Old 07-01-2006, 03:21 PM   #1 (permalink)
whites97's Avatar
Member Number: 19176
Trader Rating: (36)
HOW-TO: Paint Radio Bezel
Supplies needed:
320 grit sand paper
Colormatched (or whatever color you want) body paint from Mopar
Primer
Clear Coat
Scapel Blade (or for you cheap-o's, a standard razor blade)
Painter's tape (I like the blue stuff)
Your nail
First off... remove the bezel (obviously)
Tape off the areas you don't want to paint and then using your nail, press the tape down around the corners making everything as precise as possible.
Take your razor and cut out the areas that are covered and need to be painted
and then sand it with 320 grit to remove the clear coat. After you've sanded it, take some cleaner (whatever you want really), and remove the loose grit on the bezel. From here, take out your primer, and prime it.
I'm anal retentive and sanded it after I primed it to remove any small bumps. If you're not as crazy as I am... then don't worry about it. You should be fine without sanding again (up to you really). After that's said and done, take out your body paint and give it a few coats.
Once again, I sanded this a little to remove any excessive marks between coats. Not completely necessary. After you get your last coat of paint on, time to whip out the clear coat and add a few layers. The more coats, the shinnier it gets. I added 3... because, well... I wanted to. To remove the tape, DO NOT just yank it off, as you'll peel off some of your freshly laid paint as well. I'd recommend taking your scapel blade and tracing it around the outline of the laid tape and then SLOWLY removing the tape. It should come up nicely.
EDIT:
From here, I decided to take some Zaino Z-5 (Z-2 would've been too shiny in my opinion) and waxed it with two applications, applying Z-6 after each coat. This made the final product even smoother, shinier and slippery!!!
And just for fun... here's a picture of it installed. Enjoy!
I hope this helped,
Dave
whites97 is online now   Reply With Quote
Old 07-01-2006, 03:31 PM   #2 (permalink)
Member Number: 10965
good write up, looks badass
2005 Stone White SRT-4
SRT-T3ddy is offline   Reply With Quote
Old 07-01-2006, 03:33 PM   #3 (permalink)
Member Number: 31419
Looks good man. Hey I wanted to ask you what headunit is that?
Thanks,
Miguel
Miguel_in_Denver is offline   Reply With Quote
Old 07-01-2006, 03:34 PM   #4 (permalink)
whites97's Avatar
Trader Rating: (36)
The RB1 navigation unit. I LOVE IT!!! Especially since I have it hooked up to the iPod control module as well!
Old 07-01-2006, 07:45 PM   #5 (permalink)
Annihilator's Avatar
Member Number: 42629
GREAT job! You have had some practice with painting I assume, that came out looking great, surely too good for it being your first time. Again, nice job man, I may very well use this writeup when I get my e-blue, it makes the interior look SO much better!
off topic, but how much did that head unit cost you, and was it extremely hard to install?
Annihilator is offline   Reply With Quote
Old 07-01-2006, 07:59 PM   #6 (permalink)
AZSRT$$'s Avatar
Member Number: 36604
Turned out really good. I'll have to mark that up as a future project.
-Matt
Keep it at the track.
2007 GSXR 600
AZSRT$$ is offline   Reply With Quote
Old 07-01-2006, 08:28 PM   #7 (permalink)
jstnelson2006's Avatar
Member Number: 30134
Trader Rating: (37)
How much did the RB1 Navi run you from the dealer?
05 FLAME RED SRT-4
- Mopar BOV-
-FBM PnP Ceramic Coated Intake Mani -
-FBM PnP Ceramic Coated TB & TB Spacer-
- lightweight DR17's w/225's-
jstnelson2006 is offline   Reply With Quote
Old 07-02-2006, 12:17 AM   #8 (permalink)
whites97's Avatar
Trader Rating: (36)
In fact, it is my first interior paint job. My first true paint job was my Redline Elite Quicklift kit for my hood... but that doesn't count in my opinion. I'm just picky... and really take pride in all the work that I do. Patience is a virtue I was never dealt, but perfectionism is one I live by.
As for the headunit... $~800 and the install was a fricken' snap! A one-armed retarded mongoose could do it. Well, maybe not that simple, but rather straight foward none-the-less.
Dealer = Stealer (and mind you, I always get the employee discount too)
Check e-bay... and be certain to look for the "AD" disc, as it is the latest to be released with all location and firmware upgrades.
Dave
Old 07-02-2006, 11:04 PM   #9 (permalink)
Forced's Avatar
Member Number: 13041
It looks real nice I've been wanting to paint a few things in my car but have wondered how durable it is.
Forced is offline   Reply With Quote
Old 07-02-2006, 11:06 PM   #10 (permalink)
Ricekiller's Avatar
Member Number: 25816
Trader Rating: (42)
Dave
does it play dvd's??
does the nav talk to you??
2005 SRT-4 for sale
22,xxx miles, flame red
Mods: greddy turbo timer since 5k miles, Gutted cat, mopar bov, and 180 t-stat.
2 door dings. great shape. clear carfax. Pm me with offer
http://www.srtforums.com/forums/show...61#post4451261
Ricekiller is offline   Reply With Quote
Old 07-02-2006, 11:54 PM   #11 (permalink)
Member Number: 37506
hey man nice write up, i also painted my bezel and would like to add a tip for the folks that wanted to put in the effort. i also tried the taping of the A/C controls, but i wasn't as clean around the edges. tried some paint thinner, and it just ate through the plastic sticker, thankfully i bought an extra bezel for this project.
My tip is this, pick up a jar of rubber cement, and skip using the tape with Scapel Blade. warm up the bezel with a hair dryer and it should peel right off. the sticker is somewhat durable. Then paint as messy as you would like. then glue it back with the rubber cement when your done.
on second thought after typing this, it might be a good idea to tape some of the "sticker bezel" area off, so the rubber cement sticks to plastic instead clearcoat paint. but it's just a thought.
Vapochill is offline   Reply With Quote
Old 07-03-2006, 07:44 AM   #12 (permalink)
whites97's Avatar
Trader Rating: (36)
Quote: Originally Posted by Ricekiller
does it play dvd's?? does the nav talk to you??
It does not play DVDs. It does however talk to you... and the level in which it talks to you can be changed. It can mention EVERY SINGLE DAMN TURN, or it can make a chime so you know to look at the navigation... or you can make it do nothing (like I have it set)... and then there's the manual method, where you click on the voice command and it'll tell you what your next turn is and how far away it is.
Old 07-03-2006, 03:17 PM   #13 (permalink)
Member Number: 26275
Good write up man, exactly how I did my awhile back
2004 E-BLUE SRT-4
EssArTee-4 is offline   Reply With Quote
Old 07-04-2006, 05:04 PM   #14 (permalink)
endlessheart666's Avatar
Member Number: 36526
Trader Rating: (30)
Damn that looks good, once I get some spare cash I'ma do this. How much is dodge asking for that color match paint nowadays?
97 Miata Turbo
endlessheart666 is offline   Reply With Quote
Old 07-04-2006, 09:05 PM   #15 (permalink)
whites97's Avatar
Trader Rating: (36)
$9.40
Page generated in 0.22425 seconds with 13 queries
