Old 09-03-2007, 10:34 AM   #16 (permalink)
With Honor's Avatar
Member Number: 28113
Got inspection coming up, SAFTY. will def. have to be fixing this!
I'll admit I have a little rice in my blood, but come on people there is a line to be drawn!!!!
05 Black SRT-4, bought May 23, 05 From Maine
With Honor is offline   Reply With Quote
Old 09-04-2007, 09:06 AM   #17 (permalink)
With Honor's Avatar
EDIT: ok i read this wrong, and just clicked the star down two times on both sides when i pulled my e brake I snapped up all the way to my center console think this is fixable or you think i broke something?
Old 09-07-2007, 03:45 AM   #18 (permalink)
projectNEON's Avatar
Member Number: 10290
Trader Rating: (35)
Cool my parking brake right now sits all the way to the top almost hopefully doing this will get it clicking near the middle again.
Why not just use a scribe instead of a screw driver?
[IMG][/IMG]
Best 1/8th: 8.205 @ 84.95 Best 1/8th MPH: 86.37 <<< These are so 2005 I need new numbers
projectNEON is offline   Reply With Quote
Old 09-07-2007, 04:26 AM   #19 (permalink)
srt4101's Avatar
Member Number: 38341
Quality write up for sho. I have been meaning to do this for ever.
srt4101 is offline   Reply With Quote
Old 09-08-2007, 11:39 AM   #20 (permalink)
flamingpinhead's Avatar
Member Number: 45953
read more carefully!!! to tighten its up on one side, down on the other
anyhow, glad to see so many found this helpful, im suprised to see this thread still alive and well.
flamingpinhead is offline   Reply With Quote
Old 09-09-2007, 11:59 PM   #21 (permalink)
SNOOPALOOP's Avatar
Member Number: 29605
Trader Rating: (23)
Bump for a very helpful thread
SNOOPALOOP is offline   Reply With Quote
Old 09-16-2007, 01:38 AM   #22 (permalink)
travisanderson's Avatar
Member Number: 53370
i tightened the star up all the way till the tire didnt move then backed it off 2 turns.so there was a hair of resistance... i think this is what he means correct?
and excelleent thread ..the dodge user manual looks like drum brakes... i was liek.. WTF?!?! we have disk brakes.
travisanderson is offline   Reply With Quote
Old 09-16-2007, 01:51 AM   #23 (permalink)
HMS4's Avatar
Member Number: 11228
It has both, regular braking uses the disc, park brake drum is part of the rotor.
HMS4 is offline   Reply With Quote
Old 09-18-2007, 02:05 PM   #24 (permalink)
zero13's Avatar
Member Number: 26886
excellent right up, never would of figured that out with out this thread
thanks
zero13 is offline   Reply With Quote
Old 10-02-2007, 01:58 PM   #25 (permalink)
Member Number: 58040
Quote: Originally Posted by flamingpinhead
Disclaimer: I have provided the following information and pictures out of the kindness of my heart. i assume no responsibility if you mess something up, break something, break your car, injure yourself, somehow die or otherwise f*** something up as a result of reading or attempting this.
What youll need:
- Jack
- Jack stands
- Medium sized standard screw driver
- Some good lighting (trebel light or powerful flashlight)
- Wheel chocks
- Creeper (makes life easier)
Step 1: Park on a level surface, leave the car in gear and leave the parking brake completley disengaged.
Step 2: Chock the front wheels
Step 3: Jack up the rear end of the car, supporting it on jackstands
Step 4: Scoot under the car and locate the oval shaped rubber plug covering the hole accessing the disc brake caliper adapter. Remove them and put them somewhere you wont lose them. (They are located on the inside of the brake assembly at the bottom.)
Step 5: Adjust the left (driver's side) wheel as follows:
A. Inside the access hole, there is a star wheel just above the spring. Use the screw driver, inserting it through the access hole, turn the star wheel downward until a slight drag is noticed when rotating the rear tire.
B. Rotate the star wheel upward no more than 1 or 2 clicks, backing the brake shoe off the drum just enough to allow for rotation of the wheel.
C. Reinstall the oval rubber plug.
Step 6: Adjust the right (passanger's side) wheel as follows (slightly different than the left)
A: Inside the access hole, there is a star wheel just above the spring. Use the screw driver, inserting it through the access hole, turn the star wheel upward until a slight drag is noticed when rotating the rear tire.
B. Rotate the star wheel downward no more than 1 or 2 clicks, backing the brake shoe off the drum just enough to allow for rotation of the wheel.
Step 7: With the wheels slightly off the ground (if you were using a full vehicle lift, which i obvously was not, lower the car)
Step 8: Reach into the car and fully apply the parking brake and release it two times. Fully apply the parking brake once more and leave it engaged.
Step 9: With the parking brake fully engaged, attempt to rotate each rear wheel by hand to ensure the parking brakes on each side are engaging. There should be no movement.
Step 10: Fully release the parking brake.
Step 11: Hand rotate each wheel, ensuring there is no drag caused by the parking brake shoes. (you may need to readjust the brakes as necessary, repeating steps 4 thru 11.)
Step 12: Remove the jackstands and wheel chocks.
hey man can u send these pics to ruvim2011@hotmail.com
ruvim2011 is offline   Reply With Quote
Old 10-02-2007, 02:10 PM   #26 (permalink)
yorad's Avatar
Member Number: 49047
Subscribed so I can find this later. Great work!! Thanks for taking the time to do this!
yorad is offline   Reply With Quote
Old 10-05-2007, 12:52 AM   #27 (permalink)
email sent. glad to help!
Old 10-14-2007, 07:26 PM   #28 (permalink)
Member Number: 54038
OK don't understand what this does..anyone care to explain?
Joshlax27 is offline   Reply With Quote
Old 10-15-2007, 12:36 PM   #29 (permalink)
darthcual's Avatar
Member Number: 36035
Trader Rating: (29)
Another way to do this is too jack up the car, remove the rear tire, then the caliper, and finally the rotor. The Star bolt is much easier to access. Dont adjust to far out or the rotor wont fit back on. Just thought I'd add to this fantastic sticky.
Quote: Originally Posted by Madrex View Post
the internet has ruined me...stills will not do it...has to be video...nasty video
darthcual is offline   Reply With Quote
Old 10-21-2007, 07:30 PM   #30 (permalink)
Member Number: 44087
great post i did this the other day worked great
wicked94s10 is offline   Reply With Quote
Page generated in 0.18970 seconds with 13 queries
