HOW-TO: One Hour Alternator Install - Dodge SRT Forum
post #1 of 18 (permalink) Old 08-15-2011, 07:47 PM Thread Starter
Monster's Avatar
Quoted: 3 Post(s)
I've noticed the service manual sends people the longest way possible to install an alternator on our beloved turbo charged beasts. Removing motor mounts, axles and requiring lots of tools and time. I searched for a how-to for another member to no avail.
So I figured I'd post up how I do it.
I discovered this method way back in 2005 when I killed my batt then had my alt tested. I've done 5 since. This method only requires a socket set and a couple of screw drivers. No jacks, trans fluid mess or special tools. Until now I hadn't realized everyone else seems to be doing things the hard (service manual) way.
I don't actually need to replace my alternator but since I was replacing my valve cover gasket. I thought I would help another member who inquired about my method of doing it. So bare with me. I decided to take some pics since someone last year called my bluff on an upper removal.
I'm not a mechanic just an auto enthusiast so I will do the best I can to be as clear as possible with my instructions and terminology.
First disconnect the battery
Next disconnect the pcv valve and drivers side breather hose.
Next remove the coilpack and spark plug wires.
Next remove the valve cover.
At this point you should have easy access to the alternator
loosen the heat shield screws (2) on the top of the assembly
There are 3 bolts holding the alternator assembly together.
An adjustment T-Bolt/nut on the back facing the firewall(1) and a locking
mechanism on the left side of the alternator.(2) There is one that the alternator swivels on also underneath the assembly.(3)
loosen the locking nut on the left (2) then loosen the tensioner nut on the back of the assembly (1) all the way till it comes apart.
Here are a pic of the locking nut and tensioner bolts.
Next there is a wire harness toward the bottom of the alternator that needs to be unplugged.
Next Remove the B+ terminal nut and wire
Move the alternator forward a bit so you can wiggle the belt past the pulley.
Remove the lower alternator pivot bolt. (3)
Remove the alternator from the top of the vehicle.
Reverse instructions to install the new one.
Originally Posted by SRT2MR2 View Post
I also will suggest you have a 15mm ratchet wrench for #3 bolt, the tension bolt #1 is a 13mm and #2 is also a 15mm
Originally Posted by Turbolag87 View Post
ur all idiots and noobs.
Stop giving out retarded information
Monster is offline
post #2 of 18 (permalink) Old 08-16-2011, 07:52 AM
BoatsNHoes's Avatar
Quoted: 3 Post(s)
Nice post! I thought I was going to have to wait for a motor swap to put in a higher capacity alternator.
BoatsNHoes is offline
post #3 of 18 (permalink) Old 08-16-2011, 08:07 PM
Quoted: 0 Post(s)
Monster thanks so much man, I got your PMs. I will be putting mine in this week thanks to you.
passtschon is offline
post #4 of 18 (permalink) Old 08-18-2011, 05:20 PM
Quoted: 2 Post(s)
Brilliant!! STICKY this. Subscribed for future ref
tooner is offline
post #5 of 18 (permalink) Old 08-19-2011, 03:52 PM
RUgoinUp's Avatar
Quoted: 9 Post(s)
Was already stickied.
Ever lie, steal, dishonor your parents? Those are only 3 of 10 Commandments. Breaking 1 condemns U 2 Hell. If U want Heaven, admit your guilt, & ask God 2 forgive U based on Jesus' death on a cross. Then love God & people.
RUgoinUp is offline
post #6 of 18 (permalink) Old 08-19-2011, 03:59 PM
director1203's Avatar
Quoted: 0 Post(s)
very nice.
DCR built
PTE6262 powered
Frana input with extended gears
AEM now installed
Best timeslip
1.78 60ft
11.12 1/4
129.65 MPH
director1203 is offline
post #7 of 18 (permalink) Old 08-19-2011, 04:18 PM
SRTFORUM Moderator
Advans's Avatar
Quoted: 71 Post(s)
Nice man!
Advans is offline
post #8 of 18 (permalink) Old 08-19-2011, 04:19 PM Thread Starter
Monster's Avatar
Quoted: 3 Post(s)
Thanks guys. That last pic is actually a video showing there is room to pull it past the head. Just click it.
I also don't have a water overflow in that location so if you have one its likely that will need to come off as well.
Monster is offline
post #9 of 18 (permalink) Old 12-06-2011, 06:08 PM
Tonysrt4's Avatar
Quoted: 0 Post(s)
Wbt how to replace the band
Tonysrt4 is offline
post #10 of 18 (permalink) Old 12-07-2011, 10:47 AM
Gizmodo's Avatar
Quoted: 74 Post(s)
If you don't want to remove the valve cover you can put a jack under the transaxle and remove the bolt that holds it on and lower the engine slightly. You may have to unbolt the exhaust.
Gizmodo is offline
post #11 of 18 (permalink) Old 12-24-2011, 02:15 PM
John203's Avatar
Quoted: 1 Post(s)
has anyone done this with a big turbo setup? just wondering if anything gets in the way , like the dumptube or wastegate?
Dcr Option A + Cncport Street Storm head + DBB 6262 =
John203 is offline
post #12 of 18 (permalink) Old 03-12-2012, 05:04 PM
SRT2MR2's Avatar
Quoted: 0 Post(s)
yes the overflow gets in the way, i jus used this method to get my old one out as my new one will arrive tomorrow, i also will suggest you have a 15mm ratchet wrench for #3 bolt, the tension bolt #1 is a 13mm and #2 is also a 15mm
05 Orange Blast- sold
03 Solar Yellow- sold
04 Black- sold
04 Silver- sold
05 black- trying again
SRT2MR2 is offline
post #13 of 18 (permalink) Old 11-19-2012, 08:31 PM
sdubb3's Avatar
Quoted: 0 Post(s)
Does anyone know where I can get a replacement locking nut and the bolt thing it spins onto? Mine has snapped off making my alternator useless. Its (2) on the diagram. Thanks.
EDIT
Found a pic of it in a old thread. Do I really have to go to a junk yard?
Full Stage 2 w/o toys+ DSP, ACT street/strip, SRI, MaxxFabb 3" TBE single exit w/Magnaflow muffler, Walbro 255, 180* T-stat, Uego Wideband
sdubb3 is offline
post #14 of 18 (permalink) Old 05-04-2014, 03:34 PM
f2tzoomzoom's Avatar
Quoted: 0 Post(s)
note that if you do jack and remove the passenger tire the bottom bolt is extremely easy to remove.
Thanks for the info OP worked like a charm.
f2tzoomzoom is offline
post #15 of 18 (permalink) Old 05-10-2014, 06:20 PM
Quoted: 0 Post(s)
wow very handy info ! thanks !
evilneon95 is offline
User Tag List
Linear Mode Linear Mode
