Old 07-28-2008, 04:40 PM   #46 (permalink)
Member Number: 64745
my parking brake doesn't work at all....maybe this will fix it
*black05srt4* is offline   Reply With Quote
Old 07-30-2008, 03:55 PM   #47 (permalink)
Zero46's Avatar
Member Number: 20143
Just did mine. Works great now.
Zero46 is offline   Reply With Quote
Old 08-05-2008, 05:54 PM   #48 (permalink)
VanillaXtract's Avatar
Member Number: 27205
Trader Rating: (33)
I did mine and tightened till the wheel was dragging. Backed off so the wheel spun freely again. With the tire still off the ground, I pulled on the parking brake to make sure both wheels were engaging. However, after I release the brake, both wheels were still difficult to turn as if it did not fully disengage. I loosened and repeated. Same results. Anybody have ideas or should I just not engage the parking brake with the tires off the ground?
ANTI-SWEETS CLUB MEMBER # 6
If life was easy, it'd be called "your mom"
VanillaXtract is offline   Reply With Quote
Old 08-08-2008, 08:26 AM   #49 (permalink)
flamingpinhead's Avatar
Member Number: 45953
you mean the wheels wont turn at all after you disengage it? its a pretty fine balance between too tight and too loose. last time i didnt tighten it enough and the brake was still too loose, you may have just overtightened it a bit (or did one wheel backwards which i did when figuring this one out)
flamingpinhead is offline   Reply With Quote
Old 08-08-2008, 09:42 AM   #50 (permalink)
Trader Rating: (33)
No they are just not as loose as when I first set them
Old 08-17-2008, 04:27 PM   #51 (permalink)
N1ck's Avatar
Member Number: 29830
I just did mine today, this helped a lot. Thanks a lot for the writeup. Also this should be noted, when I did mine the star gear that is moved with the screw driver doesn't take much to fully adjust it. I only had to move mine a few turns. Also, be sure to feel how the wheels move (spin them) *BEFORE* you adjust the parking brake, so you know how much they should be turning after they are adjusted. Mine would graze the brake pads very slightly when moved.
04 Silver
N1ck is offline   Reply With Quote
Old 08-20-2008, 01:12 PM   #52 (permalink)
thanks N1ck, hand thought of that. added it to the how-to
Old 08-21-2008, 04:43 PM   #53 (permalink)
Member Number: 64643
Default thanks
thanks alot man!!! my car really needed this i was tired of ripping up the e brake and it not holding!!!! good thread
JGORMAN is offline   Reply With Quote
Old 09-25-2008, 08:00 PM   #54 (permalink)
ivey_usmc's Avatar
Member Number: 62002
Ive needed to do mine for a long time. Good write up!
Build a man a fire keep him warm for the night.
Set a man on fire keep him warm for life.
Semper Fi!
ivey_usmc is offline   Reply With Quote
Old 11-01-2008, 03:36 PM   #55 (permalink)
bluebeast's Avatar
Member Number: 39695
Nice write up. Follow your instructions. Very easy job once you know whaty your looking for!
ROLL RACING isn't racing. It's just 2 homos speeding next to each other!
11.79 @ 118.53 S3 + bolt-on car!
BEST 60 1.68
bluebeast is offline   Reply With Quote
Old 02-08-2009, 01:53 PM   #56 (permalink)
Member Number: 56114
Any tips to get the star wheel to budge? It took me close to an hour but I got the driver side one to move a few turns. After about an hour and a half of jabbing every tool I owned at the passenger side one I had to give up. Would it be ok to spray some wd-40 in there to loosen things up? I'm nervous to take apart the rotor and caliper so I'd like to avoid that route if possible.
ghostfly is offline   Reply With Quote
Old 02-08-2009, 08:59 PM   #57 (permalink)
pmurcyard's Avatar
Member Number: 66762
its funny how such a simple thing is not widely known... i looked cuz i didnt know how to do disc brakes only to learn that its the exact same as it is with the drum brakes on my 84 mustang i just did that one a month ago... now ill do the neon soon (since its a piece of cake)
pmurcyard is offline   Reply With Quote
Old 02-14-2009, 02:58 PM   #58 (permalink)
To answer my own question, a little bit of WD-40 went a long way. Only took me about a half hour to do both sides using a regular screwdriver.
Old 04-29-2009, 08:22 PM   #59 (permalink)
tbillz715's Avatar
Member Number: 65315
Well the other day I parked in a friends driveway with a slight hill. Came back out and my car was at the bottom of his driveway. Yeah now it doesn't move at all, thank you.
05' OB SRT-4
-AGP Motor Mounts
-K&N Short Ram intake
-Halo headlights & fog lights
-More to come soon.
tbillz715 is offline   Reply With Quote
Old 05-17-2009, 12:53 AM   #60 (permalink)
ge_forcez22's Avatar
Member Number: 59151
Was at the track and couldn't get my E-brake to hold me back completely and has been weak on driveways (reverse).
Thanks for the write up I am doing this today!
-Garrett
2004 - SRT4 -Wiseco pistons -Crower rods -Port/Polished head -DCR 272/272 -AEM EMS -RC750 -SMC Watermeth -BFMIC -AGP 60-1 -AGP return line kit -3" MPX with single exit -Eibach Springs - Tokico suspension -ACT 6-puck -DSS stage3 axles -MH 24.5x8.5
-424whp @ 26psi
-12.0 @117mph @ 23psi
ge_forcez22 is offline   Reply With Quote
Page generated in 0.18677 seconds with 13 queries
