Old 04-19-2006, 03:29 PM   #1 (permalink)
westrock's Avatar
Member Number: 20096
HOW-TO: Open Hood Scoop for Better Air Flow
This is to make the vent on the top of the hood more open so that more air can flow back to the turbo.
*** Sorry about the reflections on the hood, I did this in my garage with the Sun behind me....****
This is what the hood scoop looks like from the showroom.
As you can see it is functional, but there is a shelf back there that divertes the air straightdown through a smaller vent.
Without the scoop installed you are able to see clear back to the turbo vents.
Removing The Scoop
You will need a 9mm socket wrench
Remove the two nuts located behind the hood latch.
Then push the screws up out through the holes. Use your thumb to grasp the scoop. Once the two screws clear the holes, pull up and out. The scoop will pop out.
Here you can see the scoop removed.
The air enters the scoop and is directed down through the smaller vents where it hits the inner hood skin. The air then turns 90 degrees again and heads back to the turbo vents. I would imagine all the turning kills the air flow and leaves some room for improvement.
Heres the vents that the air passes through
Modifiying The Scoop
I used a Dremel with a 1/32" thick cut-off disc. You could probably get by with a hacksaw or wire cutters. If your on this website and coming to this particular section, you should already have a Dremel
This shows the amount I chose to cut off. I basically followed the line of the vent on the bottom, so it cuts off even. I cut the center brace about halfway because that all the cut-off disc could reach. Then once I cut everything else free, I twisted the whole piece and the center brace detached nice and cleanly.
Ahh..there we go, much better now
Reinstall the scoop the same way you took it out. Place it in the hole at an angle and then push it so the screws are in the holes. Then you should be able to snap it down in place. Put the nuts back on.
Heres the modified scoop reinstalled. You can now see clear back to the turbo vents. The air has much less restriction and should maintain more velocity as your driving down the road.
Scoop still looks stock from outside, so no evident DIY workmanship here!
-David
06 Lotus Exige
280HP Supercharged 1.8L
05 Black SRT-4 (sold)
330HP & 307TQ @17 PSI (mods in pic)
Diary of a 50 Trim & DTEC Install Huge!
Installs
Intake temp mod, Hood Scoop mod
Use dual stage MBC to set lo & hi throttle boost levels (PTB)
westrock is offline   Reply With Quote
Old 04-19-2006, 03:31 PM   #2 (permalink)
srt4-acr.cpjay's Avatar
Member Number: 34996
tricky ass pics man, my eyes were going nuckin futz
srt4-acr.cpjay is offline   Reply With Quote
Old 04-19-2006, 03:44 PM   #3 (permalink)
Member Number: 10097
Trader Rating: (31)
Is that wall there for water deflection?
Ultimateone is offline   Reply With Quote
Old 04-19-2006, 03:49 PM   #4 (permalink)
Member Number: 34900
yea its there for water deflection. i did sumhting similar to this with my car and i havemt had a problem.
SRT-Vegas765 is offline   Reply With Quote
Old 04-19-2006, 04:09 PM   #5 (permalink)
westrock's Avatar
Thats what I figured, but it never rains in Texas, and I don't drive this car when it does. Plus water still splashes on the Turbo when it rains....just look at the underside of your hood.
Definently a worst case scenario thing, but I think its OK. And as you mentioned I know poeple have done this in the past...there just wasn't a How-To that I saw.
Old 04-20-2006, 12:12 AM   #6 (permalink)
silverpheonix's Avatar
Member Number: 29591
Trader Rating: (39)
Default n
dam thats some crazy shine!
330mmX30mm or approx 13"x1.18"
These probably won't fit stock wheels.
But they do say BOOOYAH! I got nice brakes BEEYATCH!
"just have a qusetion...what does lowering your car have to do with strut bars?...strut bars keep your car stiff at high speeds and hold your engine in place why would you sell them if you lowered you car?..."
silverpheonix is offline   Reply With Quote
Old 04-20-2006, 12:22 AM   #7 (permalink)
IWantAn04's Avatar
Member Number: 3377
paint ur garage son lol! nice write up
Injen sri | AGP WGA | Progress springs
AGP motor/tranny mounts | MaxxFab side exit
CCA bfmic | Enkei RS-V 17x7's | Revitup tbars
map clamp |NGK wideband | AGP fuel return | Crane 12's
Quote: Originally Posted by 03slpr
Me either. WTF is a MAP and why do I want to clamp it? Sounds Painful.
Quote: Originally Posted by silverscooby
BTW, thats Canadian horsepower. Take 11% off of that to convert it to American Horsepower.....
IWantAn04 is offline   Reply With Quote
Old 04-20-2006, 01:06 AM   #8 (permalink)
Imboosted's Avatar
Member Number: 25289
woah....took me like 3 min to figure out what i was looking at. LOL
Imboosted is offline   Reply With Quote
Old 04-21-2006, 12:10 AM   #9 (permalink)
endlessheart666's Avatar
Member Number: 36526
Trader Rating: (30)
I just did this and it actually helped out pretty decently. My car was already hot from driving...I did this mod...went to the grocery store and came back. I popped the hood and rather than getting a greeting of hot air I got barely any heat comming up, so it's definitely working...
97 Miata Turbo
endlessheart666 is offline   Reply With Quote
Old 04-21-2006, 12:14 AM   #10 (permalink)
Member Number: 11681
Trader Rating: (96)
Mine was ike that for close to two years so im sure its fine
2nd Fastest stock turbo no n2o in the country.
Best 60 1.662
Best 1/8 7.55/93
Best 1/4 11.865/116
Best MPG 28.1 city/33 highway
3147 7.49/102 11.51/124 so far 28psi
3147 7.26/100 22psi pump full int
Old 04-21-2006, 04:10 AM   #11 (permalink)
ac_srt4's Avatar
Member Number: 32920
Trader Rating: (50)
will the water kill the parts under the hood? i mean when it rains fairly heavily. i can imagine it iwll be totally wet under the hood.. i am talking about damage by cold water/rust.. or anything ucan think of?
buthowever good write up, i will do this if it doesn't damage anything
ac_srt4 is offline   Reply With Quote
Old 04-21-2006, 10:00 AM   #12 (permalink)
Trader Rating: (30)
It can't be that bad because think of cars like the wrx and imprezas and etc. who have non filtered or blocked off hood scoops. Think of what it must be like once a wrx owner takes off the intercooler and does a front mount. With such a small space I can't imagine that enough water would get through to mater
Old 04-21-2006, 11:17 AM   #13 (permalink)
nicks2kes's Avatar
Member Number: 39505
Trader Rating: (30)
i think ill try this soon, atleast its free!!
13.7@103.1mph
2000 neon es swapped srt-4
FBM ported stock turbo,s1,AEM sri,agp wga,NGK plugs,CTI 3" side exit,jmb upp w/ greddy type rs bov,walbro 255 lph,kinetic 60mm TB
http://www.cardomain.com/ride/2073821
http://www.myspace.com/nickkrupica
THANKS TO EXPOLINEAUTO.COM
nicks2kes is offline   Reply With Quote
Old 04-21-2006, 03:13 PM   #14 (permalink)
dcsax's Avatar
Member Number: 4232
Trader Rating: (13)
For those concerned with water entering, maybe you can buy an additional scoop and insert it on rainy days. Should be easy enough.
Mods: Lots of stuff
dcsax is offline   Reply With Quote
Old 04-21-2006, 04:38 PM   #15 (permalink)
Member Number: 33093
Trader Rating: (13)
water wont harm anything and I just did mine right now with a saw took like 10 min tops. I have yet to test it out but rather fun mod and very easy to do.
'05 - Stone White - Ma Pearl
SOLD!
armeN is offline   Reply With Quote
Page generated in 0.19549 seconds with 13 queries
