Old 05-12-2005, 12:02 AM   #1 (permalink)
distinctdev's Avatar
Member Number: 22976
Trader Rating: (32)
HOW-TO: PCV Leak Fix
PCV Leak Fix: Check Valve
After recent testing, it has been found that the stock PCV system may have a boost leak. To
eliminate this problem, a check valve is installed, inline, between the throttle body and the pcv
valve.
UPDATE:
If you are installing this mod, and already have a catch can, the check vavle should be placed between the Intake Manifold and the Catch can, with the direction of flow like the following
Catch Can ===== > Check Valve ===== > Intake Manofild
Parts Needed:
1 x Valve,Check,3/8 In (Part #5X781)
2 x Brass Hose Barb,3/8 In (Part #6X410)
Source: http://www.grainger.com
Gainger seems to only sell to businesses, if you have a local grainger store they may allow you to open up an account with them
or
1 x Brass Medium-Pressure Spring-Loaded Piston Check Valves (Part #7775K53)
1 x Push-On Brass Hose Fitting Barbed X Male for 3/8" Hose ID, 3/8" Pipe Size (Part #91465K93)
Source: http://www.mcmaster.com/
I recomend any brass check valve over a plastic one, you can see here how my plastic one warped from underhood heat.
Approximately 4ft of 3/8 In Hose
4 Zipties or 4 3/8 In Hose Clamps
Source: Local Auto Parts Store
Steps:
1) Buy the parts.
2) Pop walk outside, unlock your car (skip this step if car was previously unlocked), pop hood.
3) Disconnect both sides of the Stock PCV Plastic Hose.
4) Remove the Stock PCV Plastic Hose, This may be a little tricky but It can be done.
5) Roughly Measure how much of your new hose you need to cut.
6) Cut it in half and install the check valve inline.
7) Reconnect both ends so that the arrow on the check valve points towards the trottle body. You may hide the valve and hose behind the intake manifold for a clean look.
8) Install zipties/hoseclamps on the lines
9) Take the car for a drive, you most likely gained 1-2 psi of boost!
10) Enjoy
R.I.P. Steven Lorenz 04.04.06
MySlips.com
Bench Racing Stops Here.
distinctdev is offline   Reply With Quote
Old 05-12-2005, 07:32 PM   #2 (permalink)
wolf's Avatar
Member Number: 4873
Although it looks pretty simple and easy, there is just something about it is not right. I think a check valk (one way) it ain't design to be there.
Any experts thoughts?
CIRRUS HIGH OUTPUT
Same Engine and HP of SRT-4 right from factory!
wolf is offline   Reply With Quote
Old 05-12-2005, 07:40 PM   #3 (permalink)
thunder6g's Avatar
Member Number: 12672
Trader Rating: (60)
Talking
granger won't deal direct with customers/consumers??
I've been following the thread for this but was kinda waiting for someone to give a easy link to them directly- got any where else we can pick these up?
thunder6g is offline   Reply With Quote
Old 05-12-2005, 07:44 PM   #4 (permalink)
SilverBullet's Avatar
Member Number: 28
I'm confused. Where does it actually leak? I'd figure, if anything, it would leak around the six connecting areas. Is the check valve there to prevent/help the PCV valve to deal with the "back pressure"?
Mods:
- Mean-looking Headlight Stickers (Pat#D0507845)
- Red and Blue buttons
- MaxxFab SEE
- Zipties (and lots of it)
My other avatar.
SilverBullet is offline   Reply With Quote
Old 05-12-2005, 07:48 PM   #5 (permalink)
thunder6g's Avatar
Trader Rating: (60)
there is about a 12-14 page thread on this issue in the performancemods section I think.
Old 05-12-2005, 08:08 PM   #6 (permalink)
Member Number: 28
hmmmmm...
Old 05-16-2005, 05:07 PM   #7 (permalink)
ojcool's Avatar
Member Number: 19382
Trader Rating: (13)
It's a scam! That valve is bronze not gold!!!!!!!!
Heh Heh.
I am trying to pass off my shifter as a Maddog shifter so I can make a quick buck.
ojcool is offline   Reply With Quote
Old 05-17-2005, 07:18 PM   #8 (permalink)
tURBOsetch's Avatar
Member Number: 24746
Nothing wrong with adding the mcmaster valve. The stock PCV valve is a one way valve it just doesn't seal very well so it allows boost to blow by into the valve cover...You can tell if yours is leaking by looking in the air box where the little sponge is...If it has oil on it then your PCV is leaking boost.
Yep. How do it know?
tURBOsetch is offline   Reply With Quote
Old 05-17-2005, 07:52 PM   #9 (permalink)
mdhavi18's Avatar
Member Number: 224
so does this mod completely eliminate the need for an oil catch can?
Never argue with an idiot, they'll just drag you down to their level, and then beat you with experience.
Quote: Originally Posted by BLOO SRT
hi i instl amaxx fab yestoday and i m happy whit it. going to trak on friday.god job maxx fab
Quote: Originally Posted by slow79ford
hmm...if he can install it, I guess I shouldn't have a problem.
mdhavi18 is offline   Reply With Quote
Old 05-17-2005, 08:41 PM   #10 (permalink)
RoostBoost's Avatar
Member Number: 7368
Trader Rating: (72)
subscribing for the best check valve to get.....grainger doesn't sell to the public...
RoostBoost is offline   Reply With Quote
Old 05-18-2005, 12:37 PM   #11 (permalink)
Member Number: 25579
any thoughts on that?
UNCsrt is offline   Reply With Quote
Old 05-18-2005, 12:45 PM   #12 (permalink)
barrr's Avatar
Member Number: 10243
No, they do two different things.
Catch can stops oil from getting into the intake.
Check valve stops boost getting to the valve cover.
Don't argue with an idiot; people watching may not be able to tell the difference.
barrr is offline   Reply With Quote
Old 05-18-2005, 01:47 PM   #13 (permalink)
Trader Rating: (32)
updated
Old 05-18-2005, 03:10 PM   #14 (permalink)
SINYBlueSRT's Avatar
Member Number: 10049
Ok, to clarify, "...You can tell if yours is leaking by looking in the air box where the little sponge is...If it has oil on it then your PCV is leaking boost." If so, then once you fix the boost leak, you should no longer be finding oil in the airbox. Right?
SINYBlueSRT is offline   Reply With Quote
Old 05-18-2005, 04:00 PM   #15 (permalink)
01CBR929's Avatar
Member Number: 20734
Hmmm guys... a PCV is, well... it stands for "positive crankcase ventilation". Not positive valve cover ventilation.
01CBR929 is offline   Reply With Quote
