Old 05-17-2009, 02:46 AM   #61 (permalink)
SystemUpgrade's Avatar
Member Number: 37980
Yea, I did mine last summer 'cause they stopped working. Good write up!!! My only .02 cents is this... When you think that you have it all adjusted right by how much drag you get from the free spinning tire, you need to go do a 20 mph e-brake stop in your street (making sure your thumb is holding down on the button). This is what I did to test the setup, and I'm glad I did. Thing was still only working on one side even though the spin test said it was good. the stop test said it was, FAIL! Tried to go sideways on me!!! When Oh-Shit happens, you can count on the worst when you pull that fucker and the car goes sideways... Just make sure that after you get everything adjusted all nice, you keep at adjusting the offending side till both tires are leaving the same amount of rubber on the road and the car is stopping its self straight... Most important!!!
_O_w_n_e_d______L_i_s_t_
Supercharged Cobalt SS 1
Riced out cars 7
Late 90's Camaro V8 1
Late 90's Mustang GT 1
2009 Hyundai Genesis Coupe 1
Second place in the stock turbo category at the 2009 SRT Nationals!
SystemUpgrade is offline   Reply With Quote
Old 05-25-2009, 12:54 PM   #62 (permalink)
Member Number: 515
Just did this, great write up. Very important to have a long screwdriver, just makes things easier.
Also remember to remove the wheel chokes before trying to drive away I failed that one lol
You have to be angry at life to be creative
-John Leguizamo
"man is the measure of all things." - Protagoras
reason is the only proper guide to the most crucial problem of human existence- the question of good and evil. -socrates
04electricblue is offline   Reply With Quote
Old 06-06-2009, 10:58 PM   #63 (permalink)
3chord's Avatar
Member Number: 70323
Trader Rating: (12)
I'd add this bit of advice first:
Take all that crap out of your console, then unscrew the 4 screws in the pocket, then the two screws in the cupholders in the front. Next, unscrew your shift ball and shift into neutral. pull up the e-brake as high as you can. Now lift the back of the console high enough so you can see the brake equalizer. Make sure that it is pulling both of the cables equally. If it's not, then you're going to need to take off the brake rotor on the side that's not moving right and try working the cable in and out enough to free it up.
In my case, the drivers side was stuck solid until I sprayed the workings of the cable/drum assembly with brake cleaner and then worked the cable several times. After I put it all back together then I was able to adjust both sides. Now my ebrake cable pulls both equally and I confirmed this by a hard yank on the ebrake at 10mph which produced two equal length skid marks.
3chord is offline   Reply With Quote
Old 06-08-2009, 02:49 PM   #64 (permalink)
The Man!!!
Old 06-09-2009, 12:08 AM   #65 (permalink)
groki21's Avatar
Member Number: 69258
I have to try this soon, my car rolls when i have the ebrake up on just a very slight slanted road.
2004 E BlueAGP WGA, Borla catback 2.5, K&N intake, Mopar STS, Drag DR wheels, Tein S techs on Tokico Illumina struts
11lb Kinetik kr 612 lightweight battery
groki21 is offline   Reply With Quote
Old 06-21-2009, 02:38 PM   #66 (permalink)
Member Number: 52407
I did this and it still doesn't grab well enough. How hard is it to replace the E-brake pads?
7055 is offline   Reply With Quote
Old 06-21-2009, 07:07 PM   #67 (permalink)
blackedsrt's Avatar
Member Number: 73370
helps to take disk off and sand inside of drum and the pads
blackedsrt is offline   Reply With Quote
Old 06-21-2009, 08:46 PM   #68 (permalink)
3chord's Avatar
Trader Rating: (12)
drum brake friction material is called shoes. Our parking brake is a set of shoes which sit inside the drum part of the rotor. The shoes are imo very difficult to replace. There are two springs that are used to hold them together and it is very difficult to get the spring back on. I must have spent atleast an hour per side screwing around with the springs.
If they don't grab enough, then you need to tighten the adjuster wheel more. The friction material lasts a very long time. I have atleast 50% left on oem shoes and I've got 109k on the car.
Old 06-21-2009, 11:00 PM   #69 (permalink)
What does sanding them do? And what grit?
Old 06-21-2009, 11:25 PM   #70 (permalink)
3chord's Avatar
Trader Rating: (12)
If they are glazed, it takes the glaze off. I'd use a rough grit anything under 400 if you ask me. Wear a breathing mask if you do it though, you don't want to be breathing that crap.
Old 06-22-2009, 08:09 AM   #71 (permalink)
SRTMIAMI's Avatar
Member Number: 54645
Trader Rating: (12)
subscribed!
GT3076R-AEM EMS-DP VARI-COOL
WWW.MYFLORIDASRT.COM
SRTMIAMI is offline   Reply With Quote
Old 06-22-2009, 09:26 AM   #72 (permalink)
blackedsrt's Avatar
ya what he said....
it roughens up the surface of the disc and shoes and enables them to grab easier instead of two smooth surfaces trying to grab
Old 08-21-2009, 10:24 PM   #73 (permalink)
sareteafour's Avatar
Member Number: 73170
will this not make my ebrake handle not go up so high, or do i adjust the cable its self if so where?
Stage 2, 3bar map/tip, AGP WGA, NGK Iridiums 1 step colder, Walbro 255lph, Mopar CAI, GReddy Catchcan, MSD wires, Stock coilpack, GReddy turbo timer, DC Sports strut bars, Hotchkis sway bars, KW V1, AGP solid mounts.
sareteafour is offline   Reply With Quote
Old 08-21-2009, 11:13 PM   #74 (permalink)
rasp's Avatar
Member Number: 56076
Trader Rating: (21)
Handle will go up to about half of where it does for you now, most likely, and catch very early. Great adjustment. My ebrake was non-existent; now it engages with a few clicks up on the handle. Love it.
Pensi?
Old 08-22-2009, 12:36 AM   #75 (permalink)
sweet cuz my ebrake nearly touches the center console
Page generated in 0.18490 seconds with 13 queries
