do talk alot of shit..noob
Wheat_Burner is offline   Reply With Quote
Old 10-16-2005, 02:24 PM   #6 (permalink)
Member Number: 11820
That makes two of us
Thanks for me also!
[live]Mopar Madness[/live]
Eyeless0486 is offline   Reply With Quote
Old 02-05-2006, 01:46 PM   #7 (permalink)
RUgoinUp's Avatar
Member Number: 181
Trader Rating: (33)
I just used this. Thanks for putting it up.
RUgoinUp 2 Heaven? Ever lie, steal, dishonor your parents, commit adultery, use God's name in vain? Those are only 5 of the 10 Commandments. Breaking one condemns you to Hell. Claiming to be a good person won't work in a court of law, nor will it when you stand before God. If you want Heaven, admit you're guilty and ask God to forgive you solely on Jesus' death on a cross. Then love God with all your heart, and love people too.
RUgoinUp is offline   Reply With Quote
Old 03-06-2006, 12:33 AM   #8 (permalink)
cybr's Avatar
Member Number: 31841
Trader Rating: (40)
The stock tension struts look identical to the new ones... Am I missing something? Should they look IDENTICAL?
Family time Got 50/50 with my kids, couldn't be happier. Good luck in all your endeavors.
Mad Props to PFI, RX, and Kevin Warren!!!
http://myspace.com/cybr
cybr is offline   Reply With Quote
Old 03-06-2006, 12:46 AM   #9 (permalink)
jaymzx's Avatar
Member Number: 278
Trader Rating: (12)
The difference is in the durometer rating of the bushings. They're stiffer.
James NWSRT-4
READ AND LEARN:
Old 03-06-2006, 04:08 AM   #10 (permalink)
Member Number: 22737
you can get the same resaltes from getting urethane bushings and putting them in, I just got the master suspetion kit and man did it make a differance in the handling in the car.....
paragod is offline   Reply With Quote
Old 03-06-2006, 05:23 PM   #11 (permalink)
cybr's Avatar
Trader Rating: (40)
thanks Jaymzx... I'll put them in tonight
Old 05-08-2006, 12:54 PM   #12 (permalink)
XXxx_Totmacher_xxXX's Avatar
Member Number: 9649
Trader Rating: (43)
what bushings? mine look identiocal and have the smae part number, even the numbers stamped on the big forward bushing are the same. I didn't get and bushings for the back part though...
Neon SRT-4 (Mine)
11.431 @ 123.61___600 Hp/500 Tq
Crossfire SRT-6 (Wife)
??.?? @ ???.??___331 Hp/310 Tq
Neon SRT-4 (Red Sled)
9.316 @ 156.50___9?? Hp/6?? Tq
Caliber SRT-4 (Red Shed)
12.079 @ 114.92___568 Hp/504 Tq
XXxx_Totmacher_xxXX is offline   Reply With Quote
Old 05-08-2006, 02:01 PM   #13 (permalink)
jaymzx's Avatar
Member Number: 278
Trader Rating: (12)
Mine had identical part numbers, too. If you feel the bushings at where they attach to the frame rails, there is a big difference. My 03 bushings felt like a pink eraser and the new ones felt like a super bounce ball.
You don't get the bushings that attach to the knuckle. You reuse the stockers. Remember, it goes washer, bushing, knuckle, bushing, washer, nut. I screwed that up the first time and had to climb under and redo one side the next day
Old 04-19-2009, 11:36 PM   #14 (permalink)
05blcksrt's Avatar
Member Number: 66782
went to discount tire today and they had showed me my back tires and i could set the tire on the ground and it wouldent move because of the flat spots on my tires.
Stage 2 W/Toys, Mopar CAI, Mopar BOV
05blcksrt is offline   Reply With Quote
Old 04-20-2009, 12:31 AM   #15 (permalink)
jaymzx's Avatar
Member Number: 278
Trader Rating: (12)
Don't think that's a torsion strut issue.
