Old 01-29-2008, 06:49 PM   #1 (permalink)
ralf's Avatar
Member Number: 55887
How-To: Oil Catch Can & PCV Leak Stop Valve
This is a procedure to make a custom oil catch can and also install a check valve to prevent leaks through the pcv valve. Notice this check valve is very small, light and efficient.
Buy the following parts:
1. Home depot: HUSKY 1/4 In. Air Compressor Filter SKU 401910 (1 piece)
2. Grainger: Brass check valve item # 6D914 (1 piece)
3. female Fittings 90° Elbow 1/4 npt thread (1 piece)
4. Grainger: brass hose barb fitting 3/8 hose, 1/4 thread male, item # 4A488 (2 pieces)
5. 2 3/8 Hoses about 40 inch long, for oil and gas type.
6. something to secure connections (tie zips, etc).
PROCEDURE:
Notice: use teflon tape or something like that on all threads.
1.attach one barb fitting to the 90° elbow as shown:
2.attach the check valve to the other side of the 90° elbow, notice the arrow pointing towards the elbow.
3. Attach this to one side of the air filter, notice an arrow on top of the filter showing the direction of flow, this arrow must point towards the elbow and valve.
4. attach the other fitting barb to the other side of the air filter, and attach one of the hoses to it and secure it.
5. Attach the other hose to the opposite barb fitting and secure it.
6. unplug the rubber grommet between the pcv valve and the manifold pipeline, and attach the air filter side hose to pcv valve.
7. Attach the other hose from the check valve side to the manifold pipeline and secure it. Then, place it with zipties below the AC line.
Thatīs all!
Ralf
Dodge SRT-4 2004 electric blue
Bmw 330i 2002
ralf is offline   Reply With Quote
Old 01-29-2008, 07:15 PM   #2 (permalink)
BMPUTZ's Avatar
Member Number: 53572
Can't see pics. You've been cursed by the red "X"
2004 Dodge Neon SRT-4
308WHP/326Torque
BMPUTZ is offline   Reply With Quote
Old 01-30-2008, 05:34 PM   #3 (permalink)
ralf's Avatar
yeah, i can see.... iīm using google pictures, i guess it wont let me link the pictures from an external site... how can i post pictures on the message?
Old 01-30-2008, 11:47 PM   #4 (permalink)
04RedSrt-4's Avatar
Member Number: 56795
Trader Rating: (35)
You can use photobucket. LETS SEE SOME PICS.
04RedSrt-4 is offline   Reply With Quote
Old 02-01-2008, 12:45 PM   #5 (permalink)
Miguelangelo's Avatar
Member Number: 23664
Tinypic.com
It's better to live one day as a lion than a thousand years as a lamb
STOP STREET RACING
Miguelangelo is offline   Reply With Quote
Old 02-02-2008, 01:50 PM   #6 (permalink)
ralf's Avatar
pics now are showing, thanks for the site advice!
Old 02-02-2008, 02:45 PM   #7 (permalink)
redline88's Avatar
Member Number: 58842
i used the same exact filter thingy. ad on the bottom of it, it would leak air. and there was no way to stop it from leaking, i capped it ad oil would just drip out of it. there a way to fix that
Mopar CAI, Mopar exhaust, Mopar STS, Mopar BOV, Apexi Turbo timer, AGP WGA, 8000 HID's, Tein springs
redline88 is offline   Reply With Quote
Old 02-05-2008, 10:15 AM   #8 (permalink)
ralf's Avatar
maybe you put the check valve on the wrong side and there vas positive pressure inside the filter, i donīt have any trouble so far with the bottle of the filter because it only has vacuum.
How did you install it?
Old 02-05-2008, 12:23 PM   #9 (permalink)
redline88's Avatar
i conected a hose from my PCV valve and connected it to the CC then got anthoer hose and connected it to the other side of the CC and the connected that hose to the IM.
Old 02-06-2008, 05:56 AM   #10 (permalink)
BMPUTZ's Avatar
Mine leaked from the bottom as well. What I did was knocked out the barb thingy at the bottom and then plugged the hole with a bolt I had laying around and just for good measure I sealed the bolt with some high temp silicone gasket maker. Might sound ghetto but it worked. I have boost leak tested several times now with absolutely no leaking. The only thing I haven't figured out is how I a going to drain the filter when it starts to fill up..........
Old 02-06-2008, 11:23 AM   #11 (permalink)
wiggyx's Avatar
Member Number: 58107
Trader Rating: (20)
Sorry if this sounds dumb, but why is the check valve necessary? Isn't the PCV valve already a check valve of sorts? Wouldn't this just be redundant? Thanks.
Old 02-06-2008, 03:33 PM   #12 (permalink)
BMPUTZ's Avatar
Yes the PCV valve is a check valve but it does not close completely under WOT which creates a boost leak through the valve cover and into the intake. The check valve will close completely and no more boost leak.
Old 02-27-2008, 02:08 PM   #13 (permalink)
King Cid's Avatar
Member Number: 55188
Just a question, can't you just cap the intake manifold nipple off? Then just run a breather filter to the other side of the catch can instead of routing it back to your intake?
'04 Electric Blue SRT-4:
Stage 2 w/toys, SST Turbo upgrade, methanol injected, Crane cam/springs/retainers, Unorthodox racing pully, Unorthodox cam gears, Boomba solid motor mounts, AEM TRU-Boost (23 psi hold), Apexi NEO AFC, OBX huge racing FMIC, MSD performance ignition coil+wires, Denso iridiums, AEM SAI, Walbro 255 fuel pump, Maxx Fabb 3in catless exhaust, fully rebuilt Mopar trans, Clutchmasters fx400 clutch & flywheel, mopar s.s.
King Cid is offline   Reply With Quote
ŧ Wheel & Tire Center
Page generated in 0.26205 seconds with 11 queries
